发表于 2010-5-11 16:32:56
在网上找个SPICE模型,添加到库里就可以了。
以下文字拷贝到记事本另存位*.cir,不包括“—”
AD630 SPICE Macro-model 2/92, Rev. A
* ARG / PMI
* Copyright 1990 by Analog Devices, Inc.
* The information on this diskette is protected under the
* United States copyright laws. Analog Devices, Inc.("ADI")
* hereby grants users of these macro-models hereto referred
* to as licensee, a nonexclusive, nontransferable license to
* use these macro-models as long as the licensee abides by
* the terms of this agreement. Before using the macro-
* models the licensee should read this license. If the
* licensee does not accept these terms, this diskette should
* be returned to ADI within 30 days.
* The licensee may not sell, loan, rent, lease, or license
* the macro-models, in whole, in part, or in modified form,
* to anyone outside the licensee's company. The licensee
* may modify these macro-models to suit his specific
* applications, and the licensee may make copies of this
* diskette or macromodels for use within his company only.
* These macro-models are provided "AS IS, WHERE IS, AND WITH
* NO WARRANTY OF ANY KIND EITHER EXPRESSED OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO ANY IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE."
* In no event will ADI be liable for special, collateral,
* incidental, or consequential damages in connection with or
* arising out of the use of these macro-models. ADI
* reserves the right to make changes to the products and the
* macro-models without prior notice.
* Node assignments
* chan A non-inverting input
* | chan A inverting input
* | | RIN A
* | | | chan B non-inverting input
* | | | | chan B inverting input
* | | | | | RIN B
* | | | | | | sel A
* | | | | | | | sel B
* | | | | | | | | RB
* | | | | | | | | | RF
* | | | | | | | | | | RA
* | | | | | | | | | | | comp
* | | | | | | | | | | | | status
* | | | | | | | | | | | | | pos supply
* | | | | | | | | | | | | | | neg supply
* | | | | | | | | | | | | | | | output
.SUBCKT AD630 11 10 19 21 20 24 25 29 47 49 48 52 51 99 50 46
* COMPARATOR
V1 99 97 1
I1 97 1 100.2E-6
D1 1 97 DX
Q1 3 2 1 QP
Q2 5 4 1 QP
R1 3 50 40E3
R2 5 50 40E3
R4 25 2 1E3
R5 29 4 1E3
* COMPARATOR GAIN AND CLAMP
EREF 98 0 100 0 1
E1 6 98 5 3 12.931E3
R3 6 7 1E6
D2 7 8 DX
D3 9 7 DX
V6 8 98 .2429
V7 98 9 .2429
Q7 51 53 50 QN
G11 99 53 7 100 100E-6
D14 53 99 DY
* CHANNEL A AMPLIFIER AND POLE AT 1.7MHZ
R6 10 13 5E11
R7 11 13 5E11
IOS1 11 10 3.333E-9
CIN1 10 11 1E-12
Q3 14 10 16 QN
Q4 15 12 17 QN
R8 99 14 12.736E3
R9 99 15 12.736E3
C1 14 15 3.675E-12
R10 16 18 12.220E3
R11 17 18 12.220E3
G2 18 50 7 100 100.2E-6
D4 50 18 DZ
R17 19 11 2.5E3
EOS1 12 11 POLY(1) 35 100 50E-6 1
* CHANNEL B AMPLIFIER
R12 20 23 5E11
R13 23 21 5E11
IOS2 21 20 3.333E-9
CIN2 20 21 1E-12
Q5 14 20 26 QN
Q6 15 22 27 QN
R14 26 28 12.220E3
R15 27 28 12.220E3
G3 28 50 100 7 100.2E-6
D5 50 28 DZ
R18 24 21 2.5E3
EOS2 22 21 POLY(1) 37 100 50E-6 1
* GAIN STAGE, SLEW RATE, AND DOMINANT POLE AT 5.623HZ
G1 98 30 15 14 78.518E-6
RPI 30 98 12.736E3
C2 30 33 2.222E-12
GM1 33 98 30 0 1
RL 33 98 1E6
CC 30 52 2.75E-12
D6 33 31 DX
D7 32 33 DX
V2 99 31 1.42
V3 32 50 1.53
* AMP A COMMON MODE STAGE AND ZERO AT 100HZ
R20 34 35 1E6
R21 35 98 1
C3 34 35 1.592E-9
ECMA 34 98 13 100 3.162
* AMP B COMMON MODE STAGE AND ZERO AT 100HZ
R22 36 37 1E6
R23 37 98 1
C4 36 37 1.592E-9
ECMB 36 98 23 100 3.162
* POLE AT 20MHZ
G5 98 39 33 100 1E-6
R25 39 98 1E6
C6 39 98 7.958E-15
* POLE AT 20MHZ
G6 98 40 39 100 1E-6
R26 40 98 1E6
C7 40 98 7.958E-15
* OUTPUT STAGE
ISY 99 50 3.6E-3
R27 99 100 32.86E3
R28 100 50 32.86E3
R29 99 45 200
R30 45 50 200
L1 45 46 1E-10
G9 45 99 99 40 5E-3
G10 50 45 40 50 5E-3
G7 43 50 40 45 5E-3
G8 44 50 45 40 5E-3
V4 41 45 1.9
V5 45 42 1.9
D8 40 41 DX
D9 42 40 DX
D10 99 43 DX
D11 99 44 DX
D12 50 43 DY
D13 50 44 DY
R31 46 49 10E3
R32 49 47 10E3
R33 49 48 5E3
.MODEL QP PNP(BF=500)
.MODEL QN NPN(BF=500)
.MODEL DX D
.MODEL DY D(BV=50)
.MODEL DZ D(BV=30)
.ENDS AD630 |
