发表于 2005-1-22 11:55:28
资料:
PRODUCT SPECIFICATIONS
 PHYSICAL DATA
 EXTERNAL DIMENSIONS
 BLOCK DIAGRAM
 ABSOLUTE MAXIMUM RATINGS
 ELECTRICAL CHARACTERISTICS
 OPERATING PRINCIPLES  METHODS
 DISPLAY DATA RAM ADDRESS MAP
 ELECTRO-OPTICAL CHARACTERISTICS
 INTERFACE PIN CONNECTIONS
 PART LIST
 RELIABILITY
 QUALITY GUARANTEE
 INSPECTION CRITERIA
 PRECAUTIONS FOR USING LCD MODULES
 USING LCD MODULES
 PHYSICAL DATA
Item Contents Unit
LCD type STN ---
LCD duty 1/64 ---
LCD bias 1/9 ---
Viewing direction 6 o’clock
Module size (WHT) 78  70  14.5MAX (3.07  2.76  0.57MAX) mm
Viewing area (WH) 62  58 (2.46  2.28) mm
Number of dots 128  64 dots
Dot size (WH) 0.39  0.55 (0.015  0.022) mm
Dot pitch (WH) 0.44  0.60 (0.017  0.024) mm
 BLOCK DIAGRAM
 ABSOLUTE MAXIMUM RATINGS ( Ta = 25°C )
Parameter Symbol Min Max Unit
Supply voltage for logic VDD -0.3 7.0 V
Supply voltage for LCD VDD - VO -0.3 VDD+0.3 V
Input voltage VI -0.3 VDD+0.3 V
Operating temperature TOP -20 70 C
Storage temperature TST -30 80 C
 ELECTRICAL CHARACTERISTICS ( VDD = +5V5% , VSS = 0V, Ta = 25°C )
u DC Characteristics
Parameter Symbol Condition Min Typ Max Unit
Supply voltage for logic VDD --- 4.5 5.0 5.5 V
Supply current for logic IDD --- --- 2.62 4 mA
-20°C 12.1 12.6 13.1 V
Operating voltage for LCD VDD - VO 25°C 9.8 10.3 10.8 V
70°C 9.1 9.6 10.1 V
Supply voltage for back light VF --- --- 4.2 4.6 V
Supply current for back light IF VF=4.2V --- 500 840 mA
Input voltage ' H ' level VIH --- 0.7VDD --- VDD V
Input voltage ' L ' level VIL --- 0 --- 0.3VDD V
u AC Characteristics
 MPU Interface
Characteristic Symbol Min Typ Max Unit
E cycle tcyc 1000 --- --- ns
E high level width twhE 450 --- --- ns
E low level width twlE 450 --- --- ns
E rise time tr --- --- 25 ns
E fall time tf --- --- 25 ns
Address set-up time tas 140 --- --- ns
Address hold time tah 10 --- --- ns
Data set-up time tdsw 200 --- --- ns
Data delay time tddr --- --- 320 ns
Data hold time(write) tdhw 10 --- --- ns
Data hold time(read) tdhr 20 --- --- ns
MPU Write Timing
MPU Read Timing
u I/O Buffer
Input buffer controls the status between the enable and disable of chip. Unless the CS1 or CS2 is in active mode, input or output of data and instruction do not execute. Therefore internal state is not changed. But RSTB can operate regardless of CS1 and CS2.
u Input Register
Input register is provided to interface with MPU which is different operating frequency. Input register stores the data temporarily before writing it into display data RAM.
When CS1 or CS2 is in the active mode, R/W and RS select the input register. The data from MPU is written into input register and then write it into display data RAM. Data is latched when falling of the E signal and written automatically into the display data RAM by internal operation.
u Output Register
Output register stores the data temporarily from display data RAM when CS1 or CS2 is in active mode and R/W and RS=H. Stored data in display data RAM is latched in output register. When CS1 or CS2 is in active mode and R/W=H, RS=L, status data (busy check)can be read out.
To read the contents of display data RAM, twice access of read instruction is needed. In first access, data in display data RAM is latched into output register. In second access, MPU can read data which is latched. That is, to read the data in display data RAM, it needs dummy read. But status read does not need dummy read.
