终于找到个开源的 USB 接口的支持 Cotex-M3 的仿真器.
http://www.coocox.org/Index.html
CoLink
点击此处下载 ourdev_503271.pdf(文件大小:28K) (原文件名:Circuit Schematic Diagramc.pdf)
点击此处下载 ourdev_503272.pdf(文件大小:9K) (原文件名:Components List.pdf)
点击此处下载 ourdev_503273.zip(文件大小:74K) (原文件名:Colink_Protel.zip)
![](http://cache.amobbs.com/bbs_upload782111/files_22/ourdev_503267.jpg)
(原文件名:1.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_22/ourdev_503268.jpg)
(原文件名:2.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_22/ourdev_503269.jpg)
(原文件名:3.jpg)
CooCox Colink is a small ARM Cortex M3 JTAG hardware debug probe . CooCox Colink integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK .
CooCox Colink is open, you can Do It Yourself.
* You can directly debug your program without a Colink by using Colink Plugin and the ICDI on the luminary LM35 series board.
Colink Features:
■Supports all Arm Cortex-M3 devices
■Download speed up to 250 KB/sec *
■From 5-pin to 20-pin connector support
■Wide target voltage range: 1.2V - 3.3V, up to 5V with optional probe
■No power supply required, powered through USB
■Plug-and-Play installation using standard Windows USB drivers
■Integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK
* Measured with STM32F103 at 72MHz, 6MHz JTAG speed
Colink supports for the following devices:
■ST STM32 Series
■Atmel AT91SAM3U Series
■NXP LPC17xx Series
■Toshiba TMPM330 Series
■Luminary LM3S Series
Colink support is available in:
■Keil RealView MDK 3.20 or higher
■IAR Workbench 4.42A
Colink Software:
Colink Plugin for IAR Workbench
Colink Plugin for Keil RealView MDK |
