下了ISE11.1还有11.2,11.3
先装11.1一路升级到11.3,然后在license configuration manager 那里一直不动,等很久也动不了,一直显示 鼠标沙漏;
无奈,删了11.3重装,
先装11.1然后把那个11.1的LIC包进来。然后装11.2 11.3升级,把那个11.1的LIC直接删了用11.3的LIC替换,没有在license configuration manager选11.3的license,11.3的那里一直是鼠标沙漏, 等很久多 SET 多是灰白的,关了。
启动ISE11.3 ,有很多错误
ERROR:PersonalityModule:7 - Unable to open Xilinx data file for Vendor/Device Module "xc9500xl". Please make sure that it has been correctly installed before continuing.
FATAL_ERROR:StaticFileParsers:StaticAcdRead.c:640:1.55 - ACD file .acd does not exists
Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.FATAL_ERROR:StaticFileParsers:StaticAcdRead.c:658:1.55 - Unable to load file or override file "".
Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.INTERNAL_ERROR:PersonalityModule:baspmspec.c:1751:1.79 - Could not load definition file <xc9500xl.acd>
有用11.3的朋友吗? |
