// UG-2864ASYDT01 (2864-27E)
// UG-2864ASYDT02 (2864-28E)
// UG-2864ASYDT03 (2864-31E)
// UG-2864ASYDT04 (2864-32E)
// UG-2864ASYDT05 (2864-33E)
// UG-2864ALBDT05 (2864-34E) Reference Code
// Dot Matrix: 128*64
// Driver IC : SSD1325 (Solomon Systech)
// Interface : 8-bit 68XX/80XX Parallel, 4-wire SPI
// Revision :
// Date : 2007/11/25
// Author :
// Editor : Humphrey Lin
// Copyright (c) Univision Technology Inc.
#include <at89x51.h>
//#define M68 // 8-bit 68XX Parallel
// BS1=0; BS2=1
#define I80 // 8-bit 80XX Parallel
// BS1=1; BS2=1
//#define SPI // 4-wire SPI
// BS1=0; BS2=0
// The unused pins should be connected with VSS mostly or floating (D2).
// Please refer to the SSD1329 specification for detail.
// Pin Definition
#define xData P1 // Parallel Data Input
#define SCLK P1_0 // Serial Clock Input
#define SDIN P1_1 // Serial Data Input
#define RES P3_3 // Reset
#define CS P3_4 // Chip Select
#define DC P3_2 // Data/Command Control
#define E P3_0 // Read/Write Enable
#define RW P3_1 // Read/Write Select
#define RD P3_0 // Read Signal
#define WR P3_1 // Write Signal
// Delay Time
void uDelay(unsigned char l)
while(l--);
void Delay(unsigned char n)
unsigned char i,j,k;
for(k=0;k<n;k++)
for(i=0;i<131;i++)
for(j=0;j<15;j++)
uDelay(203);
// Read/Write Sequence
#ifdef M68 // 8-bit 68XX Parallel
void Write_Command(unsigned char Data)
DC=0;
CS=0;
RW=0;
E=1;
xData=Data;
E=0;
RW=1;
CS=1;
DC=1;
void Write_Data(unsigned char Data)
DC=1;
CS=0;
RW=0;
E=1;
xData=Data;
E=0;
RW=1;
CS=1;
DC=1;
#ifdef I80
DC=0;
CS=0;
WR=0;
xData=Data;
WR=1;
CS=1;
DC=1;
DC=1;
CS=0;
WR=0;
xData=Data;
WR=1;
CS=1;
DC=1;
#ifdef SPI
unsigned char i;
CS=0;
DC=0;
for (i=0; i<8; i++)
SCLK=0;
SDIN=(Data&0x80)>>7;
Data = Data << 1;
// uDelay(1);
SCLK=1;
// uDelay(1);
// SCLK=0;
DC=1;
CS=1;
unsigned char i;
CS=0;
DC=1;
for (i=0; i<8; i++)
SCLK=0;
Data = Data << 1;
// uDelay(1);
SCLK=1;
// uDelay(1);
// SCLK=0;
DC=1;
CS=1;
// Instruction Setting
void Set_Column_Address(unsigned char a, unsigned char b)
Write_Command(0x15); // Set Column Address
Write_Command(a); // Default => 0x00
Write_Command(b); // Default => 0x3F (Total Columns Devided by 2)
void Set_Row_Address(unsigned char a, unsigned char b)
Write_Command(0x75); // Set Row Address
Write_Command(b); // Default => 0x4F
void Set_Contrast_Current(unsigned char d)
Write_Command(0x81); // Set Contrast Value
Write_Command(d); // Default => 0x40
void Set_Current_Range(unsigned char d)
Write_Command(0x84|d); // Set Current Range
// Default => 0x84
// 0x84 (0x00) => Quarter Current Range
// 0x85 (0x01) => Half Current Range
// 0x86 (0x02) => Full Current Range
void Set_Remap_Format(unsigned char d)
Write_Command(0xA0); // Set Re-Map & Data Format
Write_Command(d); // Default => 0x00
// Column Address 0 Mapped to SEG0
// Disable Nibble Re-Map
// Horizontal Address Increment
// Scan from COM0 to COM[N-1]
// Disable COM Split Odd Even
void Set_Start_Line(unsigned char d)
Write_Command(0xA1); // Set Display Start Line
void Set_Display_Offset(unsigned char d)
Write_Command(0xA2); // Set Display Offset
void Set_Display_Mode(unsigned char d)
Write_Command(0xA4|d); // Set Display Mode
// Default => 0xA4
// 0xA4 (0x00) => Normal Display
// 0xA5 (0x01) => Entire Display On, All Pixels Turn On at GS Level 15
// 0xA6 (0x02) => Entire Display Off, All Pixels Turn Off
// 0xA7 (0x03) => Inverse Display
void Set_Multiplex_Ratio(unsigned char d)
Write_Command(0xA8); // Set Multiplex Ratio
Write_Command(d); // Default => 0x5F
void Set_Master_Config(unsigned char d)
Write_Command(0xAD); // Set Master Configuration
Write_Command(0x02|d); // Default => 0x03
// 0x02 (0x00) => Select External VCC Supply
// 0x03 (0x01) => Select Internal DC/DC Voltage Converter
void Set_Display_On_Off(unsigned char d)
Write_Command(0xAE|d); // Set Display On/Off
// Default => 0xAE
// 0xAE (0x00) => Display Off
// 0xAF (0x01) => Display On
void Set_Phase_Length(unsigned char d)
Write_Command(0xB1); // Phase 1 & 2 Period Adjustment
Write_Command(d); // Default => 0x53 (5 Display Clocks [Phase 2] / 3 Display Clocks [Phase 1])
// D[3:0] => Phase 1 Period in 1~15 Display Clocks
// D[7:4] => Phase 2 Period in 1~15 Display Clocks
void Set_Frame_Frequency(unsigned char d)
Write_Command(0xB2); // Set Frame Frequency (Row Period)
Write_Command(d); // Default => 0x25 (37 Display Clocks)
void Set_Display_Clock(unsigned char d)
Write_Command(0xB3); // Display Clock Divider/Osciallator Frequency
Write_Command(d); // Default => 0x41
// D[3:0] => Display Clock Divider
// D[7:4] => Oscillator Frequency
void Set_Precharge_Compensation(unsigned char a, unsigned char b)
Write_Command(0xB4); // Set Pre-Charge Compensation Level
Write_Command(b); // Default => 0x00 (No Compensation)
if(a == 0x20)
Write_Command(0xB0); // Set Pre-Charge Compensation Enable
Write_Command(0x08|a); // Default => 0x08
// 0x08 (0x00) => Disable Pre-Charge Compensation
// 0x28 (0x20) => Enable Pre-Charge Compensation
void Set_Precharge_Voltage(unsigned char d)
Write_Command(0xBC); // Set Pre-Charge Voltage Level
Write_Command(d); // Default => 0x10 (Connect to VCOMH)
void Set_VCOMH(unsigned char d)
Write_Command(0xBE); // Set Output Level High Voltage for COM Signal
Write_Command(d); // Default => 0x1D (0.81*VREF)
void Set_VSL(unsigned char d)
Write_Command(0xBF); // Set Segment Low Voltage Level
Write_Command(0x02|d); // Default => 0x0E
// 0x02 (0x00) => Keep VSL Pin Floating
// 0x0E (0x0C) => Connect a Capacitor between VSL Pin & VSS
void Set_NOP()
Write_Command(0xE3); // Command for No Operation
// Global Variables
#define Max_Column 0x3F // 128/2-1 (Total Columns Devided by 2)
#define Max_Row 0x3F // 64-1
#define Brightness 0x7F
// Patterns
unsigned char code Logo[][64]={ // Univision Logo
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X21,0X32,0X33,0X12,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X20,0X62,0X56,0X64,0X66,0X63,0X56,0X22,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X41,0X56,0X63,0X56,0X72,0X56,0X62,0X66,0X64,0X25,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X40,0X66,0X66,0X66,0X66,0X67,0X66,0X66,0X66,0X66,0X66,0X25,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X66,0X63,0X56,0X62,0X46,0X61,0X46,0X61,0X66,0X65,0X56,0X66,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X63,0X66,0X64,0X56,0X63,0X46,0X61,0X46,0X61,0X66,0X65,0X56,0X66,0X56,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X30,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X05,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X62,0X67,0X66,0X64,0X56,0X63,0X46,0X62,0X47,0X52,0X66,0X65,0X66,0X66,0X66,0X56,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X66,0X26,0X67,0X40,0X36,0X40,0X17,0X40,0X16,0X30,0X46,0X70,0X26,0X64,0X15,0X66,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X50,0X66,0X66,0X66,0X65,0X66,0X64,0X46,0X63,0X56,0X63,0X66,0X65,0X66,0X66,0X66,0X66,0X36,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X64,0X66,0X66,0X66,0X66,0X66,0X66,0X56,0X63,0X57,0X63,0X66,0X66,0X66,0X66,0X66,0X66,0X76,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X10,0X46,0X66,0X35,0X56,0X31,0X26,0X40,0X06,0X20,0X06,0X20,0X26,0X50,0X16,0X63,0X25,0X66,0X64,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X40,0X56,0X66,0X46,0X67,0X41,0X36,0X40,0X