发表于 2010-1-14 13:55:19
和我们刚搞完的FPGA一样,好东西
![](http://cache.amobbs.com/bbs_upload782111/files_25/ourdev_525941.jpg)
(原文件名:512G_top_small.jpg)
U-Boot 2009.11 ( 1月 12 2010 - 13:44:24)
CPU: AMCC PowerPC 460EX Rev. B at 600 MHz (PLB=200 OPB=100 EBC=100)
No Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter enabled
32 kB I-Cache 32 kB D-Cache
Board: XXX PPC460EX Evaluation Board, 2*PCIe, Rev. 13
I2C: ready
DRAM: 256 MB (ECC not enabled, 400 MHz, CL3)
FLASH: 64 MB
NAND: 0 MiB
PCI: Bus Dev VenId DevId Class Int
PCIE0: link is not up.
PCIE1: successfully set as root-complex
02 00 10ee 0007 1180 ff
DTT: 1 is 37 C
DTT: 2 is 56 C
Net: ppc_4xx_eth0, ppc_4xx_eth1
Type run flash_nfs to mount root filesystem over NFS
Hit any key to stop autoboot: 0
Waiting for PHY auto negotiation to complete... done
ENET Speed is 1000 Mbps - FULL duplex connection (EMAC0)
Using ppc_4xx_eth0 device
host 192.168.0.232 is alive
## Starting application at 0xFFC00000 ...
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: AMCC PPC460GT Glacier
Version: VxWorks5.5.1
BSP version: 1.2/1
Creation date: Jan 12 2010, 17:12:05
Press any key to stop auto-boot...
0
auto-booting...
boot device : emac
unit number : 0
processor number : 0
host name : dsphp
file name : ppc460ex/vxworks
inet on ethernet (e) : 192.168.0.71:ffff0000
host inet (h) : 192.168.0.232
user (u) : user
ftp password (pw) : pass
flags (f) : 0x0
target name (tn) : ppc640ex_lt
Attached TCP/IP interface to emac0.
Attaching network interface lo0... done.
Loading... 1173680
Starting at 0x10000...
Attached TCP/IP interface to emac unit 0
Attaching interface lo0...done
Adding 3434 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.5.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.6
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2003
CPU: AMCC PPC460GT Glacier. Processor #0.
Memory Size: 0x10000000. BSP version 1.2/1.
WDB Comm Type: WDB_COMM_END
WDB: Ready.
-> sysPciConfigEnable(1)
value = 168464 = 0x29210 = pciAutoFuncEnable + 0x148
-> pciConfigTopoShow
[0,0,0] type=P2P BRIDGE to [1,0,0]
base/limit:
mem= 0xb0000000/0xb03fffff
preMem=0x00000000a0000000/0x000000009fffffff
I/O= 0xc0000000/0xbfffffff
status=0x0010 ( CAP DEVSEL=0 )
command=0x0007 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE )
base/limit:
[1,0,0] type=DATA ACQUISITION DEV
command=0x0006 ( MEM_ENABLE MASTER_ENABLE )
bar0 in 32-bit mem space @ 0xb0000000
bar1 in 32-bit mem space @ 0xb0200000
value = 0 = 0x0
-> pciDeviceShow 1
Scanning function 0 of each PCI device on bus 1
Using configuration mechanism 0
bus device function vendorID deviceID class
00000001 00000000 00000000 000010ee 00000007 00118000
value = 0 = 0x0
-> pciHeaderShow 1,0,0
vendor ID = 0x10ee
device ID = 0x0007
command register = 0x0006
status register = 0x0010
revision ID = 0x00
class code = 0x11
sub class code = 0x80
programming interface = 0x00
cache line = 0x08
latency time = 0x00
header type = 0x00
BIST = 0x00
base address 0 = 0xb0000000
base address 1 = 0xb0200000
base address 2 = 0x00000000
base address 3 = 0x00000000
base address 4 = 0x00000000
base address 5 = 0x00000000
cardBus CIS pointer = 0x00000000
sub system vendor ID = 0x10ee
sub system ID = 0x0007
expansion ROM base address = 0x00000000
interrupt line = 0x70
interrupt pin = 0x01
min Grant = 0x00
max Latency = 0x00
value = 0 = 0x0
=> run flash_self
## Booting kernel from Legacy Image at fc000000 ...
Image Name: Linux-2.6.25.7-00002-geaaf8db
Created: 2008-06-30 13:53:11 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1547704 Bytes = 1.5 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at fc200000 ...
