TINA Design Suite v9 最新版发布时间:2010年4月30日 18:07:47 《更新说明在下面》
最新测试版下载:点击此处下载 ourdev_550860.rar(文件大小:53.98M) (原文件名:Tina90en.rar)
![](http://cache.amobbs.com/bbs_upload782111/files_28/ourdev_550861.PNG)
(原文件名:Tina v9.PNG)
New features of TINA v9 and TINA Design Suite v9
• Full Vista and Windows 7 compatibility
• Multi core support
• Enhanced analysis speed
Up to 10 times higher speed on 1 core, 15x on dual core, 20x on quad core
• Advanced powerful Spice-VHDL mixed mode analysis
• Extended catalog with ARM 7, ARM 9 and HCS08 microcontrollers, more SMPS ICs models, realistic ADC and DAC models,
LCD display, Bi-color LEDs
• Extended MCU simulation, USB and other modules
• Programmable Design Tool where users can implement design procedures for calculating and setting circuit parameters so that
the circuits can produce predefined target output values.
• Extended flowchart tool: PIC, AVR, 8051, code box, USART, external interrupt handling
• Open and save TINA designs, models and libraries directly from the Web
• Import Spice .CIR and .LIB files directly from the Web
• Import Libraries, Designs and Examples from any earlier versions of TINA v7 and later.
• Show analysis results on diagrams during analysis
• Fast diagram drawing and processing speed, even for very large circuits
• New tool in the View menu of the diagrams for easier hiding and showing curves on diagrams
• New more effective storing of analysis results, save all analysis results for all circuits without speed compromise
• Parametrizable output curve filter for even more effective storage of results
• Scrollbars for browsing multiple diagrams on the same page
• New diagram cursor tools to find and annotate
local and global maximum, minimum
gain and phase margins
zero crossover frequency
horizontal and vertical coordinates
• Combinational and parallel stepping , show stepping cases (test benches) in separate diagrams
• More advanced tools for addition of parts to TINA from semiconductor manufacturers both from downloaded files and directly
from the internet
• Node list in post processor now displays macro names and local node names in the relevant macros
• Minimize TINA main window while analysis is running
• Run two TINA instances on the same computer
• Multi-level, hierarchical ERC. Checks the main or any subcircuts, or the whole circuit in full depth
• ERC detects and shows floating nodes in Spice subcircuits
• Open Examples command in File menu, for easier return to TINA’s Examples folder
• Open .CIR files from Open command in the File menu
• New arrow button in Open dialog, for easier finding TINA EXAMPLES or User folders
• Updated and extended examples under the EXAMPLES folder
• Conversion of circuits to TINA v7 format, for compatibility with TINA v7 and v8 and v9
• Detailed Transient Statistics from the View menu
• TINA v9 is now digitally signed by DesignSoft
PCB Design
• G-Code export of PCB designs for creating control files for milling machines
• Extended PCB footprint catalog
Tina Pro是重要的现代化EDA(Electronic Design Automation,即电子电路设计自动化)软件之一,用于模拟及数字电路的仿真分析。其研发者是欧洲DesignSoft Kft.公司,目前大约流行四十多个国家,并有二十余种不同语言的版本,其中包括中文版,大约含有两万多个分立或集成电路元器件。
该软件的具体功能包括:在模拟电路分析方面,Tina Pro除了具有一般电路仿真软件通常所具备的直流分析、瞬态分析、正弦稳态分析、傅立叶分析、温度扫描、参数扫描、最坏情况及蒙特卡罗统计等仿真分析功能之外,还能先对输出电量进行指标设计,然后对电路元件的参数进行优化计算。此外,它具有符号分析功能,即能给出时域过渡过程表达式或频域传递函数表达式;具有RF仿真分析功能;具有绘制零、极点图、相量图、Nyquist图等重要的仿真分析功能。
在数字电路分析方面,Tina Pro支持VHDL语言;并具有BUS总线及虚拟连线等功能,这避免了电路图中元件之间连线过密,使得电路绘图界面看起来更清晰、简洁。
Tina Pro具有八种虚拟测量仪器,各仪器与元件之间采用虚拟连线。其虚拟测试仪器(如多踪示波器)的动态演示功能,是极好的电类教学辅助工具。Tina Pro的仿真分析结果,如波形图可方便地与电路图粘贴在界面中,对输出打印及分析资料的完整保存十分便利。
Tina Pro可以与其硬件设备Tina-Lab,即实时信号发生器、数据采集器相连接,故能将实时测量与虚拟仿真结果相比对。这是目前所知能实现该项功能的少数实用技术产品之一。
Tina Pro具有较高的性能价格比。它是目前所知为数不多的具有简体中文界面的成熟软件(在Help索引文件中,也用中文对于电路器件模型参数进行详细解释)。
Tina Pro是一种功能强大的电路仿真软件,不仅在工程实践中,对于电子产品的开发与研制能够发挥高效率、高精度的作用,而且将其引入各类学校电类课程的教学,会带来意想不到的教学效果
〖主要特色: 〗
1、模拟, 数字以及混合模式仿真
2、强有力的编辑工具 (电路图, 连线表, 文本, 方程, 和激励编辑器)
3、完善的说明介绍 (可定制的说明包括波特图,牛克斯图,组滞,极和零点,瞬时响应,数字波形,为后加工结果用的翻译器及其他)
〖高级特色: 〗
1、放置总线
2、电气规则核查(ERC)
3、材料单(BOM)
4、分级设计
5、带版本控制的成套设计
6、网络分析
7、网络分析器和频谱分析器
8、带S-参数模型的RF元件
9、屏幕自定义选项(定义背景,元件颜色等)
10、15,000+ 内置元件模型
11、带参数设计的微波传输带元件
11、为Spice和S参数用的扩展了的存储库管理器
12、逻辑转换和简化
13、子回路 (从电路图或Spice子回路创建你自己的元件)
14、电路图形符号编辑器 (创建你自己的电路图符号)
15、元件工具条编辑器 (追加你的新元件到TINA的图形元件条)
16、参数提取器 (从测量或目录数据中创建元件模型)
17、Spice存储库管理器 (向TINA的Spice存储库追加更多的模型或创建你自己的Spice存储库)
18、符号分析 (以闭形式的表达式显示结果)
19、傅立叶分析 (傅立叶频谱,傅立叶级数和失真)
20、噪声分析 (噪声频谱,信号对噪声比及其他)
21、公差分析 (蒙特卡罗[Monte-Carlo]和最坏情形[worst-case]分析)
22、最优化 (寻找预定目标和灵敏度)
23、虚拟设备 (万用表,示波器,信号发生器,信号分析器,逻辑分析器)
24、实时测试与测量
25、教学和训练工具 (问题解答和故障排除) |
