发表于 2011-2-2 03:02:23
-- S S R A M i n t e r f a c e
-- various components for ssrams
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
package SSRAM is
component ssram_conn is
generic(
DWIDTH : positive := 16;
AWIDTH : positive := 18
port (
clk : in std_logic;
A : in unsigned(AWIDTH -1 downto 0);
Din : in std_logic_vector(DWIDTH -1 downto 0);
Dout : out std_logic_vector(DWIDTH -1 downto 0);
rw : in std_logic;
bw : in std_logic_vector((DWIDTH/8) downto 0) := (others => '0');
ssramA : out unsigned(AWIDTH -1 downto 0);
ssramD : inout std_logic_vector(DWIDTH -1 downto 0);
ssramRW : out std_logic;
ssramBW : out std_logic_vector((DWIDTH/8) downto 0)
end component ssram_conn;
component cs_ssram is
generic(
port (
clk : in std_logic;
clk_div2 : in std_logic; -- clk divided by 2
p0_A : in unsigned(AWIDTH -1 downto 0);
p0_Din : in std_logic_vector(DWIDTH -1 downto 0);
p0_Dout : out std_logic_vector(DWIDTH -1 downto 0);
p0_rw : in std_logic;
p0_bw : in std_logic_vector((DWIDTH/8) downto 0) := (others => '0');
p1_A : in unsigned(AWIDTH -1 downto 0);
p1_Din : in std_logic_vector(DWIDTH -1 downto 0);
p1_Dout : out std_logic_vector(DWIDTH -1 downto 0);
p1_rw : in std_logic;
p1_bw : in std_logic_vector((DWIDTH/8) downto 0) := (others => '0');
end component cs_ssram;
end package SSRAM;
-- SSRAM cycle shared memory implementation
-- ssram can be accessed by 2 ports at clk_div2 frequency. SSRAM operates at clk frequency
-- clk_div2 is actually a clk_en signal (no extra clock-domain)
-- read command: data valid after 3 clk_div2 cycles
-- 1) set address, RW = '1' (read command)
-- 2) present address/RW to ssram
-- 3) ssram presents data
-- 4) data (p0_dout/p1_dout) valid
-- 5) take/use data
-- note: p0_dout Tsu = 1 clk_div2 cycle
-- p1_dout Tsu = 1 clk cycle (so half of p0_dout Tsu)
library ieee;
entity cs_ssram is
generic(
port (
clk : in std_logic;
end entity cs_ssram;
architecture structural of cs_ssram is
generic(
DWIDTH : positive;
AWIDTH : positive
port (
clk : in std_logic;
rw : in std_logic;
signal A : unsigned(AWIDTH -1 downto 0);
signal Din : std_logic_vector(DWIDTH -1 downto 0); -- from SSRAMs
signal Dout : std_logic_vector(DWIDTH -1 downto 0); -- towards SSRAMs
signal BW : std_logic_vector((DWIDTH/8) downto 0);
signal RW : std_logic;
begin
-- mux address / data-in / rw / bw
gen_muxs: process (clk)
variable iA : unsigned(AWIDTH -1 downto 0);
variable iDout : std_logic_vector(DWIDTH -1 downto 0);
variable iRW : std_logic;
variable iBW : std_logic_vector((DWIDTH/8) downto 0);
begin
if (clk_div2 = '0') then
iA := p0_A;
iDout := p0_Din;
iRW := p0_rw;
for n in 0 to (DWIDTH/8) loop
iBW(n) := p0_bw(n);
end loop;
else -- clk_div2 = '1'
iA := p1_A;
iDout := p1_Din;
iRW := p1_rw;
iBW(n) := p1_bw(n);
end loop;
end if;
if (clk'event and clk = '1') then
A <= iA;
Dout <= iDout;
RW <= iRW;
BW <= iBW;
end if;
end process gen_muxs;
-- instert ssram IO controller
ssram_io_ctrl: ssram_conn generic map (DWIDTH => DWIDTH, AWIDTH => AWIDTH)
port map (clk, A, Dout, Din, RW, bw, ssramA, ssramD, ssramRW, ssramBW);
-- demux data from ssram
demux_din: process(clk)
begin
if (clk_div2 = '1') then -- switched
p0_Dout <= Din;
p1_Dout <= Din;
end if;
end if;
end process demux_din;
end architecture structural; -- of cs_ssram
-- SSRAM physical connection (IO) controller
library ieee;
entity ssram_conn is
generic(
port (
clk : in std_logic;
rw : in std_logic;
end entity ssram_conn;
architecture structural of ssram_conn is
signal dD, ddD, dddD : std_logic_vector(DWIDTH -1 downto 0);
signal dsel, ddsel : std_logic;
signal dddSel : std_logic_vector(DWIDTH -1 downto 0);
attribute preserve_signal : boolean;
attribute preserve_signal of dddSel: signal is true; -- instruct compiler to leave these signals
attribute preserve_signal of dddD: signal is true;
begin
process(clk, dddD, dddSel)
begin
if(clk'event and clk = '1') then
-- compensate ssram pipeline delay
dD <= Din; -- present address / rw
ddD <= dD; -- ssram takes address / rw over
dddD <= ddD; -- present data
dsel <= not RW;
ddsel <= dsel;
for n in 0 to (DWIDTH -1) loop
dddsel(n) <= ddsel;
end loop;
Dout <= ssramD;
ssramA <= A;
ssramRW <= RW;
ssramBW <= BW;
end if;
if (dddSel(n) = '1') then
ssramD(n) <= dddD(n);
ssramD(n) <= 'Z';
end if;
end loop;
end process;
end architecture structural; -- of ssram_conn |