Image Name: canyonlands ramdisk rev. 004
Created: 2008-10-23 0:55:58 UTC
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 20743506 Bytes = 19.8 MB
## Flattened Device Tree blob at fc1e0000
Booting using the fdt blob at 0xfc1e0000
Uncompressing Kernel Image ... OK
Loading Ramdisk to 0ea8c000, end 0fe54552 ... OK
Loading Device Tree to 00ff9000, end 00fff0b4 ... OK
Using Canyonlands machine description
Linux version 2.6.25.7-00002-geaaf8db (dzu@pollux.denx.de) (gcc version 4.2.2) #1 Mon Jun 30 15:53:04 MEST 2008
Found initrd at 0xcea8c000:0xcfe54552
Zone PFN ranges:
DMA 0 -> 65536
Normal 65536 -> 65536
HighMem 65536 -> 65536
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 65536
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=/dev/ram rw ip=192.168.0.71:192.168.0.232:192.168.0.1:255.255.255.0:canyonlands:eth0:off panic=1 console=ttyS0,115200
UIC0 (32 IRQ sources) at DCR 0xc0
UIC1 (32 IRQ sources) at DCR 0xd0
UIC2 (32 IRQ sources) at DCR 0xe0
UIC3 (32 IRQ sources) at DCR 0xf0
PID hash table entries: 1024 (order: 10, 4096 bytes)
clocksource: timebase mult[6aaaab] shift[22] registered
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 235904k/262144k available (3060k kernel code, 25896k reserved, 120k data, 140k bss, 156k init)
SLUB: Genslabs=10, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
net_namespace: 152 bytes
256k L2-cache enabled
PCIE0: Checking link...
PCIE0: No device detected.
PCI host bridge /plb/pciex@d00000000 (primary) ranges:
MEM 0x0000000e00000000..0x0000000e7fffffff -> 0x0000000080000000
IO 0x0000000f80000000..0x0000000f8000ffff -> 0x0000000000000000
4xx PCI DMA offset set to 0x00000000
PCIE0: successfully set as root-complex
PCIE1: Checking link...
PCIE1: Device detected, waiting for link...
PCIE1: link is up !
PCI host bridge /plb/pciex@d20000000 (primary) ranges:
MEM 0x0000000e80000000..0x0000000effffffff -> 0x0000000080000000
IO 0x0000000f80010000..0x0000000f8001ffff -> 0x0000000000000000
PCI host bridge /plb/pci@c0ec00000 (primary) ranges:
MEM 0x0000000d80000000..0x0000000dffffffff -> 0x0000000080000000
IO 0x0000000c08000000..0x0000000c0800ffff -> 0x0000000000000000
PCI: Probing PCI hardware
PCI: Hiding 4xx host bridge resources 0000:40:00.0
PCI: Hiding 4xx host bridge resources 0001:80:00.0
PCI: Bridge: 0000:40:00.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
PCI: Bridge: 0001:80:00.0
MEM window: 0x80000000-0x802fffff
PREFETCH window: 0x0000000080300000-0x00000000803fffff
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 20257k freed
SATA port disabled via device-tree
JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4ef600300 (irq = 19) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x4ef600400 (irq = 20) is a 16550A
serial8250.0: ttyS2 at MMIO 0x4ef600500 (irq = 29) is a 16550A
serial8250.0: ttyS3 at MMIO 0x4ef600600 (irq = 21) is a 16550A
4ef600300.serial: ttyS0 at MMIO 0x4ef600300 (irq = 19) is a 16550A
4ef600400.serial: ttyS1 at MMIO 0x4ef600400 (irq = 20) is a 16550A
4ef600500.serial: ttyS2 at MMIO 0x4ef600500 (irq = 29) is a 16550A
4ef600600.serial: ttyS3 at MMIO 0x4ef600600 (irq = 21) is a 16550A
brd: module loaded
PPC 4xx OCP EMAC driver, version 3.54
MAL v2 /plb/mcmal, 2 TX channels, 16 RX channels
ZMII /plb/opb/emac-zmii@ef600d00 initialized
RGMII /plb/opb/emac-rgmii@ef601500 initialized with MDIO support
TAH /plb/opb/emac-tah@ef601350 initialized
TAH /plb/opb/emac-tah@ef601450 initialized
/plb/opb/emac-rgmii@ef601500: input 0 in RGMII mode
eth0: EMAC-0 /plb/opb/ethernet@ef600e00, MAC 00:10:ec:01:01:fc
eth0: found Generic MII PHY (0x00)
/plb/opb/emac-rgmii@ef601500: input 1 in RGMII mode
eth1: EMAC-1 /plb/opb/ethernet@ef600f00, MAC 00:10:ec:02:01:fc
eth1: found Generic MII PHY (0x01)
Driver 'sd' needs updating - please use bus_type methods
4cc000000.nor_flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
4cc000000.nor_flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
RedBoot partition parsing not available
Creating 7 MTD partitions on "4cc000000.nor_flash":
0x00000000-0x001e0000 : "kernel"
0x001e0000-0x00200000 : "dtb"
0x00200000-0x01600000 : "ramdisk"
0x01600000-0x01a00000 : "jffs2"
0x01a00000-0x03f60000 : "user"
0x03f60000-0x03fa0000 : "env"
0x03fa0000-0x04000000 : "u-boot"
NDFC NAND Driver initialized. Chip-Rev: 0x00000111
No NAND device found!!!
ppc-of-ohci 4bffd0000.usb: OF OHCI
ppc-of-ohci 4bffd0000.usb: new USB bus registered, assigned bus number 1
ppc-of-ohci 4bffd0000.usb: irq 37, io mem 0x4bffd0000 |
