回复: 3
uC/OS-ii 移植到Atmeg128 编译环境为ICCV7 编译通过但是不能正常运行
发表于 2010-4-9 21:52:55 | 显示全部楼层 |阅读模式
下面是所有的代码,uC/OS移植好几天了,移植一直都不成功,哪位大侠给分析下,谢谢。
所有的代码ourdev_545050.rar(文件大小:281K) (原文件名:myOS.rar)
发表于 2010-4-12 11:24:27 | 显示全部楼层
移植函数有问题.
;                                               uC/OS-II
;                                         The Real-Time Kernel
;                                       ATmega128  Specific code
; File     : OS_CPU_A.S
; By       : Ole Saether
;            Jean J. Labrosse
;                                           I/O PORT ADDRESSES
BIT00   = 0x01
BIT01   = 0x02
BIT02   = 0x04
BIT03   = 0x08
BIT04   = 0x10
BIT05   = 0x20
BIT06   = 0x40
BIT07   = 0x80
SREG    = 0x3F
SPH     = 0x3E
SPL     = 0x3D
RAMPZ   = 0x3B
;                                         MACROS
                .macro  PUSH_ALL                            ; Save all registers
                ST      -Y,R0
                ST      -Y,R1
                ST      -Y,R2
                ST      -Y,R3
                ST      -Y,R4
                ST      -Y,R5
                ST      -Y,R6
                ST      -Y,R7
                ST      -Y,R8
                ST      -Y,R9
                ST      -Y,R10
                ST      -Y,R11
                ST      -Y,R12
                ST      -Y,R13
                ST      -Y,R14
                ST      -Y,R15
                ST      -Y,R16
                ST      -Y,R17
                ST      -Y,R18
                ST      -Y,R19
                ST      -Y,R20
                ST      -Y,R21
                ST      -Y,R22
                ST      -Y,R23
                ST      -Y,R24
                ST      -Y,R25
                ST      -Y,R26
                ST      -Y,R27
                ST      -Y,R30
                ST      -Y,R31
                .endmacro
                .macro  POP_ALL                             ; Restore all registers
                LD      R31,Y+
                LD      R30,Y+
                LD      R27,Y+
                LD      R26,Y+
                LD      R25,Y+
                LD      R24,Y+
                LD      R23,Y+
                LD      R22,Y+
                LD      R21,Y+
                LD      R20,Y+
                LD      R19,Y+
                LD      R18,Y+
                LD      R17,Y+
                LD      R16,Y+
                LD      R15,Y+
                LD      R14,Y+
                LD      R13,Y+
                LD      R12,Y+
                LD      R11,Y+
                LD      R10,Y+
                LD      R9,Y+
                LD      R8,Y+
                LD      R7,Y+
                LD      R6,Y+
                LD      R5,Y+
                LD      R4,Y+
                LD      R3,Y+
                LD      R2,Y+
                LD      R1,Y+
                LD      R0,Y+
                .endmacro
                .macro  PUSH_SP                             ; Save stack pointer
                IN      R16,SPH
                ST      -Y,R16
                IN      R16,SPL
                ST      -Y,R16
                .endmacro
                .macro  POP_SP                              ; Restore stack pointer
                LD      R16,Y+
                OUT     SPL,R16
                LD      R16,Y+
                OUT     SPH,R16
                .endmacro
                .macro  PUSH_SREG                           ; Save status register
                IN      R16,SREG
                ST      -Y,R16
                .endmacro
                .macro  POP_SREG                            ; Restore status registers
                LD      R16,Y+
                OUT     SREG,R16
                .endmacro
                .area   text(rel)
;/*$PAGE*/.
;                            DISABLE/ENABLE INTERRUPTS USING OS_CRITICAL_METHOD #3
; Description : These functions are used to disable and enable interrupts using OS_CRITICAL_METHOD #3.
;               OS_CPU_SR  OSCPUSaveSR (void)
;                     Get current value of SREG
;                     Disable interrupts
;                     Return original value of SREG
;               void  OSCPURestoreSR (OS_CPU_SR cpu_sr)
;                     Set SREG to cpu_sr
;                     Return
_OS_CPU_SR_Save::
                IN      R16,SREG                    ; Get current state of interrupts disable flag
                CLI                                 ; Disable interrupts
                RET                                 ; Return original SREG value in R16
_OS_CPU_SR_Restore::
                OUT     SREG,R16                    ; Restore SREG
                RET                                 ; Return
;/*$PAGE*/.
;                               START HIGHEST PRIORITY TASK READY-TO-RUN
; Description : This function is called by OSStart() to start the highest priority task that was created
;               by your application before calling OSStart().