06,0X20,0X06,0X20,0X36,0X60,0X38,0X85,0X25,0X66,0X64,0X16,0X32,0X33,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X60,0X66,0X66,0X66,0X66,0X67,0X66,0X65,0X56,0X63,0X56,0X63,0X66,0X76,0XDB,0XCD,0X67,0X66,0X66,0X56,0XD9,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X63,0X66,0X66,0X66,0X66,0X54,0X37,0X50,0X06,0X20,0X06,0X20,0X26,0X61,0XDB,0XCD,0X56,0X66,0X66,0X66,0XDA,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X43,0X36,0X65,0X14,0X46,0X20,0X06,0X20,0X03,0X10,0X03,0X00,0X05,0X20,0XDB,0XCD,0X03,0X65,0X41,0X16,0XDA,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X22,0X02,0X00,0X00,0X00,0X00,0X00,0X10,0X22,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X33,0X02,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X22,0X10,0X66,0X76,0X66,0X66,0X66,0X53,0X36,0X40,0X05,0X20,0X06,0X10,0X26,0X50,0XDB,0XCD,0X46,0X66,0X66,0X66,0XDB,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X40,0XBB,0X08,0X00,0X00,0X00,0X00,0X00,0X60,0XCC,0X05,0X00,0X00,0X00,0X00,0X00,0X20,0XDC,0X0A,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X52,0X02,0X20,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X64,0X36,0X51,0X36,0X41,0X56,0X64,0XDB,0XCD,0X67,0X66,0X66,0X66,0XDB,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X40,0XBB,0X08,0X00,0X00,0X00,0X00,0X00,0X60,0XCC,0X05,0X00,0X00,0X00,0X00,0X00,0X20,0XDC,0X0A,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X40,0X1B,0X00,0X30,0X67,0X56,0X66,0X24,0X46,0X20,0X06,0X10,0X03,0X10,0X03,0X00,0X04,0X20,0XDB,0XCD,0X15,0X66,0X65,0X66,0XDB,0XDD,0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X22,0X01,0X00,0X00,0X00,0X00,0X00,0X10,0X22,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X22,0X02,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0XB5,0X02,0X00,0X40,0X43,0X16,0X62,0X00,0X24,0X00,0X03,0X10,0X00,0X00,0X00,0X00,0X01,0X10,0XDB,0XCD,0X02,0X63,0X20,0X16,0XDA,0XDD,0X50,0X77,0X53,0X99,0X89,0X05,0X20,0X77,0X56,0X77,0X06,0X00,0X40,0X77,0X37,0X77,0X03,0X62,0X98,0X99,0X99,0X37,0X10,0X76,0X06,0X40,0X97,0X99,0X99,0X68,0X01,0X73,0X27,0X84,0X99,0X69,0X01,
0X30,0X6D,0X00,0X00,0X40,0X67,0X56,0X66,0X25,0X46,0X20,0X06,0X20,0X03,0X10,0X03,0X00,0X04,0X20,0XDB,0XCD,0X25,0X66,0X65,0X76,0XDB,0XDD,0X90,0XDD,0XDA,0XDD,0XDD,0X8D,0X50,0XDD,0X5B,0XDD,0X2C,0X00,0XA0,0XDD,0X67,0XDD,0X16,0XDC,0XDD,0XDD,0XDD,0XCD,0X22,0XDC,0X0A,0XD6,0XDD,0XDD,0XDD,0XDD,0X0A,0XD5,0X8D,0XDD,0XDD,0XDD,0X0A,
0XA1,0X3C,0X00,0X00,0X40,0X66,0X66,0X66,0X66,0X66,0X66,0X56,0X63,0X26,0X41,0X26,0X40,0X56,0X74,0XDB,0XCD,0X67,0X66,0X66,0X66,0XDB,0XDD,0X90,0XDD,0XAD,0X88,0XDA,0XDD,0X52,0XDD,0X0B,0XDC,0X5D,0X00,0XD2,0XCD,0X61,0XDD,0X46,0XDD,0X5B,0X44,0XA5,0XAA,0X22,0XDC,0X0A,0XDA,0XCD,0X89,0XA8,0XDD,0X2D,0XD5,0XDD,0X8B,0XA8,0XDD,0X3D,
0XD3,0X2C,0X00,0X00,0X40,0X66,0X56,0X66,0X24,0X46,0X20,0X06,0X20,0X03,0X10,0X03,0X00,0X04,0X20,0XDB,0XCD,0X26,0X66,0X65,0X76,0XDB,0XDD,0X90,0XDD,0X09,0X00,0XA0,0XDD,0X54,0XDD,0X0B,0XD5,0XAD,0X00,0XD9,0X8D,0X60,0XDD,0X46,0XDD,0X6C,0X55,0X44,0X03,0X20,0XDC,0X0A,0XDB,0X2D,0X00,0X00,0XD9,0X4D,0XD5,0XCD,0X00,0X00,0XD8,0X5D,
0XD5,0X3C,0X00,0X00,0X40,0X43,0X16,0X62,0X00,0X24,0X00,0X04,0X00,0X00,0X00,0X00,0X00,0X01,0X00,0XDA,0XDD,0X04,0X63,0X20,0X36,0XDC,0XCD,0X90,0XDD,0X07,0X00,0XA0,0XDD,0X55,0XDD,0X0B,0XB0,0XDD,0X22,0XDD,0X3D,0X60,0XDD,0X26,0XDC,0XDD,0XDD,0XDD,0XCD,0X23,0XDC,0X1A,0XDB,0X0C,0X00,0X00,0XD7,0X5D,0XD5,0X8D,0X00,0X00,0XD6,0X6D,
0XD5,0X6D,0X00,0X00,0X30,0X66,0X56,0X66,0X24,0X46,0X20,0X06,0X20,0X03,0X10,0X03,0X00,0X04,0X20,0XDB,0XDD,0XBD,0XBB,0XA9,0XDC,0XDD,0XBD,0X90,0XDD,0X06,0X00,0X90,0XDD,0X55,0XDD,0X0B,0X70,0XDD,0X69,0XDD,0X0B,0X60,0XDD,0X06,0XA3,0XDD,0XDD,0XDD,0XDD,0X28,0XDC,0X0A,0XDB,0X0C,0X00,0X00,0XD8,0X5D,0XD5,0X7D,0X00,0X00,0XD6,0X6D,
0XC3,0XCD,0X02,0X00,0X20,0X66,0X66,0X66,0X66,0X66,0X66,0X66,0X64,0X36,0X51,0X36,0X41,0X56,0X64,0XDA,0XDD,0XDD,0XDD,0XDD,0XDD,0XDD,0X7D,0X90,0XDD,0X06,0X00,0X90,0XDD,0X55,0XDD,0X0B,0X20,0XDD,0XBD,0XDD,0X03,0X60,0XDD,0X26,0X77,0X06,0X00,0X50,0XDD,0X29,0XDC,0X0A,0XDA,0X6D,0X22,0X32,0XDB,0X3D,0XD5,0X7D,0X00,0X00,0XD6,0X6D,
0XA0,0XDD,0X1B,0X00,0X10,0X67,0X66,0X66,0X66,0X66,0X52,0X27,0X40,0X05,0X20,0X05,0X10,0X26,0X50,0XD7,0XDD,0XDD,0XDD,0XDD,0XDD,0XDD,0X1C,0X90,0XDD,0X06,0X00,0X90,0XDD,0X55,0XDD,0X0B,0X00,0XD9,0XDD,0XAD,0X00,0X60,0XDD,0X46,0XDD,0XBD,0X99,0XCA,0XDD,0X27,0XDC,0X0A,0XD9,0XDD,0XCC,0XDC,0XDD,0X1D,0XD5,0X7D,0X00,0X00,0XD6,0X6D,
0X20,0XDB,0XAD,0X03,0X00,0X43,0X36,0X65,0X14,0X46,0X20,0X07,0X20,0X03,0X10,0X03,0X00,0X05,0X20,0X44,0XDB,0XDD,0XDD,0XDD,0XDD,0XBD,0X05,0X90,0XDD,0X06,0X00,0X90,0XDD,0X55,0XDD,0X0B,0X00,0XC2,0XDD,0X5D,0X00,0X60,0XDD,0X06,0XD8,0XDD,0XDD,0XDD,0XAD,0X22,0XDC,0X0A,0XB3,0XDD,0XDD,0XDD,0XCD,0X06,0XD5,0X7D,0X00,0X00,0XD6,0X6D,
0X00,0XB2,0XDD,0X6C,0X00,0X62,0X66,0X66,0X66,0X66,0X54,0X36,0X51,0X06,0X20,0X06,0X20,0X26,0X51,0X36,0X75,0X98,0X99,0X99,0X89,0X02,0X00,0X10,0X11,0X00,0X00,0X10,0X11,0X00,0X11,0X01,0X00,0X10,0X11,0X01,0X00,0X00,0X11,0X00,0X10,0X54,0X75,0X35,0X01,0X00,0X11,0X01,0X00,0X42,0X55,0X55,0X13,0X00,0X10,0X01,0X00,0X00,0X10,0X01,
0X00,0X20,0XD9,0XDD,0X4A,0X61,0X66,0X66,0X66,0X66,0X66,0X66,0X65,0X46,0X63,0X56,0X63,0X66,0X66,0X66,0X66,0X66,0X76,0X67,0X56,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X32,0X02,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X40,0XDC,0XDD,0X9C,0X57,0X66,0X46,0X66,0X41,0X36,0X40,0X06,0X20,0X06,0X20,0X36,0X61,0X16,0X63,0X25,0X66,0X65,0X16,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X20,0X67,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X60,0XCA,0XDD,0X8C,0X78,0X36,0X56,0X31,0X26,0X40,0X06,0X20,0X06,0X20,0X26,0X50,0X16,0X63,0X25,0X66,0X64,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X20,0X53,0X56,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X20,0XC8,0XDD,0XCD,0X9C,0X67,0X66,0X66,0X66,0X56,0X63,0X56,0X64,0X66,0X66,0X66,0X66,0X66,0X66,0X76,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X83,0X7B,0X13,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X10,0XA5,0XDC,0XDD,0XCD,0X9A,0X78,0X65,0X46,0X63,0X56,0X63,0X66,0X65,0X66,0X66,0X66,0X66,0X36,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X32,0X75,0X99,0X47,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X87,0X99,0XDD,0XDD,0XCD,0XBB,0X5A,0X42,0X17,0X30,0X46,0X71,0X26,0X64,0X15,0X66,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X42,0X97,0XBB,0X8A,0X25,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X62,0X66,0X87,0XA9,0XCB,0XDC,0XDD,0XDD,0XBC,0X99,0X9A,0X87,0X78,0X87,0X77,0X77,0X12,0X11,0X11,0X21,0X22,0X32,0X33,0X54,0X86,0XA9,0XBB,0X9A,0X68,0X13,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X30,0X67,0X66,0X66,0X76,0X87,0X98,0XBA,0XCC,0XDD,0XDD,0XDD,0XDD,0XCC,0XCC,0XCC,0XBB,0XBB,0XCB,0XCC,0XCC,0XCC,0XCD,0X9B,0X67,0X24,0X11,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X62,0X66,0X64,0X56,0X63,0X46,0X61,0X46,0X71,0X77,0X97,0X89,0XA9,0X9A,0X77,0X77,0X67,0X56,0X45,0X23,0X12,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X10,0X66,0X64,0X56,0X62,0X46,0X61,0X46,0X61,0X66,0X65,0X56,0X76,0X03,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X41,0X56,0X63,0X56,0X73,0X56,0X62,0X66,0X63,0X25,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X20,0X62,0X56,0X64,0X66,0X64,0X56,0X22,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
unsigned char code Ascii_1[241][5]={ // Refer to "Times New Roman" Font Database...