RS R/W Function
0 0 Instruction
1 Status read(busy cheek)
1 0 Data write(from input register to display data RAM
1 Data read(from display data RAM to output register)
u Reset
System reset can be initialized by setting RSTB terminal at low level when turning power on, receiving instruction from MPU. When RSTB becomes low, following procedure is occurred.
- Display off
- Display start line register becone set by 0.(Z-address 0)
While RSTB is low level, no instruction except status read can be accepted. Reset status appears at DB4. After DB4 is low, any instruction can be accepted.
The Conditions of power supply at initial power up are shown in table 1.
Table 1. Power Supply Initial Conditions
Item Symbol Min Typ Max Unit
Reset time tRST 1.0 --- --- us
Rise time tr --- --- 200 ns
u Busy Flag
Busy flag indicates that KS0108B is operating or not operating. When busy flag is high, KS0108B is in internal operating. When busy flag is low, KS0108B can accept the data or instruction.
DB7 indicates busy flag of the KS0108B.
u Display ON/OFF Flip-Flop
The display on/off flip-flop makes on/off of the liquid crystal display. When flip-flop is reset (logical low). selective voltage or non selective voltage appears on segment output terminals. When flip-flop is set (logical high).non selective voltage appears on segment output terminals regardless of display RAM data.
The display on/off flip-flop can change status by instruction. The display data at all segment disappear while RSTB is low. The status of the flip-flop is output to DB5 by read instruction.
u X page Register
X page register designates page of the internal display data RAM. It has not count function. An address is set by instruction.
u Y Address Counter
Y address counter designates address of the internal display data RAM. An address is set by instruction and is increased by 1 automatically by read or write operations of display data.
u Display Data RAM
Display data RAM stores a display data for liquid crystal display. To express on state of dot matrix of liquid crystal display. write data 1. The other way. off state writes 0.
u Display Start Line Register
The display start line register indicates address of display data RAM to display top line of liquid crystal display. Bit data (DB<0:5>) of the display start line set instruction is latched in display start line register. It is used for scrolling of the liquid crystal display screen.
u Display Control Instruction
The display control instructions control the internal state of the KS0108B. Instruction is received fom MPU to KS0108B for the display control. The following table shows various instructions.
Instruction RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 Function
Display ON/OFF 0 0 0 0 1 1 1 1 1 0/1 Controls the display on or off. Internal status and display RAM data are not affected.
0:OFF, 1:ON
Set Address 0 0 0 1 Y address (063) Sets the Y address in the Y address counter.
Set Page
(X address) 0 0 1 0 1 1 1 Page
(07) Sets the X address at the X address register.
Display Start Line 0 0 1 1 Display start line
(063) Indicates the display data RAM displayed at the top of the screen.
Status Read 0 1 B
U
S
Y 0 O
N
O
F
F R
E
S
E
T 0 0 0 0 Read status.
BUSY
ON/OFF
RESET
0
1
0
1
0
1
: Ready
: In operation
: Display ON
: Display OFF
: Normal
: Reset
Write Display Data 1 0 Write Data Writes data (DB0:7) into display data RAM. After writing instruction, Y address is increased by 1 automatically.
Read Display Data 1 1 Read Data Reads data (DB0:7) from display data RAM to the data bus.
 ELECTRO-OPTICAL CHARACTERISTICS ( VOP = 13.0V, Ta = 25°C )
Item Symbol Condition Min Typ Max Unit Remarks Note
Response time Tr --- --- 187 --- ms --- 1
Tf --- --- 90 --- ms --- 1
Contrast ratio Cr --- --- 12.7 --- --- --- 2
25 --- --- deg  = 90 3
Viewing angle range  Cr  2 23 --- --- deg  = 270 3
30 --- --- deg  = 0 3
54 --- --- deg  = 180 3
Note1: Definition of response time.
Note2: Definition of contrast ratio ‘Cr’ . Note3: Definition of viewing angle range ‘’.
