Related info:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0337g/CHDBJIBF.html
The STKALIGN bit reset value in the Configuration and Control Register at address 0xE000ED14 has been inverted. The reset value is now 1, which means that the stack frame is 8-byte aligned by default. Configuration Control Register.
The generic uC/OS-II Cortex M3 port assumes that stack frame is 4-byte aligned, in order to be consistent
with the port you must cleat the reset value to ‘0’
Regards,
Freddy Torres.
Embedded Software Developer.
Micrium.
Email: Freddy.Torres@Micrium.com |
