发表于 2010-3-17 20:22:44
这两天陆陆续续研究了一下,看了网上的一些教程,同样的设置教程中很顺利下载进去了,我的板子却不行。先看看我的FLASH PROGRAMER的设置。
设置 (原文件名:flash pro.JPG)
下面是nios的提示:
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/HANDHELD_DSO_PROJECT_V2.0/HANDHELD_DSO_PROJECT_V2.0/software/new_handheld_
dso/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/HANDHELD_DSO_PROJECT_V2.0/HAN
DHELD_DSO_PROJECT_V2.0/OLD1.sof" --output="OLD1.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=OLD1.
opt D:/HANDHELD_DSO_PROJECT_V2.0/HANDHELD_DSO_PROJECT_V2.0/OLD1.sof OLD1.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 68 megabytes
Info: Processing ended: Wed Mar 17 19:22:35 2010
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:01
Info: Command: quartus_cpf --no_banner --convert OLD1.pof OLD1.rpd
Info: Peak virtual memory: 65 megabytes
Info: Processing ended: Wed Mar 17 19:22:37 2010
Info: Total CPU time (on all processors): 00:00:02
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 --cable='U
SB-Blaster [USB-0]' --device=1 "OLD1.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
EPCS signature read failed
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="OLD1.flash" --input="new_handhel
d_dso.elf" --output="epcs_controller.flash"
# Programming flash with the project
SB-Blaster [USB-0]' --device=1 "epcs_controller.flash"
Leaving target processor paused |