// Basic Characters
{0x00,0x00,0x00,0x00,0x00}, //
{0x00,0x00,0x4F,0x00,0x00}, // ( 1) ! - 0x0021 Exclamation Mark
{0x00,0x07,0x00,0x07,0x00}, // ( 2) " - 0x0022 Quotation Mark
{0x14,0x7F,0x14,0x7F,0x14}, // ( 3) # - 0x0023 Number Sign
{0x24,0x2A,0x7F,0x2A,0x12}, // ( 4) $ - 0x0024 Dollar Sign
{0x23,0x13,0x08,0x64,0x62}, // ( 5) % - 0x0025 Percent Sign
{0x36,0x49,0x55,0x22,0x50}, // ( 6) & - 0x0026 Ampersand
{0x00,0x05,0x03,0x00,0x00}, // ( 7) ' - 0x0027 Apostrophe
{0x00,0x1C,0x22,0x41,0x00}, // ( 8) ( - 0x0028 Left Parenthesis
{0x00,0x41,0x22,0x1C,0x00}, // ( 9) ) - 0x0029 Right Parenthesis
{0x14,0x08,0x3E,0x08,0x14}, // ( 10) * - 0x002A Asterisk
{0x08,0x08,0x3E,0x08,0x08}, // ( 11) + - 0x002B Plus Sign
{0x00,0x50,0x30,0x00,0x00}, // ( 12) , - 0x002C Comma
{0x08,0x08,0x08,0x08,0x08}, // ( 13) - - 0x002D Hyphen-Minus
{0x00,0x60,0x60,0x00,0x00}, // ( 14) . - 0x002E Full Stop
{0x20,0x10,0x08,0x04,0x02}, // ( 15) / - 0x002F Solidus
{0x3E,0x51,0x49,0x45,0x3E}, // ( 16) 0 - 0x0030 Digit Zero
{0x00,0x42,0x7F,0x40,0x00}, // ( 17) 1 - 0x0031 Digit One
{0x42,0x61,0x51,0x49,0x46}, // ( 18) 2 - 0x0032 Digit Two
{0x21,0x41,0x45,0x4B,0x31}, // ( 19) 3 - 0x0033 Digit Three
{0x18,0x14,0x12,0x7F,0x10}, // ( 20) 4 - 0x0034 Digit Four
{0x27,0x45,0x45,0x45,0x39}, // ( 21) 5 - 0x0035 Digit Five
{0x3C,0x4A,0x49,0x49,0x30}, // ( 22) 6 - 0x0036 Digit Six
{0x01,0x71,0x09,0x05,0x03}, // ( 23) 7 - 0x0037 Digit Seven
{0x36,0x49,0x49,0x49,0x36}, // ( 24) 8 - 0x0038 Digit Eight
{0x06,0x49,0x49,0x29,0x1E}, // ( 25) 9 - 0x0039 Dight Nine
{0x00,0x36,0x36,0x00,0x00}, // ( 26) : - 0x003A Colon
{0x00,0x56,0x36,0x00,0x00}, // ( 27) ; - 0x003B Semicolon
{0x08,0x14,0x22,0x41,0x00}, // ( 28) < - 0x003C Less-Than Sign
{0x14,0x14,0x14,0x14,0x14}, // ( 29) = - 0x003D Equals Sign
{0x00,0x41,0x22,0x14,0x08}, // ( 30) > - 0x003E Greater-Than Sign
{0x02,0x01,0x51,0x09,0x06}, // ( 31) ? - 0x003F Question Mark
{0x32,0x49,0x79,0x41,0x3E}, // ( 32) @ - 0x0040 Commercial At
{0x7E,0x11,0x11,0x11,0x7E}, // ( 33) A - 0x0041 Latin Capital Letter A
{0x7F,0x49,0x49,0x49,0x36}, // ( 34) B - 0x0042 Latin Capital Letter B
{0x3E,0x41,0x41,0x41,0x22}, // ( 35) C - 0x0043 Latin Capital Letter C
{0x7F,0x41,0x41,0x22,0x1C}, // ( 36) D - 0x0044 Latin Capital Letter D
{0x7F,0x49,0x49,0x49,0x41}, // ( 37) E - 0x0045 Latin Capital Letter E
{0x7F,0x09,0x09,0x09,0x01}, // ( 38) F - 0x0046 Latin Capital Letter F
{0x3E,0x41,0x49,0x49,0x7A}, // ( 39) G - 0x0047 Latin Capital Letter G
{0x7F,0x08,0x08,0x08,0x7F}, // ( 40) H - 0x0048 Latin Capital Letter H
{0x00,0x41,0x7F,0x41,0x00}, // ( 41) I - 0x0049 Latin Capital Letter I
{0x20,0x40,0x41,0x3F,0x01}, // ( 42) J - 0x004A Latin Capital Letter J
{0x7F,0x08,0x14,0x22,0x41}, // ( 43) K - 0x004B Latin Capital Letter K
{0x7F,0x40,0x40,0x40,0x40}, // ( 44) L - 0x004C Latin Capital Letter L
{0x7F,0x02,0x0C,0x02,0x7F}, // ( 45) M - 0x004D Latin Capital Letter M
{0x7F,0x04,0x08,0x10,0x7F}, // ( 46) N - 0x004E Latin Capital Letter N
{0x3E,0x41,0x41,0x41,0x3E}, // ( 47) O - 0x004F Latin Capital Letter O
{0x7F,0x09,0x09,0x09,0x06}, // ( 48) P - 0x0050 Latin Capital Letter P
{0x3E,0x41,0x51,0x21,0x5E}, // ( 49) Q - 0x0051 Latin Capital Letter Q
{0x7F,0x09,0x19,0x29,0x46}, // ( 50) R - 0x0052 Latin Capital Letter R
{0x46,0x49,0x49,0x49,0x31}, // ( 51) S - 0x0053 Latin Capital Letter S
{0x01,0x01,0x7F,0x01,0x01}, // ( 52) T - 0x0054 Latin Capital Letter T
{0x3F,0x40,0x40,0x40,0x3F}, // ( 53) U - 0x0055 Latin Capital Letter U
{0x1F,0x20,0x40,0x20,0x1F}, // ( 54) V - 0x0056 Latin Capital Letter V
{0x3F,0x40,0x38,0x40,0x3F}, // ( 55) W - 0x0057 Latin Capital Letter W
{0x63,0x14,0x08,0x14,0x63}, // ( 56) X - 0x0058 Latin Capital Letter X
{0x07,0x08,0x70,0x08,0x07}, // ( 57) Y - 0x0059 Latin Capital Letter Y
{0x61,0x51,0x49,0x45,0x43}, // ( 58) Z - 0x005A Latin Capital Letter Z
{0x00,0x7F,0x41,0x41,0x00}, // ( 59) [ - 0x005B Left Square Bracket
{0x02,0x04,0x08,0x10,0x20}, // ( 60) \ - 0x005C Reverse Solidus
{0x00,0x41,0x41,0x7F,0x00}, // ( 61) ] - 0x005D Right Square Bracket
{0x04,0x02,0x01,0x02,0x04}, // ( 62) ^ - 0x005E Circumflex Accent
{0x40,0x40,0x40,0x40,0x40}, // ( 63) _ - 0x005F Low Line
{0x01,0x02,0x04,0x00,0x00}, // ( 64) ` - 0x0060 Grave Accent
{0x20,0x54,0x54,0x54,0x78}, // ( 65) a - 0x0061 Latin Small Letter A
{0x7F,0x48,0x44,0x44,0x38}, // ( 66) b - 0x0062 Latin Small Letter B
{0x38,0x44,0x44,0x44,0x20}, // ( 67) c - 0x0063 Latin Small Letter C
{0x38,0x44,0x44,0x48,0x7F}, // ( 68) d - 0x0064 Latin Small Letter D
{0x38,0x54,0x54,0x54,0x18}, // ( 69) e - 0x0065 Latin Small Letter E
{0x08,0x7E,0x09,0x01,0x02}, // ( 70) f - 0x0066 Latin Small Letter F
{0x06,0x49,0x49,0x49,0x3F}, // ( 71) g - 0x0067 Latin Small Letter G
{0x7F,0x08,0x04,0x04,0x78}, // ( 72) h - 0x0068 Latin Small Letter H
{0x00,0x44,0x7D,0x40,0x00}, // ( 73) i - 0x0069 Latin Small Letter I
{0x20,0x40,0x44,0x3D,0x00}, // ( 74) j - 0x006A Latin Small Letter J
{0x7F,0x10,0x28,0x44,0x00}, // ( 75) k - 0x006B Latin Small Letter K
{0x00,0x41,0x7F,0x40,0x00}, // ( 76) l - 0x006C Latin Small Letter L
{0x7C,0x04,0x18,0x04,0x7C}, // ( 77) m - 0x006D Latin Small Letter M
{0x7C,0x08,0x04,0x04,0x78}, // ( 78) n - 0x006E Latin Small Letter N
{0x38,0x44,0x44,0x44,0x38}, // ( 79) o - 0x006F Latin Small Letter O
{0x7C,0x14,0x14,0x14,0x08}, // ( 80) p - 0x0070 Latin Small Letter P
{0x08,0x14,0x14,0x18,0x7C}, // ( 81) q - 0x0071 Latin Small Letter Q
{0x7C,0x08,0x04,0x04,0x08}, // ( 82) r - 0x0072 Latin Small Letter R
{0x48,0x54,0x54,0x54,0x20}, // ( 83) s - 0x0073 Latin Small Letter S
{0x04,0x3F,0x44,0x40,0x20}, // ( 84) t - 0x0074 Latin Small Letter T
{0x3C,0x40,0x40,0x20,0x7C}, // ( 85) u - 0x0075 Latin Small Letter U
{0x1C,0x20,0x40,0x20,0x1C}, // ( 86) v - 0x0076 Latin Small Letter V
{0x3C,0x40,0x30,0x40,0x3C}, // ( 87) w - 0x0077 Latin Small Letter W
{0x44,0x28,0x10,0x28,0x44}, // ( 88) x - 0x0078 Latin Small Letter X
