最近调试一个小板子,查到ds1302的波形都有,帮忙看一下是不是程序的问题
This program was produced by the
CodeWizardAVR V2.03.4 Standard
Automatic Program Generator
?Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 2010-3-15
Author :
Company :
Comments:
Chip type : ATmega128
Program type : Application
Clock frequency : 11.059200 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 1024
DS1302 接 mega128 的 E 口
#define ds1302_clk PORTE.2
#define ds1302_io PORTE.3
#define ds1302_rst PORTE.4
#include <mega128.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
//DS1302端口定义
#define ddre3 DDRE.3
// USART0 Receiver buffer
#define RX_BUFFER_SIZE0 8
char rx_buffer0[RX_BUFFER_SIZE0];
#if RX_BUFFER_SIZE0<256
unsigned char rx_wr_index0,rx_rd_index0,rx_counter0;
#else
unsigned int rx_wr_index0,rx_rd_index0,rx_counter0;
// This flag is set on USART0 Receiver buffer overflow
bit rx_buffer_overflow0;
// USART0 Receiver interrupt service routine
interrupt [USART0_RXC] void usart0_rx_isr(void)
char status,data;
status=UCSR0A;
data=UDR0;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer0[rx_wr_index0]=data;
if (++rx_wr_index0 == RX_BUFFER_SIZE0) rx_wr_index0=0;
if (++rx_counter0 == RX_BUFFER_SIZE0)
rx_counter0=0;
rx_buffer_overflow0=1;
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART0 Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter0==0);
data=rx_buffer0[rx_rd_index0];
if (++rx_rd_index0 == RX_BUFFER_SIZE0) rx_rd_index0=0;
#asm("cli")
--rx_counter0;
#asm("sei")
return data;
#pragma used-
// USART0 Transmitter buffer
#define TX_BUFFER_SIZE0 8
char tx_buffer0[TX_BUFFER_SIZE0];
#if TX_BUFFER_SIZE0<256
unsigned char tx_wr_index0,tx_rd_index0,tx_counter0;
#else
unsigned int tx_wr_index0,tx_rd_index0,tx_counter0;
// USART0 Transmitter interrupt service routine
interrupt [USART0_TXC] void usart0_tx_isr(void)
if (tx_counter0)
--tx_counter0;
UDR0=tx_buffer0[tx_rd_index0];
if (++tx_rd_index0 == TX_BUFFER_SIZE0) tx_rd_index0=0;
// Write a character to the USART0 Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter0 == TX_BUFFER_SIZE0);
#asm("cli")
if (tx_counter0 || ((UCSR0A & DATA_REGISTER_EMPTY)==0))
tx_buffer0[tx_wr_index0]=c;
if (++tx_wr_index0 == TX_BUFFER_SIZE0) tx_wr_index0=0;
++tx_counter0;
UDR0=c;
#asm("sei")
#pragma used-
// Standard Input/Output functions
#include <stdio.h>
#define uint unsigned int
uint i,j,k;
uchar sec, min,hou,day,mon,yea,date;
// Declare your global variables here
void delay(void);
void clock_out(uchar dd);
uchar clock_in(void);
uchar read_clock(uchar ord);
void write_clock(uchar ord, uchar dd);
void ds1302_init(void);
/**************************主程序*************************************/
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
PORTE=0x00;
DDRE=0x00;
// Port F initialization
// Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=Out Func1=Out Func0=Out
// State7=T State6=T State5=T State4=T State3=0 State2=0 State1=0 State0=0
PORTF=0x00;
DDRF=0x0F;
// Port G initialization
// Func4=In Func3=In Func2=In Func1=In Func0=In
// State4=T State3=T State2=T State1=T State0=T
PORTG=0x00;
DDRG=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
// Compare C Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer 3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
// Timer 3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
ETIMSK=0x00;
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
// USART0 Baud Rate: 9600
UCSR0A=0x00;
UCSR0B=0xD8;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x47;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
ds1302_init();
while (1)
PORTF=0x0F;
delay();
yea = read_clock(0x8d); //year
day = read_clock(0x8b); //day
mon = read_clock(0x89); //month
date= read_clock(0x87); //date
hou = read_clock(0x85); //hour
min = read_clock(0x83); //minute
sec = read_clock(0x81); //second
putchar(yea);
putchar(day);
putchar(mon);
putchar(date);
putchar(hou);
putchar(min);
putchar(sec);
putchar('/n');
PORTF=0x00;
delay();
/**************************子函数*************************************/
* 函数名: delay
* 功能描述: 延时 1 秒
void delay(void)
for(k=0;k<=200;k++)
for(i=0;i<=100;i++)
for(j=0;j<=100;j++)
/*********************DS1302程序***************************************************/
* 函数名称 :clock_out
* 功能描述 :
ddre3=1;
for(i=0;i<8;i++)
ds1302_io=dd&0x01;
ds1302_clk=1;
ds1302_clk=0;
dd>>=1;
* 函数名称 :clock_in
* 功能描述 :
uchar inclock=0;
ddre3=0;
for(i=0;i<7;i++)
if(ds1302_io)
inclock|=0x80;
ds1302_clk=1;
ds1302_clk=0;
inclock>>=1;
return(inclock);
* 函数名称 :read_clock
* 功能描述 :
uchar dd=0;
ds1302_clk=0;
ds1302_rst=0;
ds1302_rst=1;
clock_out(ord);
dd=clock_in();
ds1302_rst=0;
ds1302_clk=1;
return(dd);
* 函数名称 :write_clock
* 功能描述 :
ds1302_clk=0;
ds1302_rst=0;
ds1302_rst=1;
clock_out(ord);
clock_out(dd);
ds1302_rst=0;
ds1302_clk=1;
write_clock(0x8e,0x00); //控制写入WP=0
write_clock(0x90,0xa5);
write_clock(0x8c,0x08);//year
write_clock(0x8a,0x21);//day
write_clock(0x88,0x10);//month
write_clock(0x86,0x22);//date
write_clock(0x84,0x15);//hour
write_clock(0x82,0x56);//minute
write_clock(0x80,0x00);//second
write_clock(0x8e,0x80);
