全资料用ATmega168制作寻迹小车,让它围绕8字形走(精彩视频)。
http://www.ermicro.com/blog/?p=1163
// File Name : bramlfr.c
// Version : 1.0
// Description : BRAM Line Follower Robot (LFR)
// : LFR with PID Controller
// Author : RWB
// Target : AVRJazz Mega168 Board
// Compiler : AVR-GCC 4.3.0; avr-libc 1.6.2 (WinAVR 20090313)
// IDE : Atmel AVR Studio 4.17
// Programmer : AVRJazz Mega168 STK500 v2.0 Bootloader
// : AVR Visual Studio 4.17, STK500 programmer
// Last Updated : 28 July 2009
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <compat/twi.h>
#include <stdio.h>
#include <avr/pgmspace.h>
#include <avr/eeprom.h>// BRAM Debugging Mode, 0-Debug Off, 1-Debug On
#define BRAM_DEBUG 0#define BAUD_RATE 19200#define MAX_TRIES 50#define MCP23008_ID 0x40 // MCP23008 Device Identifier
#define MCP23008_ADDR 0x0E // MCP23008 Device Address
#define IODIR 0x00 // MCP23008 I/O Direction Register
#define GPPU 0x06 // MCP23008 I/O Pull-Up Resistor Register
#define GPIO 0x09 // MCP23008 General Purpose I/O Register#define I2C_START 0
#define I2C_DATA 1
#define I2C_DATA_ACK 2
#define I2C_STOP 3
#define ACK 1
#define NACK 0// Define BRAM Steering
#define MOVE_FORWARD 0
#define TURN_LEFT 1
#define TURN_RIGHT 2
#define ROTATE_LEFT 3
#define ROTATE_RIGHT 4
#define MOVE_BACKWARD 5
#define FULL_STOP 6// Define BRAM Sensor
#define MAX_MAP 24
#define TARGET_VAL 60
#define MAX_SENSOR_MAP 120// Define BRAM Variables
const unsigned int sensor_map[] PROGMEM = {
0b00000,0,
0b00001,10,
0b00011,20,
0b00010,30,
0b00111,40,
0b00110,50,
0b00100,60,
0b01100,70,
0b11100,80,
0b01000,90,
0b11000,100,
0b10000,110
};unsigned char MaxSpeed; // Hold Motor Maximum Speed
unsigned int Kp,Ki,Kd; // PID Parameters
int prev_res=0, prev_err_1=0, prev_err_2=0; // PID Control Variablesvoid uart_init(void)
UBRR0H = (((F_CPU/BAUD_RATE)/16)-1)>>8; // set baud rate
UBRR0L = (((F_CPU/BAUD_RATE)/16)-1);
UCSR0B = (1<<RXEN0)|(1<<TXEN0); // enable Rx & Tx
UCSR0C= (1<<UCSZ01)|(1<<UCSZ00); // config USART; 8N1
}void uart_flush(void)
unsigned char dummy; while (UCSR0A & (1<<RXC0)) dummy = UDR0;
}int uart_putch(char ch,FILE *stream)
if (ch == '\n')
uart_putch('\r', stream); while (!(UCSR0A & (1<<UDRE0)));
UDR0=ch; return 0;
}int uart_getch(FILE *stream)
unsigned char ch; while (!(UCSR0A & (1<<RXC0)));
ch=UDR0;
/* Echo the Output Back to terminal */
uart_putch(ch,stream);
return ch;
}void ansi_cl(void)
// ANSI clear screen: cl=\E[H\E[J
putchar(27);
putchar('[');
putchar('H');
putchar(27);
putchar('[');
putchar('J');
}void ansi_me(void)
// ANSI turn off all attribute: me=\E[0m
putchar(27);
putchar('[');
putchar('0');
putchar('m');
}void ansi_cm(unsigned char row,unsigned char col)
// ANSI cursor movement: cl=\E%row;%colH
putchar(27);
putchar('[');
printf("%d",row);
putchar(';');
printf("%d",col);
putchar('H');
}// BRAM Steering Function
// PD2 - Input 1 (Left Motor), PD3 - Input 2 (Left Motor)
// PD4 - Input 3 (Right Motor), PD7 - Input 4 (Right Motor)void BRAM_Steer(unsigned char steer)
switch(steer) {
case MOVE_FORWARD:
PORTD &= ~(1 << PD4); PORTD |= (1 << PD7); // Right Motor On Forward
PORTD &= ~(1 << PD2); PORTD |= (1 << PD3); // Left Motor On Forward
case TURN_LEFT:
PORTD &= ~(1 << PD2); PORTD &= ~(1 << PD3); // Left Motor Off
case TURN_RIGHT:
PORTD &= ~(1 << PD4); PORTD &= ~(1 << PD7); // Right Motor Off
case ROTATE_LEFT:
PORTD |= (1 << PD2); PORTD &= ~(1 << PD3); // Left Motor On Reverse
case ROTATE_RIGHT:
PORTD |= (1 << PD4); PORTD &= ~(1 << PD7); // Right Motor On Reverse
