发表于 2010-4-13 10:22:16
修正了一个bug
rt_hw_context_switch_interrupt //中断时,切换上下文
1 MOV.W rt_thread_switch_interrput_flag, A0
2 CMP.W #1,A0
3 MOV.W R0, rt_interrupt_from_thread
4 JEQ jump
5 MOV.W #1, A0
6 MOV.W A0,rt_thread_switch_interrput_flag
7jump
8 MOV.W R1, rt_interrupt_to_thread
9 RTS
原先的这段汇编代码有点问题,主要是第三行和第四行位置颠倒了
下面上传最新的context.asm,精简了上下文移植代码,修正了上面提到的bug
* File : context.asm
* This file is part of RT-Thread RTOS
* COPYRIGHT (C) 2009, RT-Thread Development Team
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rt-thread.org/license/LICENSE
* Change Logs:
* Date Author Notes
* 2010-04-09 fify the first version
* For : Renesas M16C
* Toolchain : IAR's EW for M16C v3.401
; PUBLIC FUNCTIONS
RSEG CSTACK
RSEG ISTACK
RSEG CODE(1)
EXTERN rt_thread_switch_interrput_flag
EXTERN rt_interrupt_from_thread
EXTERN rt_interrupt_to_thread
EXTERN rt_interrupt_enter
EXTERN rt_tick_increase
EXTERN rt_interrupt_leave
EXTERN u0rec_handler
PUBLIC rt_hw_interrupt_disable
PUBLIC rt_hw_interrupt_enable
PUBLIC rt_hw_context_switch_to
PUBLIC rt_hw_context_switch_interrupt
PUBLIC rt_hw_timer_handler
PUBLIC rt_hw_uart0_receive_handler
FCLR I
RTS
FSET I
RTS
; * void rt_hw_context_switch_to(rt_uint32 to);
; * r0 --> to
; * this fucntion is used to perform the first thread switch
MOV.W R0, A0
LDC [A0], ISP
POPM R0,R1,R2,R3,A0,A1,SB,FB
REIT
PUSHM R0,R1,R2,R3,A0,A1,SB,FB
MOV.W R0, A0
STC ISP, [A0]
MOV.W R1, A0
LDC [A0], ISP
POPM R0,R1,R2,R3,A0,A1,SB,FB ; Restore all processor registers from the new task's stack
REIT
CMP.W #1,rt_thread_switch_interrput_flag
JEQ jump
MOV.W #1,rt_thread_switch_interrput_flag
jump
RTS
rt_hw_context_switch_interrupt_do
MOV.W #0, rt_thread_switch_interrput_flag
MOV.W rt_interrupt_from_thread, A0
STC ISP, [A0]
MOV.W rt_interrupt_to_thread, A0
LDC [A0], ISP
RTS ; Normal return
.EVEN
rt_hw_timer_handler:
PUSHM R0,R1,R2,R3,A0,A1,SB,FB ; Save current task's registers
JSR rt_interrupt_enter
JSR rt_tick_increase
JSR rt_interrupt_leave
JEQ rt_hw_context_switch_interrupt_do
POPM R0,R1,R2,R3,A0,A1,SB,FB ; Restore registers from the new task's stack
REIT ; Return from interrup
.EVEN
rt_hw_uart0_receive_handler:
JSR u0rec_handler
CMP.W #1, rt_thread_switch_interrput_flag
END |