Pin No. Symbol Level Description
1 CS1 H Chip select signal for KS0108B(1)
2 CS2 H Chip select signal for KS0108B(2)
3 GND 0V Ground
4 VDD 5.0V Supply voltage for logic
5 VO --- Input voltage for LCD
6 D/I H/L H : Data signal, L : Instruction signal
7 R/W H/L H : Read mode, L : Write mode
8 E H, H  L Chip enable signal
9 DB0 H/L Data bit 0
10 DB1 H/L Data bit 1
11 DB2 H/L Data bit 2
12 DB3 H/L Data bit 3
13 DB4 H/L Data bit 4
14 DB5 H/L Data bit 5
15 DB6 H/L Data bit 6
16 DB7 H/L Data bit 7
17 BLA 4.2V Back light anode
18 BLK 0V Back light cathode
 PART LIST
Part Name Description Quantity
IC KS0107B.PCC 1
IC KS0108B.PCC 2
LCD TSD0063-DYFDCW 1
PCB M12864-17A1 1
Frame MG12864-5BB 1
Rubber connector 6.7x8.3x2.6mm YS 2
LED light ED-011YGU 54
 RELIABILITY
 Content of Reliability Test
Environmental Test
No. Test Item Content of Test Test Condition Applicable Standard
1 High temperature storage Endurance test applying the high storage temperature for a long time. 80 C
200 hrs ------
2 Low temperature storage Endurance test applying the low storage temperature for a long time. -30 C
200 hrs ------
3 High temperature operation Endurance test applying the electric stress (Voltage & Current) and the thermal stress to the element for a long time. 70 C
200 hrs
4 Low temperature operation Endurance test applying the electric stress under low temperature for a long time. -20 C
200 hrs ------
5 High temperature  Humidity storage Endurance test applying the high temperature and high humidity storage for a long time. 80 C , 90 RH
96 hrs MIL-202E-103B
JIS-C5023
6 High temperature  Humidity operation Endurance test applying the electric stress (Voltage & Current) and temperature  humidity stress to the element for a long time. 70 C , 90 RH
JIS-C5023
7
Temperature cycle Endurance test applying the low and high temperature cycle.
-20C  70C
10 cycles
Mechanical Test
8 Vibration test Endurance test applying the vibration during transportation and using. 1022Hz  1.5mmp-p
22500Hz  1.5G
Total 0.5hrs MIL-202E-201A
JIS-C5025
JIS-C7022-A-10
9 Shock test Constructional and mechanical endurance test applying the shock during transportation. 50G half sign
wave 1l msedc
3 times of each direction MIL-202E-213B
10 Atmospheric pressure test Endurance test applying the atmospheric pressure during transportation by air. 115 mbar
40 hrs MIL-202E-105C
Others
11 Static electricity test Endurance test applying the electric stress to the terminal. VS=800V , RS=1.5 k
CS=100 pF
1 time MIL-883B-3015.1
 Supply voltage for logic system = 5V. Supply voltage for LCD system = Operating voltage at 25C.
 Failure Judgement Criterion
Criterion Item Test Item No. Failure Judgment Criterion
1 2 3 4 5 6 7 8 9 10 11
Basic specification Out of the Basic Specification
Electrical characteristic Out of the DC and AC Characterstic
Mechanical characterstic Out of the Mechanical Specification Color change : Out of Limit Apperance Specification
Optical characterstic Out of the Apperance Standard
 QUALITY GUARANTEE
 Acceptable Quality Level
Each lot should satisfy the quality level defined as follows.
- Inspection method : MIL-STD-105E LEVEL II Normal one time sampling
- AQL
Partition
AQL Definition
A: Major 0.4% Functional defective as product
B: Minor 1.5% Satisfy all functions as product but not satisfy cosmetic standard
 Definition of ‘LOT’
One lot means the delivery quantity to customer at one time.
 Conditions of Cosmetic Inspection
 Environmental condition
The inspection should be performed at the 1m of height from the LCD module under 2 pieces of 40W white fluorescent lamps (Normal temperature 2025C and normal humidity 6015RH).
 Inspection method
The visual check should be performed vertically at more than 30cm distance from the LCD panel.
 Driving voltage
The VO value which the most optimal contrast can be obtained near the specified VO in the specification. (Within 0.5V of the typical value at 25C.).