{0x0C,0x50,0x50,0x50,0x3C}, // ( 89) y - 0x0079 Latin Small Letter Y
{0x44,0x64,0x54,0x4C,0x44}, // ( 90) z - 0x007A Latin Small Letter Z
{0x00,0x08,0x36,0x41,0x00}, // ( 91) { - 0x007B Left Curly Bracket
{0x00,0x00,0x7F,0x00,0x00}, // ( 92) | - 0x007C Vertical Line
{0x00,0x41,0x36,0x08,0x00}, // ( 93) } - 0x007D Right Curly Bracket
{0x02,0x01,0x02,0x04,0x02}, // ( 94) ~ - 0x007E Tilde
{0x3E,0x55,0x55,0x41,0x22}, // ( 95) C - 0x0080 <Control>
{0x00,0x00,0x00,0x00,0x00}, // ( 96) - 0x00A0 No-Break Space
{0x00,0x00,0x79,0x00,0x00}, // ( 97) ! - 0x00A1 Inverted Exclamation Mark
{0x18,0x24,0x74,0x2E,0x24}, // ( 98) c - 0x00A2 Cent Sign
{0x48,0x7E,0x49,0x42,0x40}, // ( 99) L - 0x00A3 Pound Sign
{0x5D,0x22,0x22,0x22,0x5D}, // (100) o - 0x00A4 Currency Sign
{0x15,0x16,0x7C,0x16,0x15}, // (101) Y - 0x00A5 Yen Sign
{0x00,0x00,0x77,0x00,0x00}, // (102) | - 0x00A6 Broken Bar
{0x0A,0x55,0x55,0x55,0x28}, // (103) - 0x00A7 Section Sign
{0x00,0x01,0x00,0x01,0x00}, // (104) " - 0x00A8 Diaeresis
{0x00,0x0A,0x0D,0x0A,0x04}, // (105) - 0x00AA Feminine Ordinal Indicator
{0x08,0x14,0x2A,0x14,0x22}, // (106) << - 0x00AB Left-Pointing Double Angle Quotation Mark
{0x04,0x04,0x04,0x04,0x1C}, // (107) - 0x00AC Not Sign
{0x00,0x08,0x08,0x08,0x00}, // (108) - - 0x00AD Soft Hyphen
{0x01,0x01,0x01,0x01,0x01}, // (109) - 0x00AF Macron
{0x00,0x02,0x05,0x02,0x00}, // (110) - 0x00B0 Degree Sign
{0x44,0x44,0x5F,0x44,0x44}, // (111) +- - 0x00B1 Plus-Minus Sign
{0x00,0x00,0x04,0x02,0x01}, // (112) ` - 0x00B4 Acute Accent
{0x7E,0x20,0x20,0x10,0x3E}, // (113) u - 0x00B5 Micro Sign
{0x06,0x0F,0x7F,0x00,0x7F}, // (114) - 0x00B6 Pilcrow Sign
{0x00,0x18,0x18,0x00,0x00}, // (115) . - 0x00B7 Middle Dot
{0x00,0x40,0x50,0x20,0x00}, // (116) - 0x00B8 Cedilla
{0x00,0x0A,0x0D,0x0A,0x00}, // (117) - 0x00BA Masculine Ordinal Indicator
{0x22,0x14,0x2A,0x14,0x08}, // (118) >> - 0x00BB Right-Pointing Double Angle Quotation Mark
{0x17,0x08,0x34,0x2A,0x7D}, // (119) /4 - 0x00BC Vulgar Fraction One Quarter
{0x17,0x08,0x04,0x6A,0x59}, // (120) /2 - 0x00BD Vulgar Fraction One Half
{0x30,0x48,0x45,0x40,0x20}, // (121) ? - 0x00BF Inverted Question Mark
{0x70,0x29,0x26,0x28,0x70}, // (122) `A - 0x00C0 Latin Capital Letter A with Grave
{0x70,0x28,0x26,0x29,0x70}, // (123) 'A - 0x00C1 Latin Capital Letter A with Acute
{0x70,0x2A,0x25,0x2A,0x70}, // (124) ^A - 0x00C2 Latin Capital Letter A with Circumflex
{0x72,0x29,0x26,0x29,0x70}, // (125) ~A - 0x00C3 Latin Capital Letter A with Tilde
{0x70,0x29,0x24,0x29,0x70}, // (126) "A - 0x00C4 Latin Capital Letter A with Diaeresis
{0x70,0x2A,0x2D,0x2A,0x70}, // (127) A - 0x00C5 Latin Capital Letter A with Ring Above
{0x7E,0x11,0x7F,0x49,0x49}, // (128) AE - 0x00C6 Latin Capital Letter Ae
{0x0E,0x51,0x51,0x71,0x11}, // (129) C - 0x00C7 Latin Capital Letter C with Cedilla
{0x7C,0x55,0x56,0x54,0x44}, // (130) `E - 0x00C8 Latin Capital Letter E with Grave
{0x7C,0x55,0x56,0x54,0x44}, // (131) 'E - 0x00C9 Latin Capital Letter E with Acute
{0x7C,0x56,0x55,0x56,0x44}, // (132) ^E - 0x00CA Latin Capital Letter E with Circumflex
{0x7C,0x55,0x54,0x55,0x44}, // (133) "E - 0x00CB Latin Capital Letter E with Diaeresis
{0x00,0x45,0x7E,0x44,0x00}, // (134) `I - 0x00CC Latin Capital Letter I with Grave
{0x00,0x44,0x7E,0x45,0x00}, // (135) 'I - 0x00CD Latin Capital Letter I with Acute
{0x00,0x46,0x7D,0x46,0x00}, // (136) ^I - 0x00CE Latin Capital Letter I with Circumflex
{0x00,0x45,0x7C,0x45,0x00}, // (137) "I - 0x00CF Latin Capital Letter I with Diaeresis
{0x7F,0x49,0x49,0x41,0x3E}, // (138) D - 0x00D0 Latin Capital Letter Eth
{0x7C,0x0A,0x11,0x22,0x7D}, // (139) ~N - 0x00D1 Latin Capital Letter N with Tilde
{0x38,0x45,0x46,0x44,0x38}, // (140) `O - 0x00D2 Latin Capital Letter O with Grave
{0x38,0x44,0x46,0x45,0x38}, // (141) 'O - 0x00D3 Latin Capital Letter O with Acute
{0x38,0x46,0x45,0x46,0x38}, // (142) ^O - 0x00D4 Latin Capital Letter O with Circumflex
{0x38,0x46,0x45,0x46,0x39}, // (143) ~O - 0x00D5 Latin Capital Letter O with Tilde
{0x38,0x45,0x44,0x45,0x38}, // (144) "O - 0x00D6 Latin Capital Letter O with Diaeresis
{0x22,0x14,0x08,0x14,0x22}, // (145) x - 0x00D7 Multiplcation Sign
{0x2E,0x51,0x49,0x45,0x3A}, // (146) O - 0x00D8 Latin Capital Letter O with Stroke
{0x3C,0x41,0x42,0x40,0x3C}, // (147) `U - 0x00D9 Latin Capital Letter U with Grave
{0x3C,0x40,0x42,0x41,0x3C}, // (148) 'U - 0x00DA Latin Capital Letter U with Acute
{0x3C,0x42,0x41,0x42,0x3C}, // (149) ^U - 0x00DB Latin Capital Letter U with Circumflex
{0x3C,0x41,0x40,0x41,0x3C}, // (150) "U - 0x00DC Latin Capital Letter U with Diaeresis
{0x0C,0x10,0x62,0x11,0x0C}, // (151) `Y - 0x00DD Latin Capital Letter Y with Acute
{0x7F,0x12,0x12,0x12,0x0C}, // (152) P - 0x00DE Latin Capital Letter Thom
{0x40,0x3E,0x01,0x49,0x36}, // (153) B - 0x00DF Latin Capital Letter Sharp S
{0x20,0x55,0x56,0x54,0x78}, // (154) `a - 0x00E0 Latin Small Letter A with Grave
{0x20,0x54,0x56,0x55,0x78}, // (155) 'a - 0x00E1 Latin Small Letter A with Acute
{0x20,0x56,0x55,0x56,0x78}, // (156) ^a - 0x00E2 Latin Small Letter A with Circumflex
{0x20,0x55,0x56,0x55,0x78}, // (157) ~a - 0x00E3 Latin Small Letter A with Tilde
{0x20,0x55,0x54,0x55,0x78}, // (158) "a - 0x00E4 Latin Small Letter A with Diaeresis
{0x20,0x56,0x57,0x56,0x78}, // (159) a - 0x00E5 Latin Small Letter A with Ring Above
{0x24,0x54,0x78,0x54,0x58}, // (160) ae - 0x00E6 Latin Small Letter Ae
{0x0C,0x52,0x52,0x72,0x13}, // (161) c - 0x00E7 Latin Small Letter c with Cedilla
{0x38,0x55,0x56,0x54,0x18}, // (162) `e - 0x00E8 Latin Small Letter E with Grave
{0x38,0x54,0x56,0x55,0x18}, // (163) 'e - 0x00E9 Latin Small Letter E with Acute
{0x38,0x56,0x55,0x56,0x18}, // (164) ^e - 0x00EA Latin Small Letter E with Circumflex
{0x38,0x55,0x54,0x55,0x18}, // (165) "e - 0x00EB Latin Small Letter E with Diaeresis
{0x00,0x49,0x7A,0x40,0x00}, // (166) `i - 0x00EC Latin Small Letter I with Grave
