发表于 2010-3-22 09:49:22
按钮控件主体(控件类实现过程):
#define BS_PRESSED (1<<0)
//按钮风格
#define BS_NULL (0<<0)
#define BS_IMG (1<<1)
static int PaintButton(HDC hdc,HWND hwnd)
WINDOW *pBN;
GUI_COLOR fr_color,bk_color,bd_color;
COORD x,y;
if(hdc==0) return 0;
if(hwnd==0) return 0;
pBN =HWND2WND(hwnd);
fr_color =pBN->FrColor;
bk_color =pBN->BkColor;
bd_color =pBN->BdColor;
x=0;
y=0;
if(WindowStyle(hwnd,BS_NULL))
FillRaisedRectangle(hdc,x,y,pBN->Rect.dx,pBN->Rect.dy,bk_color);
DrawImage(hdc,x,y,pBN->hImage);
Label(hdc,x,y,pBN->Rect.dx,pBN->Rect.dy,fr_color,RGB_TRANS,RGB_TRANS,CENTER,pBN->Caption);
if(WindowStyle(hwnd,BS_IMG))
IMG_BUTTON_DATA *btn_data;
btn_data =(void*)GetWindowPrivateData(hwnd);
DrawImage(hdc,x,y,btn_data->hImg);
if(WindowStatus(hwnd,WS_FOCUS))
//如果是焦点窗口
DotRectangle(hdc,x+3,y+3,pBN->Rect.dx-6,pBN->Rect.dy-6,fr_color);
static int PaintPressedButton(HDC hdc,HWND hwnd)
WINDOW *pBN;
COORD x,y;
//x =pBN->Rect.x;
//y =pBN->Rect.y;
x=0;
y=0;
FillSunkRectangle(hdc,x,y,pBN->Rect.dx,pBN->Rect.dy,AlphaBlendColor((RGB(0,0,0)),bk_color,96));
Label(hdc,x+3,y+3,pBN->Rect.dx-3,pBN->Rect.dy-3,fr_color,RGB_TRANS,RGB_TRANS,CENTER,pBN->Caption);
DrawImage(hdc,x,y,btn_data->hPressedImg);
static int ButtonDraw(HDC hdc,HWND hwnd)
if(WindowStatus(hwnd,BS_PRESSED))
PaintPressedButton(hdc,hwnd);
PaintButton(hdc,hwnd);
InvalidateRect(hwnd,0,0);
// DebugPrintf("%s -> OnDraw!\n",pBN->Caption);
static int ButtonRelease(HWND hwnd)
WINDOW *pWin;
pWin=HWND2WND(hwnd);
#if GUI_DBG_EN
DebugPrintf("ButtonRelease => '%s' - %08XH\n",pWin->Caption,pWin);
//发送MSG_CLOSE所有子窗口.
pWin=HWND2WND(pWin->hChild);
while(pWin)
SendMessage(WND2HWND(pWin),MSG_CLOSE,0,0);
pWin=pWin->Next;
MemFree((void*)hwnd);
return 1;
static U32 ButtonProc(HWND hwnd,U32 msg,WPARAM wParam,LPARAM lParam)
HDC hdc;
switch(msg)
case MSG_CREATE:
case MSG_LBUTTONDOWN:
// DebugPrintf("'%s' -> MSG_LBUTTONDOWN - %d,%d\n",pBN->Caption,wParam>>16,wParam&0xffff);
if(!WindowStatus(hwnd,BS_PRESSED))
SetWindowStatus(hwnd,BS_PRESSED);
UpdateWindow(hwnd);
KillFocus(GetFocus(hwnd));
if(WindowStyle(hwnd,WS_NCCHILD))
SendMessageToParent(hwnd,MSG_SYSCOMMAND,(BN_CLICKED<<16)|GetWindowID(hwnd),hwnd);
SendMessageToParent(hwnd,MSG_COMMAND,(BN_CLICKED<<16)|GetWindowID(hwnd),hwnd);
case MSG_KILLFOCUS:
// DebugPrintf("'%s' -> MSG_KILLFOCUS\n",pBN->Caption);
case MSG_SETFOCUS:
// DebugPrintf("'%s' -> MSG_SETFOCUS\n",pBN->Caption);
case MSG_LBUTTONUP:
ClrWindowStatus(hwnd,BS_PRESSED);
// DebugPrintf("'%s' -> MSG_LBUTTONUP - %d,%d\n",pBN->Caption,wParam>>16,wParam&0xffff);
UpdateWindow(hwnd);
SendMessageToParent(hwnd,MSG_SYSCOMMAND,(BN_UP<<16)|GetWindowID(hwnd),hwnd);
SendMessageToParent(hwnd,MSG_COMMAND,(BN_UP<<16)|GetWindowID(hwnd),hwnd);
case BM_SETIMAGE:
IMG_BUTTON_DATA *btn;
btn=(void*)GetWindowPrivateData(hwnd);
if(btn)
btn->hImg =(HANDLE)wParam;
btn->hPressedImg =(HANDLE)lParam;
case BM_GETIMAGE:
case MSG_PAINT:
// DebugPrintf("'%s' -> MSG_PAINT\n",pBN->Caption);
hdc =BeginPaint(hwnd);
if(hdc==0) break;
ButtonDraw(hdc,hwnd);
EndPaint(hwnd,hdc);
case MSG_DESTROY:
ButtonRelease(hwnd);
default:
return DefaultWindowProc(hwnd,msg,wParam,lParam);
return MSG_NULL;
static WNDCLASS wnd_class;
void RegisButtonClass(void)
wnd_class.ClassName ="button";
wnd_class.Type =WIN_TYPE_WIDGET;
wnd_class.Style =0;
wnd_class.Proc =ButtonProc;
RegisterWindowClass(&wnd_class);