 Module Cosmetic Criteria
No. Item Judgement Criterion Partition
1 Difference in Spec. None allowed Major
2 Pattern peeling No substrate pattern peeling and floating Major
3 Soldering defects No soldering missing
No soldering bridge
No cold soldering Major
Major Minor
4 Resist flaw on substrate Invisible copper foil (0.5mm or more) on substrate pattern Minor
5 Accretion of metallic Foreign matter No soldering dust
No accretion of metallic foreign matters (Not exceed 0.2mm) Minor
Minor
6 Stain No stain to spoil cosmetic badly Minor
7 Plate discoloring No plate fading, rusting and discoloring Minor
8
Solder amount
1. Lead parts a. Soldering side of PCB
Solder to form a ‘Filet’
all around the lead.
Solder should not hide the
lead form perfectly. (too much)
b. Components side
( In case of ‘Through Hole PCB’ )
Solder to reach the Components side of PCB.
Minor
2. Flat packages Either ‘toe’ (A) or ‘heal’ (B) of
the lead to be covered by ‘Filet’.
Lead form to be assume over
solder.
Minor
3. Chips (32) H  h  (12) H
Minor
 Screen Cosmetic Criteria (Non-Operating)
No. Defect Judgement Criterion Partition
1 Spots In accordance with Screen Cosmetic Criteria (Operating) No.1. Minor
2 Lines In accordance with Screen Cosmetic Criteria (Operating) No.2. Minor
3
Bubbles in polarizer
Minor
4 Scratch In accordance with spots and lines operating cosmetic criteria. When the light reflects on the panel surface, the scratches are not to be remarkable. Minor
5 Allowable density Above defects should be separated more than 30mm each other. Minor
6 Coloration Not to be noticeable coloration in the viewing area of the LCD panels.
Back-lit type should be judged with back-lit on state only. Minor
7 Contamination Not to be noticeable. Minor
 Screen Cosmetic Criteria (Operating)
1
Spots
A) Clear
Note : Including pin holes and defective dots which must be within one pixel size.
B) Unclear
Minor
2
Lines
A) Clear
Note : ( ) - Acceptable Qty in active area
L - Length (mm)
W - Width (mm)
 - Disregard
B) Unclear
Minor
‘Clear’ = The shade and size are not changed by VO.
‘Unclear’ = The shade and size are changed by VO.
 Screen Cosmetic Criteria (Operating) (Continued)
No.
3 Rubbing line Not to be noticeable.
4 Allowable density Above defects should be separated more than 10mm each other. Minor
5 Rainbow Not to be noticeable. Minor
6 Dot size To be 95  105 of the dot size (Typ.) in drawing.
Partial defects of each dot (ex. pin-hole) should be treated as ‘spot’.
(see Screen Cosmetic Criteria (Operating) No.1) Minor
7
Uneven brightness (only back-lit type module)
Uneven brightness must be BMAX  BMIN  2
- BMAX : Max. value by measure in 5 points
- BMIN : Min. value by measure in 5 points
Divide active area into 4 vertically and horizontally.
Measure 5 points shown in the following figure. Minor
Note :
(1) Size : d = (long length  short length)  2
(2) The limit samples for each item have priority.
(3) Complexed defects are defined item by item, but if the number of defects are defined in above table, the total number should not exceed 10.
(4) In case of ‘concentration’, even the spots or the lines of ‘disregarded’ size should not allowed. Following three situations should be treated as ‘concentration’.
- 7 or over defects in circle of 5mm.
- 10 or over defects in circle of 10mm.
- 20 or over defects in circle of 20mm.
 Handing Precautions
(1) The display panel is made of glass. Do not subject it to a mechanical shock by dropping it or impact.
(2) If the display panel is damaged and the liquid crystal substance leaks out, be sure not to get any in your mouth. If the substance contacts your skin or clothes, wash it off using soap and water.
(3) Do not apply excessive force to the display surface or the adjoining areas since this may cause the color tone to vary.
(4) The polarizer covering the display surface of the LCD module is soft and easily scratched. Handle this polarizer carefully.
(5) If the display surface becomes contaminated, breathe on the surface and gently wipe it with a soft dry cloth. If it is heavily contaminated, moisten cloth with one of the following solvents :
- Isopropyl alcohol
- Ethyl alcohol
(6) Solvents other than those above-mentioned may damage the polarizer. Especially, do not use the following.
- Water
- Ketone
- Aromatic solvents
(7) Exercise care to minimize corrosion of the electrode. Corrosion of the electrodes is accelerated by water droplets, moisture condensation or a current flow in a high-humidity environment.