{0x00,0x48,0x7A,0x41,0x00}, // (167) 'i - 0x00ED Latin Small Letter I with Acute
{0x00,0x4A,0x79,0x42,0x00}, // (168) ^i - 0x00EE Latin Small Letter I with Circumflex
{0x00,0x4A,0x78,0x42,0x00}, // (169) "i - 0x00EF Latin Small Letter I with Diaeresis
{0x31,0x4A,0x4E,0x4A,0x30}, // (170) - 0x00F0 Latin Small Letter Eth
{0x7A,0x11,0x0A,0x09,0x70}, // (171) ~n - 0x00F1 Latin Small Letter N with Tilde
{0x30,0x49,0x4A,0x48,0x30}, // (172) `o - 0x00F2 Latin Small Letter O with Grave
{0x30,0x48,0x4A,0x49,0x30}, // (173) 'o - 0x00F3 Latin Small Letter O with Acute
{0x30,0x4A,0x49,0x4A,0x30}, // (174) ^o - 0x00F4 Latin Small Letter O with Circumflex
{0x30,0x4A,0x49,0x4A,0x31}, // (175) ~o - 0x00F5 Latin Small Letter O with Tilde
{0x30,0x4A,0x48,0x4A,0x30}, // (176) "o - 0x00F6 Latin Small Letter O with Diaeresis
{0x08,0x08,0x2A,0x08,0x08}, // (177) + - 0x00F7 Division Sign
{0x38,0x64,0x54,0x4C,0x38}, // (178) o - 0x00F8 Latin Small Letter O with Stroke
{0x38,0x41,0x42,0x20,0x78}, // (179) `u - 0x00F9 Latin Small Letter U with Grave
{0x38,0x40,0x42,0x21,0x78}, // (180) 'u - 0x00FA Latin Small Letter U with Acute
{0x38,0x42,0x41,0x22,0x78}, // (181) ^u - 0x00FB Latin Small Letter U with Circumflex
{0x38,0x42,0x40,0x22,0x78}, // (182) "u - 0x00FC Latin Small Letter U with Diaeresis
{0x0C,0x50,0x52,0x51,0x3C}, // (183) 'y - 0x00FD Latin Small Letter Y with Acute
{0x7E,0x14,0x14,0x14,0x08}, // (184) p - 0x00FE Latin Small Letter Thom
{0x0C,0x51,0x50,0x51,0x3C}, // (185) "y - 0x00FF Latin Small Letter Y with Diaeresis
{0x1E,0x09,0x09,0x29,0x5E}, // (186) A - 0x0104 Latin Capital Letter A with Ogonek
{0x08,0x15,0x15,0x35,0x4E}, // (187) a - 0x0105 Latin Small Letter A with Ogonek
{0x38,0x44,0x46,0x45,0x20}, // (188) 'C - 0x0106 Latin Capital Letter C with Acute
{0x30,0x48,0x4A,0x49,0x20}, // (189) 'c - 0x0107 Latin Small Letter C with Acute
{0x38,0x45,0x46,0x45,0x20}, // (190) C - 0x010C Latin Capital Letter C with Caron
{0x30,0x49,0x4A,0x49,0x20}, // (191) c - 0x010D Latin Small Letter C with Caron
{0x7C,0x45,0x46,0x45,0x38}, // (192) D - 0x010E Latin Capital Letter D with Caron
{0x20,0x50,0x50,0x7C,0x03}, // (193) d' - 0x010F Latin Small Letter D with Caron
{0x1F,0x15,0x15,0x35,0x51}, // (194) E - 0x0118 Latin Capital Letter E with Ogonek
{0x0E,0x15,0x15,0x35,0x46}, // (195) e - 0x0119 Latin Small Letter E with Ogonek
{0x7C,0x55,0x56,0x55,0x44}, // (196) E - 0x011A Latin Capital Letter E with Caron
{0x38,0x55,0x56,0x55,0x18}, // (197) e - 0x011B Latin Small Letter E with Caron
{0x00,0x44,0x7C,0x40,0x00}, // (198) i - 0x0131 Latin Small Letter Dotless I
{0x7F,0x48,0x44,0x40,0x40}, // (199) L - 0x0141 Latin Capital Letter L with Stroke
{0x00,0x49,0x7F,0x44,0x00}, // (200) l - 0x0142 Latin Small Letter L with Stroke
{0x7C,0x08,0x12,0x21,0x7C}, // (201) 'N - 0x0143 Latin Capital Letter N with Acute
{0x78,0x10,0x0A,0x09,0x70}, // (202) 'n - 0x0144 Latin Small Letter N with Acute
{0x7C,0x09,0x12,0x21,0x7C}, // (203) N - 0x0147 Latin Capital Letter N with Caron
{0x78,0x11,0x0A,0x09,0x70}, // (204) n - 0x0148 Latin Small Letter N with Caron
{0x38,0x47,0x44,0x47,0x38}, // (205) "O - 0x0150 Latin Capital Letter O with Double Acute
{0x30,0x4B,0x48,0x4B,0x30}, // (206) "o - 0x0151 Latin Small Letter O with Double Acute
{0x3E,0x41,0x7F,0x49,0x49}, // (207) OE - 0x0152 Latin Capital Ligature Oe
{0x38,0x44,0x38,0x54,0x58}, // (208) oe - 0x0153 Latin Small Ligature Oe
{0x7C,0x15,0x16,0x35,0x48}, // (209) R - 0x0158 Latin Capital Letter R with Caron
{0x78,0x11,0x0A,0x09,0x10}, // (210) r - 0x0159 Latin Small Letter R with Caron
{0x48,0x54,0x56,0x55,0x20}, // (211) 'S - 0x015A Latin Capital Letter S with Acute
{0x20,0x48,0x56,0x55,0x20}, // (212) 's - 0x015B Latin Small Letter S with Acute
{0x48,0x55,0x56,0x55,0x20}, // (213) S - 0x0160 Latin Capital Letter S with Caron
{0x20,0x49,0x56,0x55,0x20}, // (214) s - 0x0161 Latin Small Letter S with Caron
{0x04,0x05,0x7E,0x05,0x04}, // (215) T - 0x0164 Latin Capital Letter T with Caron
{0x08,0x3C,0x48,0x22,0x01}, // (216) t' - 0x0165 Latin Small Letter T with Caron
{0x3C,0x42,0x45,0x42,0x3C}, // (217) U - 0x016E Latin Capital Letter U with Ring Above
{0x38,0x42,0x45,0x22,0x78}, // (218) u - 0x016F Latin Small Letter U with Ring Above
{0x3C,0x43,0x40,0x43,0x3C}, // (219) "U - 0x0170 Latin Capital Letter U with Double Acute
{0x38,0x43,0x40,0x23,0x78}, // (220) "u - 0x0171 Latin Small Letter U with Double Acute
{0x0C,0x11,0x60,0x11,0x0C}, // (221) "Y - 0x0178 Latin Capital Letter Y with Diaeresis
{0x44,0x66,0x55,0x4C,0x44}, // (222) 'Z - 0x0179 Latin Capital Letter Z with Acute
{0x48,0x6A,0x59,0x48,0x00}, // (223) 'z - 0x017A Latin Small Letter Z with Acute
{0x44,0x64,0x55,0x4C,0x44}, // (224) Z - 0x017B Latin Capital Letter Z with Dot Above
{0x48,0x68,0x5A,0x48,0x00}, // (225) z - 0x017C Latin Small Letter Z with Dot Above
{0x44,0x65,0x56,0x4D,0x44}, // (226) Z - 0x017D Latin Capital Letter Z with Caron
{0x48,0x69,0x5A,0x49,0x00}, // (227) z - 0x017E Latin Small Letter Z with Caron
{0x00,0x02,0x01,0x02,0x00}, // (228) ^ - 0x02C6 Modifier Letter Circumflex Accent
{0x00,0x01,0x02,0x01,0x00}, // (229) - 0x02C7 Caron
{0x00,0x01,0x01,0x01,0x00}, // (230) - 0x02C9 Modifier Letter Macron
{0x01,0x02,0x02,0x01,0x00}, // (231) - 0x02D8 Breve
{0x00,0x00,0x01,0x00,0x00}, // (232) - 0x02D9 Dot Above
{0x00,0x02,0x05,0x02,0x00}, // (233) - 0x02DA Ring Above
{0x02,0x01,0x02,0x01,0x00}, // (234) ~ - 0x02DC Small Tilde
{0x7F,0x05,0x15,0x3A,0x50}, // (235) Pt - 0x20A7 Peseta Sign
{0x3E,0x55,0x55,0x41,0x22}, // (236) C - 0x20AC Euro Sign
{0x18,0x14,0x08,0x14,0x0C}, // (237) - 0x221E Infinity
{0x44,0x4A,0x4A,0x51,0x51}, // (238) < - 0x2264 Less-Than or Equal to
{0x51,0x51,0x4A,0x4A,0x44}, // (239) > - 0x2265 Greater-Than or Equal to
{0x74,0x42,0x41,0x42,0x74}, // (240) - 0x2302 House
unsigned char code Ascii_2[108][5]={ // Refer to "Times New Roman" Font Database...
// Greek & Japanese Letters
{0x7E,0x11,0x11,0x11,0x7E}, // ( 1) A - 0x0391 Greek Capital Letter Alpha
{0x7F,0x49,0x49,0x49,0x36}, // ( 2) B - 0x0392 Greek Capital Letter Beta
{0x7F,0x02,0x01,0x01,0x03}, // ( 3) - 0x0393 Greek Capital Letter Gamma
{0x70,0x4E,0x41,0x4E,0x70}, // ( 4) - 0x0394 Greek Capital Letter Delta
{0x7F,0x49,0x49,0x49,0x41}, // ( 5) E - 0x0395 Greek Capital Letter Epsilon
{0x61,0x51,0x49,0x45,0x43}, // ( 6) Z - 0x0396 Greek Capital Letter Zeta
{0x7F,0x08,0x08,0x08,0x7F}, // ( 7) H - 0x0397 Greek Capital Letter Eta
{0x3E,0x49,0x49,0x49,0x3E}, // ( 8) - 0x0398 Greek Capital Letter Theta
{0x00,0x41,0x7F,0x41,0x00}, // ( 9) I - 0x0399 Greek Capital Letter Iota
{0x7F,0x08,0x14,0x22,0x41}, // ( 10) K - 0x039A Greek Capital Letter Kappa
{0x70,0x0E,0x01,0x0E,0x70}, // ( 11) - 0x039B Greek Capital Letter Lamda
{0x7F,0x02,0x0C,0x02,0x7F}, // ( 12) M - 0x039C Greek Capital Letter Mu
{0x7F,0x04,0x08,0x10,0x7F}, // ( 13) N - 0x039D Greek Capital Letter Nu
{0x63,0x5D,0x49,0x5D,0x63}, // ( 14) - 0x039E Greek Capital Letter Xi
{0x3E,0x41,0x41,0x41,0x3E}, // ( 15) O - 0x039F Greek Capital Letter Omicron
{0x41,0x3F,0x01,0x3F,0x41}, // ( 16) - 0x03A0 Greek Capital Letter Pi
{0x7F,0x09,0x09,0x09,0x06}, // ( 17) P - 0x03A1 Greek Capital Letter Rho
{0x63,0x55,0x49,0x41,0x41}, // ( 18) - 0x03A3 Greek Capital Letter Sigma
{0x01,0x01,0x7F,0x01,0x01}, // ( 19) T - 0x03A4 Greek Capital Letter Tau
{0x03,0x01,0x7E,0x01,0x03}, // ( 20) - 0x03A5 Greek Capital Letter Upsilon
{0x08,0x55,0x7F,0x55,0x08}, // ( 21) - 0x03A6 Greek Capital Letter Phi
{0x63,0x14,0x08,0x14,0x63}, // ( 22) X - 0x03A7 Greek Capital Letter Chi
{0x07,0x48,0x7F,0x48,0x07}, // ( 23) - 0x03A8 Greek Capital Letter Psi
{0x5E,0x61,0x01,0x61,0x5E}, // ( 24) - 0x03A9 Greek Capital Letter Omega
{0x38,0x44,0x48,0x30,0x4C}, // ( 25) a - 0x03B1 Greek Small Letter Alpha
{0x7C,0x2A,0x2A,0x2A,0x14}, // ( 26) B - 0x03B2 Greek Small Letter Beta
{0x44,0x38,0x04,0x04,0x08}, // ( 27) r - 0x03B3 Greek Small Letter Gamma
{0x30,0x4B,0x4D,0x59,0x30}, // ( 28) - 0x03B4 Greek Small Letter Delta
{0x28,0x54,0x54,0x44,0x20}, // ( 29) - 0x03B5 Greek Small Letter Epsilon
{0x00,0x18,0x55,0x52,0x22}, // ( 30) - 0x03B6 Greek Small Letter Zeta
{0x3E,0x04,0x02,0x02,0x7C}, // ( 31) n - 0x03B7 Greek Small Letter Eta
{0x3C,0x4A,0x4A,0x4A,0x3C}, // ( 32) - 0x03B8 Greek Small Letter Theta
{0x00,0x3C,0x40,0x20,0x00}, // ( 33) i - 0x03B9 Greek Small Letter Iota
{0x7C,0x10,0x28,0x44,0x40}, // ( 34) k - 0x03BA Greek Small Letter Kappa
{0x41,0x32,0x0C,0x30,0x40}, // ( 35) - 0x03BB Greek Small Letter Lamda
{0x7E,0x20,0x20,0x10,0x3E}, // ( 36) u - 0x03BC Greek Small Letter Mu
{0x1C,0x20,0x40,0x20,0x1C}, // ( 37) v - 0x03BD Greek Small Letter Nu
{0x14,0x2B,0x2A,0x2A,0x60}, // ( 38) - 0x03BE Greek Small Letter Xi
{0x38,0x44,0x44,0x44,0x38}, // ( 39) o - 0x03BF Greek Small Letter Omicron
{0x44,0x3C,0x04,0x7C,0x44}, // ( 40) - 0x03C0 Greek Small Letter Pi
{0x70,0x28,0x24,0x24,0x18}, // ( 41) p - 0x03C1 Greek Small Letter Rho
{0x0C,0x12,0x12,0x52,0x60}, // ( 42) - 0x03C2 Greek Small Letter Final Sigma
{0x38,0x44,0x4C,0x54,0x24}, // ( 43) - 0x03C3 Greek Small Letter Sigma
{0x04,0x3C,0x44,0x20,0x00}, // ( 44) t - 0x03C4 Greek Small Letter Tau
{0x3C,0x40,0x40,0x20,0x1C}, // ( 45) v - 0x03C5 Greek Small Letter Upsilon
{0x18,0x24,0x7E,0x24,0x18}, // ( 46) - 0x03C6 Greek Small Letter Phi
{0x44,0x28,0x10,0x28,0x44}, // ( 47) x - 0x03C7 Greek Small Letter Chi
{0x0C,0x10,0x7E,0x10,0x0C}, // ( 48) - 0x03C8 Greek Small Letter Psi
{0x38,0x44,0x30,0x44,0x38}, // ( 49) w - 0x03C9 Greek Small Letter Omega
{0x0A,0x0A,0x4A,0x2A,0x1E}, // ( 50) - 0xFF66 Katakana Letter Wo
{0x04,0x44,0x34,0x14,0x0C}, // ( 51) - 0xFF67 Katakana Letter Small A
{0x20,0x10,0x78,0x04,0x00}, // ( 52) - 0xFF68 Katakana Letter Small I
{0x18,0x08,0x4C,0x48,0x38}, // ( 53) - 0xFF69 Katakana Letter Small U
{0x48,0x48,0x78,0x48,0x48}, // ( 54) - 0xFF6A Katakana Letter Small E
{0x48,0x28,0x18,0x7C,0x08}, // ( 55) - 0xFF6B Katakana Letter Small O
{0x08,0x7C,0x08,0x28,0x18}, // ( 56) - 0xFF6C Katakana Letter Small Ya
{0x40,0x48,0x48,0x78,0x40}, // ( 57) - 0xFF6D Katakana Letter Small Yu
{0x54,0x54,0x54,0x7C,0x00}, // ( 58) - 0xFF6E Katakana Letter Small Yo
{0x18,0x00,0x58,0x40,0x38}, // ( 59) - 0xFF6F Katakana Letter Small Tu
{0x08,0x08,0x08,0x08,0x08}, // ( 60) - 0xFF70 Katakana-Hiragana Prolonged Sound Mark
{0x01,0x41,0x3D,0x09,0x07}, // ( 61) - 0xFF71 Katakana Letter A
{0x10,0x08,0x7C,0x02,0x01}, // ( 62) - 0xFF72 Katakana Letter I
{0x0E,0x02,0x43,0x22,0x1E}, // ( 63) - 0xFF73 Katakana Letter U
{0x42,0x42,0x7E,0x42,0x42}, // ( 64) - 0xFF74 Katakana Letter E
{0x22,0x12,0x0A,0x7F,0x02}, // ( 65) - 0xFF75 Katakana Letter O
{0x42,0x3F,0x02,0x42,0x3E}, // ( 66) - 0xFF76 Katakana Letter Ka
{0x0A,0x0A,0x7F,0x0A,0x0A}, // ( 67) - 0xFF77 Katakana Letter Ki
{0x08,0x46,0x42,0x22,0x1E}, // ( 68) - 0xFF78 Katakana Letter Ku
{0x04,0x03,0x42,0x3E,0x02}, // ( 69) - 0xFF79 Katakana Letter Ke
{0x42,0x42,0x42,0x42,0x7E}, // ( 70) - 0xFF7A Katakana Letter Ko
{0x02,0x4F,0x22,0x1F,0x02}, // ( 71) - 0xFF7B Katakana Letter Sa
{0x4A,0x4A,0x40,0x20,0x1C}, // ( 72) - 0xFF7C Katakana Letter Shi
{0x42,0x22,0x12,0x2A,0x46}, // ( 73) - 0xFF7D Katakana Letter Su
{0x02,0x3F,0x42,0x4A,0x46}, // ( 74) - 0xFF7E Katakana Letter Se
{0x06,0x48,0x40,0x20,0x1E}, // ( 75) - 0xFF7F Katakana Letter So
{0x08,0x46,0x4A,0x32,0x1E}, // ( 76) - 0xFF80 Katakana Letter Ta
{0x0A,0x4A,0x3E,0x09,0x08}, // ( 77) - 0xFF81 Katakana Letter Chi
{0x0E,0x00,0x4E,0x20,0x1E}, // ( 78) - 0xFF82 Katakana Letter Tsu
{0x04,0x45,0x3D,0x05,0x04}, // ( 79) - 0xFF83 Katakana Letter Te
{0x00,0x7F,0x08,0x10,0x00}, // ( 80) - 0xFF84 Katakana Letter To
{0x44,0x24,0x1F,0x04,0x04}, // ( 81) - 0xFF85 Katakana Letter Na
{0x40,0x42,0x42,0x42,0x40}, // ( 82) - 0xFF86 Katakana Letter Ni
{0x42,0x2A,0x12,0x2A,0x06}, // ( 83) - 0xFF87 Katakana Letter Nu
{0x22,0x12,0x7B,0x16,0x22}, // ( 84) - 0xFF88 Katakana Letter Ne
{0x00,0x40,0x20,0x1F,0x00}, // ( 85) - 0xFF89 Katakana Letter No
{0x78,0x00,0x02,0x04,0x78}, // ( 86) - 0xFF8A Katakana Letter Ha
{0x3F,0x44,0x44,0x44,0x44}, // ( 87) - 0xFF8B Katakana Letter Hi
{0x02,0x42,0x42,0x22,0x1E}, // ( 88) - 0xFF8C Katakana Letter Fu
{0x04,0x02,0x04,0x08,0x30}, // ( 89) - 0xFF8D Katakana Letter He
{0x32,0x02,0x7F,0x02,0x32}, // ( 90) - 0xFF8E Katakana Letter Ho
{0x02,0x12,0x22,0x52,0x0E}, // ( 91) - 0xFF8F Katakana Letter Ma
{0x00,0x2A,0x2A,0x2A,0x40}, // ( 92) - 0xFF90 Katakana Letter Mi
{0x38,0x24,0x22,0x20,0x70}, // ( 93) - 0xFF91 Katakana Letter Mu
{0x40,0x28,0x10,0x28,0x06}, // ( 94) - 0xFF92 Katakana Letter Me
{0x0A,0x3E,0x4A,0x4A,0x4A}, // ( 95) - 0xFF93 Katakana Letter Mo
{0x04,0x7F,0x04,0x14,0x0C}, // ( 96) - 0xFF94 Katakana Letter Ya
{0x40,0x42,0x42,0x7E,0x40}, // ( 97) - 0xFF95 Katakana Letter Yu
{0x4A,0x4A,0x4A,0x4A,0x7E}, // ( 98) - 0xFF96 Katakana Letter Yo
{0x04,0x05,0x45,0x25,0x1C}, // ( 99) - 0xFF97 Katakana Letter Ra
{0x0F,0x40,0x20,0x1F,0x00}, // (100) - 0xFF98 Katakana Letter Ri
{0x7C,0x00,0x7E,0x40,0x30}, // (101) - 0xFF99 Katakana Letter Ru
{0x7E,0x40,0x20,0x10,0x08}, // (102) - 0xFF9A Katakana Letter Re
{0x7E,0x42,0x42,0x42,0x7E}, // (103) - 0xFF9B Katakana Letter Ro
{0x0E,0x02,0x42,0x22,0x1E}, // (104) - 0xFF9C Katakana Letter Wa
{0x42,0x42,0x40,0x20,0x18}, // (105) - 0xFF9D Katakana Letter N
{0x02,0x04,0x01,0x02,0x00}, // (106) - 0xFF9E Katakana Voiced Sound Mark
{0x07,0x05,0x07,0x00,0x00}, // (107) - 0xFF9F Katakana Semi-Voiced Sound Mark
// Graphic Acceleration
void GA_Option(unsigned char d)
Write_Command(0x23); // Graphic Acceleration Command Options
Write_Command(d); // Default => 0x01
// Enable Fill Rectangle
// Disable Wrap around in Horizontal Direction During Copying & Scrolling
// Disable Reverse Copy
void Draw_Rectangle(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e)
Write_Command(0x24); // Draw Rectangle
Write_Command(a); // Column Address of Start
Write_Command(c); // Row Address of Start
Write_Command(b); // Column Address of End (Total Columns Devided by 2)
Write_Command(d); // Row Address of End
Write_Command(e); // Gray Scale Level
uDelay(200);
void Copy(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e, unsigned char f)
Write_Command(0x25); // Copy
Write_Command(e); // Column Address of New Start
Write_Command(f); // Row Address of New Start
uDelay(200);
// Show Regular Pattern (Full Screen)
// a: Two Pixels Data
void Fill_RAM(unsigned char a)
GA_Option(0x01);
Draw_Rectangle(0x00,0x3F,0x00,0x5F,a);
// Show Regular Pattern (Partial or Full Screen)
// a: Column Address of Start
// b: Column Address of End (Total Columns Devided by 2)
// c: Row Address of Start
// d: Row Address of End
// e: Two Pixels Data
void Fill_Block(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e)
GA_Option(0x01);
Draw_Rectangle(a,b,c,d,e);
// Show Checkboard (Full Screen)
void Checkerboard()
unsigned char i,j;
Set_Column_Address(0x00,0x3F);
Set_Row_Address(0x00,0x5F);
for(i=0;i<40;i++)
for(j=0;j<64;j++)
Write_Data(0xF0);
for(j=0;j<64;j++)
Write_Data(0x0F);
// Show Gray Scale Bar (Full Screen)
void Grayscale()
// Level 16 => Column 1~8
Fill_Block(0x00,0x03,0x00,0x3F,0xFF);
// Level 15 => Column 9~16
Fill_Block(0x04,0x07,0x00,0x3F,0xEE);
// Level 14 => Column 17~24
Fill_Block(0x08,0x0B,0x00,0x3F,0xDD);
// Level 13 => Column 25~32
Fill_Block(0x0C,0x0F,0x00,0x3F,0xCC);
// Level 12 => Column 33~40
Fill_Block(0x10,0x13,0x00,0x3F,0xBB);
// Level 11 => Column 41~48
Fill_Block(0x14,0x17,0x00,0x3F,0xAA);
// Level 10 => Column 49~56
Fill_Block(0x18,0x1B,0x00,0x3F,0x99);
// Level 9 => Column 57~64
Fill_Block(0x1C,0x1F,0x00,0x3F,0x88);
// Level 8 => Column 65~72
Fill_Block(0x20,0x23,0x00,0x3F,0x77);
// Level 7 => Column 73~80
Fill_Block(0x24,0x27,0x00,0x3F,0x66);
// Level 6 => Column 81~88
Fill_Block(0x28,0x2B,0x00,0x3F,0x55);
// Level 5 => Column 89~96
Fill_Block(0x2C,0x2F,0x00,0x3F,0x44);
// Level 4 => Column 97~104
Fill_Block(0x30,0x33,0x00,0x3F,0x33);
// Level 3 => Column 105~112
Fill_Block(0x34,0x37,0x00,0x3F,0x22);
// Level 2 => Column 113~120
Fill_Block(0x38,0x3B,0x00,0x3F,0x11);
// Level 1 => Column 121~128
Fill_Block(0x3C,0x3F,0x00,0x3F,0x00);
// Show Frame (Full Screen)
void Frame()
GA_Option(0x00);
Draw_Rectangle(0x00,0x3F,0x00,0x3F,0xFF);
Fill_Block(0x00,0x00,0x01,0x3E,0x0F);
Fill_Block(0x3F,0x3F,0x01,0x3E,0xF0);
// Show Character (5x7)
// a: Database
// b: Ascii
// c: Start X Address
// d: Start Y Address
void Show_Font57(unsigned char a, unsigned char b, unsigned char c, unsigned char d)
unsigned char *Src_Pointer;
unsigned char i,Font,MSB,LSB;
switch(a)
case 1:
Src_Pointer=&Ascii_1[(b-1)];
case 2:
Src_Pointer=&Ascii_2[(b-1)];
Set_Remap_Format(0x54);
Src_Pointer--;
for(i=0;i<=4;i+=2)
LSB=*Src_Pointer;
Src_Pointer++;
if(i == 4)
MSB=0x00;
MSB=*Src_Pointer;
Src_Pointer++;
Set_Column_Address(c,c);
Set_Row_Address(d,d+7);
Font=((MSB&0x01)<<4)|(LSB&0x01);
Font=Font|(Font<<1)|(Font<<2)|(Font<<3);
Write_Data(Font);
Font=((MSB&0x02)<<3)|((LSB&0x02)>>1);
Write_Data(Font);
Font=((MSB&0x04)<<2)|((LSB&0x04)>>2);
Write_Data(Font);
Font=((MSB&0x08)<<1)|((LSB&0x08)>>3);
Write_Data(Font);
Font=((MSB&0x10)<<3)|((LSB&0x10)>>1);
Font=Font|(Font>>1)|(Font>>2)|(Font>>3);
Write_Data(Font);
Font=((MSB&0x20)<<2)|((LSB&0x20)>>2);
Write_Data(Font);
Font=((MSB&0x40)<<1)|((LSB&0x40)>>3);
Write_Data(Font);
Font=(MSB&0x80)|((LSB&0x80)>>4);
Write_Data(Font);
c++;
Set_Remap_Format(0x50);
// Show String
// a: Database
// b: Start X Address
// c: Start Y Address
// * Must write "0" in the end...
