发表于 2010-4-13 11:06:34
Camera Optics
* Lens Type: Fixed Focus (2ft/.6m – ∞), glass
* Aperture: f/2.8 (high performance in low-light situations)
* Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
* Angle of View: 127º wide angle in 1080p mode
Video
* HD Video Resolution Modes: (subject to change, pending final firmware release)
o 1080p = 1920x1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
o 960p = 1280x960 pixels (4:3), 30 fps, 12 Mbit/s data rate
o 720p = 1280x720 pixels (16:9), 60 fps, 15 Mbit/s data rate
o 720p = 1280x720 pixels (16:9), 30 fps, 8 Mbit/s data rate
o WVGA = 848x480 pixels (16:9), 60 fps, 8 Mbit/s data rate
* Sensor Type: 1/2.5" HD CMOS, 2.2µm-sized pixels
* Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
* Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
* Exposure Control: Auto with user selectable center weighted average and spot metering settings
* White Balance: Auto
Audio
* Microphone: Built-in, mono with AGC (automatic gain control)
* Audio Format: 48 kHz, AAC audio compression
* Resolution: 5 megapixel
* Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
* Memory: SD card, up to 32GB capacity (SDHC)
* Average recording times (using 32GB SD card):
o 1080p (30 fps): 4h 21m
o 960p (30 fps): 5h 26m
o 720p (60 fps): 4h 21
o 720p (30 fps): 8h 09m
o WVGA (60 fps): 8h 09m
Size & Weight
* Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
* Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing |
