module segment(
clk,
rst_n,
sw0,
sw1,
sw2,
sw3,
//output
hc_cp,
hc_si
input clk;
input rst_n;
input sw0,sw1,sw2,sw3; //Active low
output hc_cp;
output hc_si;
reg [3:0]data;
integer count;
integer shuaxin;
always @ (posedge clk or negedge rst_n)begin
if (!rst_n)begin
count <= 0;
data <= 4'h0;
end
else begin
if(count==16_000_000)begin
count<=0;
data <= data + 1'b1;
end
else begin
count <= count +1'b1;
end
end
end
if (!rst_n)begin
shuaxin<=0;
end
else begin
if(shuaxin==5000)begin
shuaxin<=0;
hc164_driver hc164_driver_inst(
.clk ( clk ),
.rst_n ( rst_n ),
.led ( 0 ),
.dot ( 0 ),
.seg_value ( {4'd1,data,4'd2,4'd3} ),
.hc_cp ( hc_cp ),
.hc_si ( hc_si )
end
shuaxin<=shuaxin + 1'b1;
end
end
endmodule
// hc164_driver模块
module hc164_driver(
clk, rst_n, led, dot, seg_value, hc_cp, hc_si );
input clk;
input rst_n;
input [3 :0] led;
input [3 :0] dot;
input [15:0] seg_value;
output reg hc_cp; //HC164 Clock input active Rising edges
output hc_si; //HC164 Data input
reg [5 :0] tx_cnt;
reg [6:0] hex2led; //hex-to-seven-segment decoder output
reg [3:0] hc_data_34bit;
reg hc_data_31bit;
wire [15:0] hc_data = {led,hc_data_34bit,hex2led[6:2], hc_data_31bit, hex2led[1:0] };
wire [15:0] hc_data_inv = { hc_data[0],
hc_data[1],hc_data[2],hc_data[3], hc_data[4],
hc_data[5],hc_data[6],hc_data[7], hc_data[8],
hc_data[9],hc_data[10],hc_data[11], hc_data[12],
hc_data[13], hc_data[14], hc_data[15] };
reg [15:0] clk_cnt;
always @ ( posedge clk or negedge rst_n )
if ( !rst_n ) clk_cnt <= 16'd0;
else clk_cnt <= clk_cnt + 1'b1;
reg [1:0] seg_led_num;
if (!rst_n ) seg_led_num <= 2'b00;
else if ( clk_cnt == 16'hFFFF ) seg_led_num <= seg_led_num + 1'b1;
reg [3:0] hex;
always @ ( * )
case ( seg_led_num )
2'b00: hex = seg_value[15:12];
2'b01: hex = seg_value[11:8];
2'b10: hex = seg_value[7:4];
2'b11: hex = seg_value[3:0];
endcase
always @ ( * )
begin
case (hex) //数值
4'h1 : hex2led = 7'b0010_100; //1
4'h2 : hex2led = 7'b1011_011; //2
4'h3 : hex2led = 7'b1011_110; //3
4'h4 : hex2led = 7'b0111_100; //4
4'h5 : hex2led = 7'b1101_110; //5
4'h6 : hex2led = 7'b1101_111; //6
4'h7 : hex2led = 7'b1010_100; //7
4'h8 : hex2led = 7'b1111_111; //8
4'h9 : hex2led = 7'b1111_100; //9
4'hA : hex2led = 7'b1111_101; //A
4'hB : hex2led = 7'b0101_111; //b
4'hC : hex2led = 7'b1100_011; //C
4'hD : hex2led = 7'b0011_111; //d
4'hE : hex2led = 7'b1101_011; //E
4'hF : hex2led = 7'b1101_001; //F
default : hex2led = 7'b1110_111; //0
endcase
end
always @ ( * )
2'b00:hc_data_34bit[3:0] = 4'b0111;
2'b01:hc_data_34bit[3:0] = 4'b1011;
2'b10:hc_data_34bit[3:0] = 4'b1101;
2'b11:hc_data_34bit[3:0] = 4'b1110;
endcase
always @ ( * )
2'b00:hc_data_31bit = dot[3];
2'b01:hc_data_31bit = dot[2];
2'b10:hc_data_31bit = dot[1];
2'b11:hc_data_31bit = dot[0];
endcase
if (!rst_n ) tx_cnt <= 6'd0;
else if ( clk_cnt[15] ) tx_cnt <= 6'd0;
else if ((!clk_cnt[15]) && (tx_cnt <= 6'd32 )) tx_cnt <= tx_cnt + 1'b1;
if (!rst_n) hc_cp <= 1'b0;
else if ( clk_cnt[15] ) hc_cp <= 1'b0;
else if ((!clk_cnt[15]) && (tx_cnt < 6'd32 )) hc_cp <= !hc_cp;
assign hc_si = hc_data_inv[tx_cnt[4:1]];
endmodule |