void Show_String(unsigned char a, unsigned char *Data_Pointer, unsigned char b, unsigned char c)
Src_Pointer=Data_Pointer;
Show_Font57(1,96,b,c); // No-Break Space
// Must be written first before the string start...
Show_Font57(a,*Src_Pointer,b,c);
Src_Pointer++;
b+=3;
if(*Src_Pointer == 0) break;
// Show Pattern (Partial or Full Screen)
void Show_Pattern(unsigned char *Data_Pointer, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
unsigned char i,j;
Set_Column_Address(a,b);
Set_Row_Address(c,d);
for(i=0;i<(b-a+1);i++)
for(j=0;j<(d-c+1);j++)
Write_Data(*Src_Pointer);
Src_Pointer++;
// Vertical Scrolling (Full Screen)
// a: Scrolling Direction
// "0x00" (Upward)
// "0x01" (Downward)
// b: Set Numbers of Row Scroll per Step
// c: Set Time Interval between Each Scroll Step
void Vertical_Scroll(unsigned char a, unsigned char b, unsigned char c)
unsigned int i,j;
switch(a)
case 0:
for(i=0;i<80;i+=b)
Set_Start_Line(i);
for(j=0;j<c;j++)
uDelay(200);
case 1:
for(i=0;i<80;i+=b)
Set_Start_Line(80-i);
for(j=0;j<c;j++)
uDelay(200);
Set_Start_Line(0x00);
// Continuous Horizontal Scrolling (Partial or Full Screen)
// a: Set Numbers of Column Scroll per Step
// b: Set Numbers of Row to Be Scrolled
// c: Set Time Interval between Each Scroll Step in Terms of Frame Frequency
// d: Delay Time
void Horizontal_Scroll(unsigned char a, unsigned char b, unsigned char c, unsigned char d)
GA_Option(0x03);
Write_Command(0x26); // Horizontal Scroll Setup
Write_Command(a);
Write_Command(b);
Write_Command(c);
Write_Command(0x2F); // Activate Scrolling
Delay(d);
// Continuous Horizontal Fade Scrolling (Partial or Full Screen)
// d: Delay Time
void Fade_Scroll(unsigned char a, unsigned char b, unsigned char c, unsigned char d)
GA_Option(0x01);
Write_Command(a);
Write_Command(b);
Write_Command(c);
Delay(d);
// Deactivate Scrolling (Full Screen)
void Deactivate_Scroll()
Write_Command(0x2E); // Deactivate Scrolling
// Fade In (Full Screen)
void Fade_In()
unsigned int i;
Set_Display_On_Off(0x01);
for(i=0;i<(Brightness+1);i++)
Set_Contrast_Current(i);
uDelay(200);
uDelay(200);
uDelay(200);
// Fade Out (Full Screen)
void Fade_Out()
unsigned int i;
for(i=(Brightness+1);i>0;i--)
Set_Contrast_Current(i-1);
uDelay(200);
uDelay(200);
uDelay(200);
Set_Display_On_Off(0x00);
// Sleep Mode
// "0x01" Enter Sleep Mode
// "0x00" Exit Sleep Mode
void Sleep(unsigned char a)
switch(a)
case 0:
Set_Display_Mode(0x01);
case 1:
Set_Display_Mode(0x00);
// Connection Test
void Test()
unsigned char i;
RES=0;
for(i=0;i<200;i++)
uDelay(200);
RES=1;
Set_Display_Mode(0x01); // Entire Display On Mode (0x00/0x01/0x02/0x03)
Set_Display_On_Off(0x01); // Display On (0x00/0x01)
Delay(2);
Set_Display_On_Off(0x00); // Display Off (0x00/0x01)
Delay(2);
// Gray Scale Table Setting (Full Screen)
void Set_Gray_Scale_Table()
Write_Command(0xB8); // Set Gray Scale Table
Write_Command(0x01); // Gray Scale Level 1
Write_Command(0x11); // Gray Scale Level 3 & 2
Write_Command(0x22); // Gray Scale Level 5 & 4
Write_Command(0x32); // Gray Scale Level 7 & 6
Write_Command(0x43); // Gray Scale Level 9 & 8
Write_Command(0x54); // Gray Scale Level 11 & 10
Write_Command(0x65); // Gray Scale Level 13 & 12
Write_Command(0x76); // Gray Scale Level 15 & 14
// Initialization
void OLED_Init()
unsigned char i;
RES=0;
for(i=0;i<200;i++)
uDelay(200);
RES=1;
Set_Display_Clock(0x91); // Set Clock as 135 Frames/Sec
Set_Multiplex_Ratio(0x3F); // 1/64 Duty (0x0F~0x5F)
Set_Display_Offset(0x4C); // Shift Mapping RAM Counter (0x00~0x5F)
Set_Start_Line(0x00); // Set Mapping RAM Display Start Line (0x00~0x5F)
Set_Remap_Format(0x50); // Set Column Address 0 Mapped to SEG0
// Disable Nibble Remap
// Scan from COM[N-1] to COM0
// Enable COM Split Odd Even
Set_Master_Config(0x00); // Disable Embedded DC/DC Converter (0x00/0x01)
Set_Contrast_Current(Brightness); // Set Scale Factor of Segment Output Current Control
Set_Current_Range(0x02); // Set Full Current Range
Set_Gray_Scale_Table(); // Set Pulse Width for Gray Scale Table
Set_Frame_Frequency(0x46); // Set Frame Frequency
Set_Phase_Length(0x22); // Set Phase 1 as 2 Clocks & Phase 2 as 2 Clocks
Set_Precharge_Voltage(0x10); // Set Pre-Charge Voltage Level
Set_Precharge_Compensation(0x20,0x07); // Set Pre-Charge Compensation
Set_VCOMH(0x02); // Set High Voltage Level of COM Pin
Set_VSL(0x0C); // Set Low Voltage Level of SEG Pin
Set_Display_Mode(0x00); // Normal Display Mode (0x00/0x01/0x02/0x03)
Fill_RAM(0x00); // Clear Screen
// Main Program
void main()
unsigned char code Name[]={53,78,73,86,73,83,73,79,78,0};
// Univision
unsigned char code Tel[]={11,24,24,22,13,19,23,13,21,24,22,21,24,22,0};
// +886-37-586586
unsigned char i;
P1=0xFF;
P3=0xFF;
OLED_Init();
// Show Pattern - Univision Logo
Show_Pattern(&Logo,0x00,0x3F,0x0B,0x35);
Delay(1);
// Fade In/Out (Full Screen)
Fade_Out();
Fade_In();
Fade_Out();
Fade_In();
Delay(1);
// Scrolling (Partial or Full Screen)
Vertical_Scroll(0x00,0x01,0x70);
// Upward
Delay(1);
Vertical_Scroll(0x01,0x01,0x70);
// Downward
Delay(1);
Deactivate_Scroll();
Horizontal_Scroll(0x01,0x40,0x00,0x03);
// Rightward
Horizontal_Scroll(0x3F,0x40,0x00,0x03);
// Leftward
Fade_Scroll(0x01,0x40,0x00,0x03);
// Rightward
// All Pixels On (Test Pattern)
Fill_RAM(0xFF);
Delay(1);
// Checkerboard (Test Pattern)
Checkerboard();
Delay(1);
// Gray Scale Bar (Test Pattern)
Grayscale();
Delay(1);
// Show Pattern - Frame (Test Pattern)
Frame();
Delay(1);
// Show String - Univision +886-37-586586
Show_String(1,&Name,0x13,0x14);
Show_String(1,&Tel,0x0B,0x24);
Delay(1);
点击此处下载 ourdev_545181.rar(文件大小:13K) (原文件名:目前最火热流行的OLED驱动程序.rar) |