case MOVE_BACKWARD:
case FULL_STOP:
}// BRAM Motor Speed Control
// PD5 - OC0B -> ENB1 (Left Motor)
// PD6 - OC0A -> ENB2 (Right Motor)
void BRAM_DriveMotor(int left_speed, int right_speed)
unsigned char left_pwm,right_pwm; if (left_speed >= 0 && right_speed >= 0) {
// Move Forward
BRAM_Steer(MOVE_FORWARD);
left_pwm=left_speed;
right_pwm=right_speed; } else if (left_speed < 0 && right_speed < 0) {
// Move Backward
BRAM_Steer(MOVE_BACKWARD); left_pwm=left_speed * -1;
right_pwm=right_speed * -1; } else if (left_speed < 0 && right_speed >= 0) {
// Rotate Left
BRAM_Steer(ROTATE_LEFT); left_pwm=left_speed * -1;
} else if (left_speed >= 0 && right_speed < 0) {
// Rotate Right
BRAM_Steer(ROTATE_RIGHT); left_pwm=left_speed;
} else {
// Full Stop
BRAM_Steer(FULL_STOP); left_pwm=0;
right_pwm=0;
} // Assigned the value to the PWM Output Compare Registers A and B
OCR0A=right_pwm;
OCR0B=left_pwm;
}/* START I2C Routine */
unsigned char i2c_transmit(unsigned char type) {
switch(type) {
case I2C_START: // Send Start Condition
TWCR = (1 << TWINT) | (1 << TWSTA) | (1 << TWEN);
case I2C_DATA: // Send Data with No-Acknowledge
TWCR = (1 << TWINT) | (1 << TWEN);
case I2C_DATA_ACK: // Send Data with Acknowledge
TWCR = (1 << TWEA) | (1 << TWINT) | (1 << TWEN);
case I2C_STOP: // Send Stop Condition
TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTO);
return 0;
} // Wait for TWINT flag set on Register TWCR
while (!(TWCR & (1 << TWINT))); // Return TWI Status Register, mask the prescaller bits (TWPS1,TWPS0)
return (TWSR & 0xF8);
}char i2c_start(unsigned int dev_id, unsigned int dev_addr, unsigned char rw_type)
unsigned char n = 0;
unsigned char twi_status;
char r_val = -1;i2c_retry:
if (n++ >= MAX_TRIES) return r_val; // Transmit Start Condition
twi_status=i2c_transmit(I2C_START);
// Check the TWI Status
if (twi_status == TW_MT_ARB_LOST) goto i2c_retry;
if ((twi_status != TW_START) && (twi_status != TW_REP_START)) goto i2c_quit; // Send slave address (SLA_W)
TWDR = (dev_id & 0xF0) | (dev_addr & 0x0E) | rw_type; // Transmit I2C Data
twi_status=i2c_transmit(I2C_DATA); // Check the TWSR status
if ((twi_status == TW_MT_SLA_NACK) || (twi_status == TW_MT_ARB_LOST)) goto i2c_retry;
if (twi_status != TW_MT_SLA_ACK) goto i2c_quit; r_val=0;i2c_quit:
return r_val;
}void i2c_stop(void)
unsigned char twi_status; // Transmit I2C Data
twi_status=i2c_transmit(I2C_STOP);
}char i2c_write(char data)
char r_val = -1; // Send the Data to I2C Bus
TWDR = data; // Transmit I2C Data
if (twi_status != TW_MT_DATA_ACK) goto i2c_quit; r_val=0;i2c_quit:
return r_val;
}char i2c_read(char *data,char ack_type)
char r_val = -1;
if (ack_type) {
// Read I2C Data and Send Acknowledge
twi_status=i2c_transmit(I2C_DATA_ACK); if (twi_status != TW_MR_DATA_ACK) goto i2c_quit;
} else {
// Read I2C Data and Send No Acknowledge
twi_status=i2c_transmit(I2C_DATA); if (twi_status != TW_MR_DATA_NACK) goto i2c_quit;
} // Get the Data
*data=TWDR;
r_val=0;i2c_quit:
return r_val;
}void Write_MCP23008(unsigned char reg_addr,unsigned char data)
// Start the I2C Write Transmission
i2c_start(MCP23008_ID,MCP23008_ADDR,TW_WRITE); // Sending the Register Address
i2c_write(reg_addr); // Write data to MCP23008 Register
i2c_write(data); // Stop I2C Transmission
i2c_stop();
}unsigned char Read_MCP23008(unsigned char reg_addr)
char data; // Start the I2C Write Transmission
i2c_start(MCP23008_ID,MCP23008_ADDR,TW_WRITE); // Read data from MCP23008 Register Address
