发表于 2010-2-8 17:16:29
这个老贵~!Price USD (US Dollar) $ 1595.00
Network BitScope 442 ( BS442N )
![](http://cache.amobbs.com/bbs_upload782111/files_26/ourdev_533094.png)
(原文件名:bs445n.png)
![](http://cache.amobbs.com/bbs_upload782111/files_26/ourdev_533096.jpg)
(原文件名:bs440e.jpg)
BS442N
BS325N
BS325U
BS100U
BS50U
The correct appearance of this website is only visible in graphical browsers that support web standards. We try to ensure our content is accessible to any browser but we recommend you upgrade your web browser if you can.
Product Summary
Order Code ADD TO CART BS442N
Description 100 MHz x 12 channel (4 analog + 8 logic), 40 MS/s, 640 kB buffer, ethernet host interface.
Comment Ethernet, Isolated.
Product Information
BS442N combines 4 analog and 8 synchronized logic channels in one powerful instrument.
If you are interested to purchase the industrial version now click here.
Feature Specification
Analog Inputs [1] 8 (4 x BNC + 4 x POD)
Analog Channels 4 (all capture modes)
Analog Bandwidth [2] 100 MHz
Logic Inputs/Channels 8 (via POD)
Input Impedance 1M/20 pF (BNC), 100K/5 pF (POD)
Input Voltage Range (+/-) 51.3 mV (x10 prescale) to 1kV (x100 probe)
Vertical Scaling 500 uV/Div to 500 V/Div (x100 probe)
Timebase Range [3] 1 nS/Div to 2 S/Div
Post-Trigger Delay 8 uS to 2 hours (programmable)
Input Prescaler [4] x10 and GND reference
Analog Sensitivity 2mV to 40mV (x1, no prescale enabled)
Maximum Sensitivity [5] 200 uV (Time), 50uV (Freq), 10uV (Mean)
Fast Sample Rates 4, 5, 10, 13.5, 20, 25, 33, 40 MS/s
Slow Sample Rates [6] 4 kHz to 1 MHz
Channel Buffer Depth 128 kS x 4 (analog), 128 kS x 8 (logic)
Resolution (Converter) TLC5540 8 bit converter with 6.8 to 7.6 ENOB
Maximum Resolution [7] 13.5 ENOB
Glitch Capture(min) 25 nS
External Trigger Bus Yes (cascadeable, access on front panel)
BitScope Digital Trigger 8 bit combinatorial on logic or A/D output.
High Speed Analog Trigger YES (on any analog input)
Waveform Generator No
Analog Interface 2 x BNC and 2 x POD
Logic Interface 1 x DB25 (inc. logic, analog, data and power)
Display Refresh Rate (max) 50 Hz (single), 25 Hz (mixed), 10 Hz (all channels)
Data Upload Speed (max) 1.2 Mb/s
PC Host Interface 10BaseT Ethernet
Included PC Software BitScope DSO Virtual Instrument Application
Power Requirement [8] 12 VDC @ 750 mA (max), 2.5mm CP
Operating Temperature 0ºC to 50ºC
Storage Temperature -20°C to +60°C
Size (WxHxD) 225x40x165 mm
[1] Analog capture for each channel is selectable from BNC or POD individually.
[2] Input bandwidth refers to the bandwidth of the analog input circuitry and the compensated A/D converter in all but the most sensitive input range.
[3] Timebase speeds faster than 50nS assume equivalent time sampling is used.
[4] User selectable analog input prescaler with x10 gain for use with low level signals or when input bandwidth limiting is required.
[5] Minimum measurable peak-to-peak sinusoidal waveform voltage when both resolution enhancement and input multiplier are enabled, when viewed as a waveform (Time) or viewed as a spectrum (Freq) and the minimum measurable average DC voltage (Mean).
[6] In addition to the fast sample rates, a wide range of slow clock rates are supported. All clock rates support enhanced resolution capture.
[7] Specifies the maximum effective number of bits (ENOB) achieveable with resolution enhancement enabled.
[8] Includes UPP-02 Universal AC adaptor and US power cable as standard.
E&OE
Analog and logic probes are sold seperately. |