; Note(s)     : 1) The (data)stack frame is assumed to look as follows:
;                  OSTCBHighRdy->OSTCBStkPtr --> SPL of (return) stack pointer           (Low memory)
;                                                SPH of (return) stack pointer
;                                                Flags to load in status register
;                                                R31
;                                                R30
;                                                R27
;                                                R0
;                                                PCH
;                                                PCL                                     (High memory)
;                  where the stack pointer points to the task start address.
;               2) OSStartHighRdy() MUST:
;                      a) Call OSTaskSwHook() then,
;                      b) Set OSRunning to TRUE,
;                      c) Switch to the highest priority task.
_OSStartHighRdy::
                CALL    _OSTaskSwHook               ; Invoke user defined context switch hook
                LDS     R16,_OSRunning              ; Indicate that we are multitasking
                INC     R16                         ;
                STS     _OSRunning,R16              ;
                LDS     R30,_OSTCBHighRdy           ; Let Z point to TCB of highest priority task
                LDS     R31,_OSTCBHighRdy+1         ; ready to run
                LD      R28,Z+                      ; Load Y (R29:R28) pointer
                LD      R29,Z+                      ;
                RET                                 ; Start task
;/*$PAGE*/.
;                                       TASK LEVEL CONTEXT SWITCH
; Description : This function is called when a task makes a higher priority task ready-to-run.
; Note(s)     : 1) Upon entry,
;                  OSTCBCur     points to the OS_TCB of the task to suspend
;                  OSTCBHighRdy points to the OS_TCB of the task to resume
;               2) The stack frame of the task to suspend looks as follows:
;                                       SP+0 --> LSB of task code address
;                                         +1     MSB of task code address                (High memory)
;               3) The saved context of the task to resume looks as follows:
;                                                R31
;                                                R30
;                                                R27
;                                                R0
;                                                PCH
;                                                PCL                                     (High memory)
_OSCtxSw::
                PUSH_ALL                            ; Save current task's context
                PUSH_SREG
                PUSH_SP
                LDS     R30,_OSTCBCur               ; Z = OSTCBCur->OSTCBStkPtr
                LDS     R31,_OSTCBCur+1             ;
                ST      Z+,R28                      ; Save Y (R29:R28) pointer
                ST      Z+,R29                      ;
                CALL    _OSTaskSwHook               ; Call user defined task switch hook
                LDS     R16,_OSPrioHighRdy          ; OSPrioCur = OSPrioHighRdy
                STS     _OSPrioCur,R16
                STS     _OSTCBCur,R30               ; OSTCBCur = OSTCBHighRdy
                STS     _OSTCBCur+1,R31             ;
                LD      R28,Z+                      ; Restore Y pointer
                LD      R29,Z+                      ;
                RET
;/*$PAGE*/.
;                                INTERRUPT LEVEL CONTEXT SWITCH
; Description : This function is called by OSIntExit() to perform a context switch to a task that has
;               been made ready-to-run by an ISR.
;                  OSTCBCur->OSTCBStkPtr ------> SPL of (return) stack pointer           (Low memory)
;                                                R31
;                                                R30
;                                                R27
;                                                R0
;                                                PCH
;                                                PCL                                     (High memory)
;                                                R31
;                                                R30
;                                                R27
;                                                R0
;                                                PCH
;                                                PCL                                     (High memory)
_OSIntCtxSw::
                STS     _OSPrioCur,R16              ;
                LDS     R30,_OSTCBHighRdy           ; Z = OSTCBHighRdy->OSTCBStkPtr
                LD      R29,Z+                      ;
                RET
;/*$PAGE*/.
;                                           SYSTEM TICK ISR
; Description : This function is the ISR used to notify uC/OS-II that a system tick has occurred.
;               The following C-like pseudo-code describe the operation being performed in the code below.
;               Save all registers on the current task's stack:
;                      Use the PUSH_ALL macro
;                      Get the SREG, set Bit #7 and save onto the task's stack using -Y addressing
;                      Use the PUSH_SP macro to save the task's hardware stack pointer onto the current task's stack
;               OSIntNesting++;
;               if (OSIntNesting == 1) {
;                  OSTCBCur->OSTCBStkPtr = SP
;               Clear the interrupt;                  Not needed for the timer we used.