(8) Install the LCD Module by using the mounting holes. When mounting the LCD module make sure it is free of twisting, warping and distortion. In particular, do not forcibly pull or bend the IO cable or the backlight cable.
(9) Do not attempt to disassemble or process the LCD module.
(10) NC terminal should be open. Do not connect anything.
(11) If the logic circuit power is off, do not apply the input signals.
(12) To prevent destruction of the elements by static electricity, be careful to maintain an optimum work environment.
- Be sure to ground the body when handling the LCD modules.
- Tools required for assembling, such as soldering irons, must be properly grounded.
- To reduce the amount of static electricity generated, do not conduct assembling and other work under dry conditions.
- The LCD module is coated with a film to protect the display surface. Exercise care when peeling off this protective film since static electricity may be generated.
 Storage Precautions
When storing the LCD modules, avoid exposure to direct sunlight or to the light of fluorescent lamps. Keep the modules in bags (avoid high temperature  high humidity and low temperatures below 0C). Whenever possible, the LCD modules should be stored in the same conditions in which they were shipped from our company.
 Others
Liquid crystals solidify under low temperature (below the storage temperature range) leading to defective orientation or the generation of air bubbles (black or white). Air bubbles may also be generated if the module is subject to a low temperature.
If the LCD modules have been operating for a long time showing the same display patterns, the display patterns may remain on the screen as ghost images and a slight contrast irregularity may also appear. A normal operating status can be regained by suspending use for some time. It should be noted that this phenomenon does not adversely affect performance reliability.
To minimize the performance degradation of the LCD modules resulting from destruction caused by static electricity etc., exercise care to avoid holding the following sections when handling the modules.
- Exposed area of the printed circuit board.
- Terminal electrode sections.
 USING LCD MODULES
 Liquid Crystal Display Modules
LCD is composed of glass and polarizer. Pay attention to the following items when handling.
(1) Please keep the temperature within specified range for use and storage. Polarization degradation, bubble generation or polarizer peel-off may occur with high temperature and high humidity.
(2) Do not touch, push or rub the exposed polarizers with anything harder than an HB pencil lead (glass, tweezers, etc.).
(3) N-hexane is recommended for cleaning the adhesives used to attach front/rear polarizers and reflectors made of organic substances which will be damaged by chemicals such as acetone, toluene, ethanol and isopropylalcohol.
(4) When the display surface becomes dusty, wipe gently with absorbent cotton or other soft material like chamois soaked in petroleum benzin. Do not scrub hard to avoid damaging the display surface.
(5) Wipe off saliva or water drops immediately, contact with water over a long period of time may cause deformation or color fading.
(6) Avoid contacting oil and fats.
(7) Condensation on the surface and contact with terminals due to cold will damage, stain or dirty the polarizers. After products are tested at low temperature they must be warmed up in a container before coming is contacting with room temperature air.
(8) Do not put or attach anything on the display area to avoid leaving marks on.
(9) Do not touch the display with bare hands. This will stain the display area and degradate insulation between terminals (some cosmetics are determinated to the polarizers).
(10) As glass is fragile. It tends to become or chipped during handling especially on the edges. Please avoid dropping or jarring.
 Installing LCD Modules
The hole in the printed circuit board is used to fix LCM as shown in the picture below. Attend to the following items when installing the LCM.
(1) Cover the surface with a transparent protective plate to protect the polarizer and LC cell.
(2) When assembling the LCM into other equipment, the spacer to the bit between the LCM and the fitting plate should have enough height to avoid causing stress to the module surface, refer to the individual specifications for measurements. The measurement tolerance should be 0.1mm.
 Precaution for Handing LCD Modules
Since LCM has been assembled and adjusted with a high degree of precision, avoid applying excessive shocks to the module or making any alterations or modifications to it.
(1) Do not alter, modify or change the the shape of the tab on the metal frame.
(2) Do not make extra holes on the printed circuit board, modify its shape or change the positions of components to be attached.
(3) Do not damage or modify the pattern writing on the printed circuit board.
(4) Absolutely do not modify the zebra rubber strip (conductive rubber) or heat seal connector.
(5) Except for soldering the interface, do not make any alterations or modifications with a soldering iron.
(6) Do not drop, bend or twist LCM.