i2c_write(reg_addr); // Stop I2C Transmission
i2c_stop();
// Re-Start the I2C Read Transmission
i2c_start(MCP23008_ID,MCP23008_ADDR,TW_READ); i2c_read(&data,NACK);
i2c_stop();
return data;
}unsigned int BRAM_IRSensor()
static unsigned int old_val = TARGET_VAL; unsigned int map_val;
unsigned char sensor_val,ptr; // Turn On the Sensor IR LED
Write_MCP23008(GPIO,0b00011111);
// Read sensor
sensor_val = Read_MCP23008(GPIO) & 0x1F; // Turn Off the Sensor IR LED
Write_MCP23008(GPIO,0b00111111); // Return Value from Sensor Map
map_val=TARGET_VAL; // Default always on center if (sensor_val > 0) {
for(ptr = 0; ptr < MAX_MAP; ptr++) {
// Now get the sensor map value
if (pgm_read_word(sensor_map + ptr) == sensor_val) {
map_val=pgm_read_word(sensor_map + ptr + 1);
} old_val=map_val; // Save the Current IR Array Value } else {
map_val=0; // Adjust for zero result if previous value greater than 5
if (old_val > TARGET_VAL) map_val=MAX_SENSOR_MAP;
} // Display IR Sensor Value in Debugging Mode
#if BRAM_DEBUG
ansi_cm(3,1);
printf("IR Sensor: %02x, Map Value: %03d",sensor_val,map_val);
#endif return map_val;
}void BRAM_PIDControl(unsigned int sensor_val)
int motor_res,err_func;
float KP,KI,KD,cont_res; // Get the Error Function
err_func=sensor_val - TARGET_VAL; // Divide all the PID parameters for decimal value
KP=Kp * 0.1;
KI=Ki * 0.01;
KD=Kd * 0.01; // Calculate the Motor Response using PID Control Equation
cont_res=(float)(prev_res + KP * (err_func - prev_err_1) + KI * (err_func + prev_err_1)/2.0
+ KD * (err_func - 2.0 * prev_err_1 + prev_err_2));
// Now we have to Limit the control response to the Maximum of our motor PWM Motor Value
motor_res=(int)cont_res; if (motor_res > MaxSpeed)
motor_res = MaxSpeed;
if (motor_res < -MaxSpeed)
motor_res = -MaxSpeed;
// Save the Motor Response and Error Function Result
prev_res=motor_res;
prev_err_2=prev_err_1;
prev_err_1=err_func;
// Display Motor Response Value in Debugging Mode
#if BRAM_DEBUG
ansi_cm(4,1);
printf("Motor Response Factor: %d ",motor_res);
#endif // Negative result mean BRAM is on the right, so we need to adjust to the left
// Positive result mean BRAM is on the left, so we need to adjust to the right
if (motor_res < 0)
BRAM_DriveMotor(MaxSpeed + motor_res,MaxSpeed); // Left less speed, Right full speed
BRAM_DriveMotor(MaxSpeed,MaxSpeed - motor_res); // Left full speed, Right less speed
}unsigned int getnumber(unsigned int min, unsigned int max)
int inumber; scanf("%d",&inumber);
if (inumber < min || inumber > max) {
printf("\n\nInvalid [%d to %d]!",min,max);
_delay_ms(500);
return -1;
return inumber;
}void Read_Parameter(void)
// Read the Kp,Ki and Kd From EEPROM at Address: 0x00,0x02,0x04
Kp=eeprom_read_word((unsigned int*) 0x0000);
Ki=eeprom_read_word((unsigned int*) 0x0002);
Kd=eeprom_read_word((unsigned int*) 0x0004);
}// Assign I/O stream to UART
FILE uart_str = FDEV_SETUP_STREAM(uart_putch, uart_getch, _FDEV_SETUP_RW);int main(void)
unsigned char mode,press_tm;
unsigned int ir_sensor;
int ichoice; // Initial PORT Used
DDRB = 0b11111110; // Set PORTB: PB0=Input, Others as Output
PORTB = 0;
DDRC = 0b00000000; // Set PORTC: Input
PORTC = 0xFF; // Pull-Up Input
DDRD = 0b11111111; // Set PORTD: Output
PORTD = 0; // Define Output/Input Stream
stdout = stdin = &uart_str; // Initial UART Peripheral
uart_init(); // Initial BRAM Terminal Screen
ansi_me();
ansi_cl(); // Clear Screen#if BRAM_DEBUG