;               OSTimeTick();                         Notify uC/OS-II that a tick has occured
;               OSIntExit();                          Notify uC/OS-II about end of ISR
;               Restore all registers that were save on the current task's stack:
;                      Use the POP_SP macro to restore the task's hardware stack pointer
;                      Use the POP_SREG macro to restore the SREG register
;                      Use the POP_ALL macro to restore the remaining registers
;               Return (DO NOT use a RETI instruction);
_OSTickISR::
                PUSH_ALL                            ; Save all registers and status register
                IN      R16,SREG                    ; Save the SREG but with interrupts enabled
                SBR     R16,BIT07
                ST      -Y,R16
                PUSH_SP                             ; Save the task's hardware stack pointer onto task's stack
                LDS     R16,_OSIntNesting           ; Notify uC/OS-II of ISR
                INC     R16                         ;
                STS     _OSIntNesting,R16           ;
                CPI     R16,1                       ; if (OSIntNesting == 1) {
                BRNE    OSTickISR_1
                LDS     R30,_OSTCBCur               ;     OSTCBCur->OSTCBStkPtr = Y
                LDS     R31,_OSTCBCur+1
                ST      Z+,R28
                ST      Z+,R29                      ; }
OSTickISR_1:
                CALL    _OSTickISR_Handler          ; Handle the tick ISR
                CALL    _OSIntExit                  ; Notify uC/OS-II about end of ISR
                POP_SP                              ; Restore the hardware stack pointer from task's stack
                POP_SREG                            ; Restore the SREG register
                RET                                 ; Note: RET instead of RETI
发表于 2010-4-12 11:26:48 | 显示全部楼层
以下是OS_CPU_C.C
*                                              uC/OS-II
*                                        The Real-Time Kernel
*                                       ATmega128 Specific code
* File     : OS_CPU_C.C
* By       : Ole Saether
*            Jean J. Labrosse
#define  OS_CPU_GLOBALS
#include <includes.h>
*                                       OS INITIALIZATION HOOK
*                                            (BEGINNING)
* Description: This function is called by OSInit() at the beginning of OSInit().
* Arguments  : none
* Note(s)    : 1) Interrupts should be disabled during this call.
#if OS_CPU_HOOKS_EN > 0 && OS_VERSION > 203
void  OSInitHookBegin (void)
*                                               (END)
* Description: This function is called by OSInit() at the end of OSInit().
* Arguments  : none
void  OSInitHookEnd (void)
/*$PAGE*/
*                                          TASK CREATION HOOK
* Description: This function is called when a task is created.
* Arguments  : ptcb   is a pointer to the task control block of the task being created.
* Note(s)    : 1) Interrupts are disabled during this call.
void  OSTaskCreateHook (OS_TCB *ptcb)
#ifdef OS_VIEW_MODULE
    OSView_TaskCreateHook(ptcb);
#else
    ptcb = ptcb;                       /* Prevent compiler warning                                     */
*                                           TASK DELETION HOOK
* Description: This function is called when a task is deleted.
* Arguments  : ptcb   is a pointer to the task control block of the task being deleted.
void  OSTaskDelHook (OS_TCB *ptcb)
*                                             IDLE TASK HOOK
* Description: This function is called by the idle task.  This hook has been added to allow you to do
*              such things as STOP the CPU to conserve power.
* Arguments  : none
* Note(s)    : 1) Interrupts are enabled during this call.
#if OS_CPU_HOOKS_EN > 0 && OS_VERSION >= 251
void  OSTaskIdleHook (void)
*                                           STATISTIC TASK HOOK
* Description: This function is called every second by uC/OS-II's statistics task.  This allows your
*              application to add functionality to the statistics task.
* Arguments  : none
void  OSTaskStatHook (void)
/*$PAGE*/
*                                       INITIALIZE A TASK'S STACK
* Description: This function is called by either OSTaskCreate() or OSTaskCreateExt() to initialize the
*              stack frame of the task being created. This function is highly processor specific.
* Arguments  : task          is a pointer to the task code
*              p_arg         is a pointer to a user supplied data area that will be passed to the task
*                            when the task first executes.
*              ptos          is a pointer to the top of stack. It is assumed that 'ptos' points to the
*                            highest valid address on the stack.
*              opt           specifies options that can be used to alter the behavior of OSTaskStkInit().
*                            (see uCOS_II.H for OS_TASK_OPT_???).
* Returns    : Always returns the location of the new top-of-stack' once the processor registers have
*              been placed on the stack in the proper order.
* Note(s)    : Interrupts are enabled when your task starts executing. You can change this by setting the
*              SREG to 0x00 instead. In this case, interrupts would be disabled upon task startup. The
*              application code would be responsible for enabling interrupts at the beginning of the task
*              code. You will need to modify OSTaskIdle() and OSTaskStat() so that they enable interrupts.
*              Failure to do this will make your system crash!
*              The AVR return stack is placed OS_TASK_HARD_STK_SIZE bytes before the bottom of the task's
*              stack.
*              (1) IMPORTANT: The ICC compiler handles function pointers by actually passing the pointer
*                             to a location in Flash that actually contains the pointer to the function.