 Electro-Static Discharge Control
Since this module uses a CMOS LSI, the same careful attention should be paid to electrostatic discharge as for an ordinary CMOS IC.
(1) Make certain that you are grounded when handing LCM.
(2) Before remove LCM from its packing case or incorporating it into a set, be sure the module and your body have the same electric potential.
(3) When soldering the terminal of LCM, make certain the AC power source for the soldering iron does not leak.
(4) When using an electric screwdriver to attach LCM, the screwdriver should be of ground potentiality to minimize as much as possible any transmission of electromagnetic waves produced sparks coming from the commutator of the motor.
(5) As far as possible make the electric potential of your work clothes and that of the work bench the ground potential.
(6) To reduce the generation of static electricity be careful that the air in the work is not too dried. A relative humidity of 50%-60% is recommended.
 Precaution for soldering to the LCM
(1) Observe the following when soldering lead wire, connector cable and etc. to the LCM.
- Soldering iron temperature : 280C  10C.
- Soldering time : 3-4 sec.
- Solder : eutectic solder.
If soldering flux is used, be sure to remove any remaining flux after finishing to soldering operation. (This does not apply in the case of a non-halogen type of flux.) It is recommended that you protect the LCD surface with a cover during soldering to prevent any damage dur to flux spatters.
(2) When soldering the electroluminescent panel and PC board, the panel and board should not be detached more than three times. This maximum number is determined by the temperature and time conditions mentioned above, though there may be some variance depending on the temperature of the soldering iron.
(3) When remove the electoluminescent panel from the PC board, be sure the solder has completely melted, the soldered pad on the PC board could be damaged.
 Precautions for Operation
(1) Viewing angle varies with the change of liquid crystal driving voltage (VO). Adjust VO to show the best contrast.
(2) Driving the LCD in the voltage above the limit shortens its life.
(3) Response time is greatly delayed at temperature below the operating temperature range. However, this does not mean the LCD will be out of the order. It will recover when it returns to the specified temperature range.
(4) If the display area is pushed hard during operation, the display will become abnormal. However, it will return to normal if it is turned off and then back on.
(5) Condensation on terminals can cause an electrochemical reaction disrupting the terminal circuit. Therefore, it must be used under the relative condition of 40C , 50% RH.
(6) When turning the power on, input each signal after the positive/negative voltage becomes stable.
 Storage
When storing LCDs as spares for some years, the following precaution are necessary.
(1) Store them in a sealed polyethylene bag. If properly sealed, there is no need for dessicant.
(2) Store them in a dark place. Do not expose to sunlight or fluorescent light, keep the temperature between 0C and 35C.
(3) The polarizer surface should not come in contact with any other objects. (We advise you to store them in the container in which they were shipped.)
(4) Environmental conditions :
- Do not leave them for more than 168hrs. at 60C.
- Should not be left for more than 48hrs. at -20C.
 Safety
(1) It is recommended to crush damaged or unnecessary LCDs into pieces and wash them off with solvents such as acetone and ethanol, which should later be burned.
(2) If any liquid leakes out of a damaged glass cell and comes in contact with the hands, wash off thoroughly with soap and water.
 Limited Warranty
Unless agreed between TRULY and customer, TRULY will replace or repair any of its LCD modules which are found to be functionally defective when inspected in accordance with TRULY LCD acceptance standards (copies available upon request) for a period of one year from date of shipments. Cosmetic/visual defects must be returned to TRULY within 90 days of shipment. Confirmation of such date shall be based on freight documents. The warranty liability of TRULY limited to repair and/or replacement on the terms set forth above. TRULY will not be responsible for any subsequent or consequential events.
 Return LCM under warranty
No warranty can be granted if the precautions stated above have been disregarded. The typical examples of violations are :
- Broken LCD glass.
- PCB eyelet’s damaged or modified.
- PCB conductors damaged.
- Circuit modified in any way, including addition of components.
- PCB tampered with by grinding, engraving or painting varnish.
- soldering to or modifying the bezel in any manner.
Module repairs will be invoiced to the customer upon mutual agreement. Modules must be returned with sufficient description of the failures or defects. Any connectors or cable installed by the customer must be removed completely without damaging the PCB eyelet’s, conductors and terminals.
-----此内容被Gorgon Meducer于2005-01-22,12:00:06编辑过 |