ansi_cm(1,1);
printf("Welcome to AVRJazz Mega168 BRAM Debugging Mode");
#endif // Initial The 8-bit PWM 0
// Fast PWM Frequency = fclk / (N * 256), Where N is the prescale
// f_PWM = 11059200 / (8 * 256) = 5400 Hz
TCCR0A = 0b10100011; // Fast PWM 8 Bit, Clear OCA0/OCB0 on Compare Match, Set on TOP
TCCR0B = 0b00000010; // Used 8 Prescaler
TCNT0 = 0; // Reset TCNT0
OCR0A = 0; // Initial the Output Compare register A & B
OCR0B = 0; // Initial ATMega168 TWI/I2C Peripheral
TWSR = 0x00; // Select Prescale of 1 // SCL frequency = 11059200 / (16 + 2 * 48 * 1) = 98.743 kHz
TWBR = 0x30; // 48 Decimal // Initial the MCP23008 Devices GP0 to GP4 Input, GP5 to GP7 Output
Write_MCP23008(IODIR,0b00011111);
Write_MCP23008(GPPU,0b00011111); // Enable Pull-Up on Input
Write_MCP23008(GPIO,0b00111111); // Reset all the Output Port, Make GP5 High // Set ADCSRA Register on ATMega168
ADCSRA = (1<<ADEN) | (1<<ADPS2) | (1<<ADPS1); // Set ADMUX Register on ATMega168
ADMUX = (1<<ADLAR); // Use Right Justified, Select Channel 0 // Initial the Motor
BRAM_DriveMotor(0,0);
mode=0; // Default BRAM Off
press_tm=0; // Initial PID Control Variables
prev_res=0;
prev_err_1=0;
prev_err_2=0;
MaxSpeed = 150; // Initial Maximum Speed // Read Default BRAM Parameter from EEPROM
Read_Parameter();
for(;;) { // Loop Forever
// Check if Button is pressed than enter to the Setup Mode
if (bit_is_clear(PINB, PB0)) { // if button is pressed
_delay_us(100); // Wait for debouching
press_tm++;
if (press_tm > 100) {
press_tm=0;
mode++;
if (mode > 2)
mode = 0;
// Start conversion by setting ADSC on ADCSRA Register
ADCSRA |= (1<<ADSC); // wait until convertion complete ADSC=0 -> Complete
while (ADCSRA & (1<<ADSC)); // Get ADC the Result
MaxSpeed = ADCH; if (mode == 0) {
prev_res=0;
prev_err_1=0;
prev_err_2=0;
} if (mode == 1) {
// Read the IR Sensor
ir_sensor=BRAM_IRSensor(); // Give some delay Before PID Calculation
_delay_us(50); // Execute the BRAM LFR PID Controller
BRAM_PIDControl(ir_sensor);
} // Entering BRAM PID Setup Mode
if (mode == 2) {
// Stop BRAM Motors
BRAM_DriveMotor(0,0); // Initial BRAM Terminal Screen
uart_flush(); // Flush UART ansi_me();
ansi_cm(1,1);
printf("Welcome to AVRJazz Mega168 BRAM Setup"); ansi_cm(3,1);
printf("BRAM Maximum Speed Value: %d",MaxSpeed);
ansi_cm(5,1);
printf("1. Kp - Proportional Parameter Factor (%d)\n",Kp);
printf("2. Ki - Integral Parameter Factor (%d)\n",Ki);
printf("3. Kd - Derivative Parameter Factor (%d)\n",Kd);
printf("4. Save Parameters to the EEPROM\n");
printf("5. Refresh Setup\n");
printf("6. Exit\n");
printf("\nEnter Choice: ");
if ((ichoice=getnumber(1,6)) < 0) continue;
switch (ichoice) {
case 1: // Kp Parameter
printf("\n\nKp Parameter [0-1000]: ");
if ((Kp=getnumber(0,1000)) < 0) continue;
case 2: // Ki Parameter
printf("\n\nKi Parameter [0-1000]: ");
if ((Ki=getnumber(0,1000)) < 0) continue;
case 3: // Kd Parameter
printf("\n\nKd Parameter [0-1000]: ");
if ((Kd=getnumber(0,1000)) < 0) continue;
case 4: // Save to EEPROM
// Write the Kp,Ki and Kd to EEPROM Address: 0x0000,0x0002,0x0004
eeprom_write_word((unsigned int*) 0x0000,Kp);
eeprom_write_word((unsigned int*) 0x0002,Ki);
eeprom_write_word((unsigned int*) 0x0004,Kd); // Read BRAM Parameter from EEPROM
Read_Parameter(); break;
case 5: // Refresh Setup
MaxSpeed = ADCH; // Read BRAM Parameter from EEPROM
case 6: // Exit Setup
mode = 0;
ansi_cl();
return 0; // Standard Return Code
}/* EOF: bramflr.c */ |