OS_STK *OSTaskStkInit (void (*task)(void *pd), void *pdata, OS_STK *ptos, INT16U opt){
        INT8U  *stk;
    INT8U  *stks;                // Temp. variable used for setting up AVR hardware stack
    INT16U tmp;
    opt     = opt;                        // 'opt' is not used, prevent warning
    stk     = (INT8U *)ptos;                // Wandlung von ptos in Bytezeiger
        // AVR return stack ("hardware stack")
    stks    = (INT8U *)(ptos)-(OS_TASK_STK_SIZE-32);
        // the function address has an extra level of indirection. Fetch the
    // actual address.
    tmp = *(INT16U const *)task;
        // 36 Bytes
    *stks-- = (INT8U)tmp;        //Put task start address on top of hardware stack
    *stks-- = (INT8U)(tmp >> 8);
    *stk-- = (INT8U)0x00;                // R0  = 0x00
    *stk-- = (INT8U)0x01;
    *stk-- = (INT8U)0x02;
    *stk-- = (INT8U)0x03;
    *stk-- = (INT8U)0x04;
    *stk-- = (INT8U)0x05;
    *stk-- = (INT8U)0x06;
    *stk-- = (INT8U)0x07;
    *stk-- = (INT8U)0x08;
    *stk-- = (INT8U)0x09;
    *stk-- = (INT8U)0x10;
    *stk-- = (INT8U)0x11;
    *stk-- = (INT8U)0x12;
    *stk-- = (INT8U)0x13;
    *stk-- = (INT8U)0x14;
    *stk-- = (INT8U)0x15;
    tmp    = (INT16U)pdata;
    *stk-- = (INT8U)tmp;        //Simulate call to function with argument
    *stk-- = (INT8U)(tmp >> 8);
    *stk-- = (INT8U)0x18;
    *stk-- = (INT8U)0x19;
    *stk-- = (INT8U)0x20;
    *stk-- = (INT8U)0x21;
    *stk-- = (INT8U)0x22;
    *stk-- = (INT8U)0x23;
    *stk-- = (INT8U)0x24;
    *stk-- = (INT8U)0x25;
    *stk-- = (INT8U)0x26;
    *stk-- = (INT8U)0x27;
        // the heap pointer Y=R29:R28 will not be stored
    *stk-- = (INT8U)0x30;
    *stk-- = (INT8U)0x31;
//    *stk-- = (INT8U)0x3B;
    *stk-- = (INT8U)0x80;        //SREG = Interrupts enabled
    tmp    = (INT16U)(stks);
    *stk   = (INT8U)(tmp);
    return ((void *)stk);
/*$PAGE*/
*                                           TASK SWITCH HOOK
* Description: This function is called when a task switch is performed.  This allows you to perform other
*              operations during a context switch.
* Arguments  : none
*              2) It is assumed that the global pointer 'OSTCBHighRdy' points to the TCB of the task that
*                 will be 'switched in' (i.e. the highest priority task) and, 'OSTCBCur' points to the
*                 task being switched out (i.e. the preempted task).
#if (OS_CPU_HOOKS_EN > 0) && (OS_TASK_SW_HOOK_EN > 0)
void  OSTaskSwHook (void)
    OSView_TaskSwHook();
*                                           OS_TCBInit() HOOK
* Description: This function is called by OS_TCBInit() after setting up most of the TCB.
* Arguments  : ptcb    is a pointer to the TCB of the task being created.
* Note(s)    : 1) Interrupts may or may not be ENABLED during this call.
void  OSTCBInitHook (OS_TCB *ptcb)
    ptcb = ptcb;                                           /* Prevent Compiler warning                 */
*                                               TICK HOOK
* Description: This function is called every tick.
* Arguments  : none
#if (OS_CPU_HOOKS_EN > 0) && (OS_TIME_TICK_HOOK_EN > 0)
void  OSTimeTickHook (void)
    OSView_TickHook();
*                                        SETUP THE TICK RATE
void  OSTickISR_Handler (void)
    OSTimeTick();
void  OSTickISR_Init (void)
        CLI();
        TCNT0   =   0x00;                   /*清零Timer0计数器*/
           OCR0    =   107;//OS_SYS_TIME;          /*每逢1ms产生一次匹配中断*/
           TCCR0A   =   0x05;                   /*工作于输出比较匹配模式,不连接OC0端口,时钟32预分频*/
           TIFR0   |=   0x02;                   /*清除输出比较匹配中断标志位*/
           TIMSK0  |=   0x02;                   /*使能输出比较匹配中断*/
           TCNT0   =   0x00;                   //清零Timer0计数器
           OCR0    =   OS_SYS_TIME;          //每逢1ms产生一次匹配中断
           TCCR0   =   0x03;                   //工作于输出比较匹配模式,不连接OC0端口,时钟32预分频
           TIFR1   |=   0x02;                   //清除输出比较匹配中断标志位
           TIMSK1  |=   0x02;                   //使能输出比较匹配中断
发表于 2010-4-12 19:30:55 | 显示全部楼层
我QQ327741577,能不能加Q交流?
GMT+8, 2024-7-23 17:35
