各位前辈!!小弟刚学驱动,写了个按键驱动。当加上去抖动后运行测试程序,串口终端没有任何反应,而且按Ctrl+C也退不出测试程序;当去掉抖动部分后又正常。请求各位能帮我看看是什么地方有错误啊?感激不尽!!程序如下:
驱动代码:
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/fs.h>
#include <linux/poll.h>
#include <linux/interrupt.h>
#include <linux/errno.h>
#include <linux/irq.h>
#include <asm/irq.h>
#include <mach/regs-gpio.h>
#include <mach/hardware.h>
#define DEVICE_NAME "my2440_buttons" //设备名称
#define DEVICE_MAJOR 232 //主设备号
#define KEY_TIMER_DELAY1 (HZ/100) //去抖延时1
#define KEY_TIMER_DELAY2 (HZ/10) //去抖延时2
#define KEY_DOWN 0 //按键按下
#define KEY_UP 1 //按键抬起
#define KEY_UNCERTAIN 2 //按键不确定
#define KEY_COUNT 6 //6个按键
static volatile int ev_press = 0; //中断产出标志
static volatile int key_status[KEY_COUNT]; //记录6个按键的状态
struct timer_list key_timers[KEY_COUNT]; //6个按键去抖动定时器
static DECLARE_WAIT_QUEUE_HEAD(button_waitq); //等待队列
struct button_irq_desc //组织硬件资源结构体
int irq; //中断号
int pin; //引脚
int pin_setting; //引脚配置
int number; //按键索引
char *name; //按键名称
static struct button_irq_desc button_irqs[] = //定义6个按键资源结构体数组
{IRQ_EINT8 , S3C2410_GPG0 , S3C2410_GPG0_EINT8 , 0, "KEY0"},
{IRQ_EINT11, S3C2410_GPG3 , S3C2410_GPG3_EINT11 , 1, "KEY1"},
{IRQ_EINT13, S3C2410_GPG5 , S3C2410_GPG5_EINT13 , 2, "KEY2"},
{IRQ_EINT14, S3C2410_GPG6 , S3C2410_GPG6_EINT14 , 3, "KEY3"},
{IRQ_EINT15, S3C2410_GPG7 , S3C2410_GPG7_EINT15 , 4, "KEY4"},
{IRQ_EINT19, S3C2410_GPG11, S3C2410_GPG11_EINT19, 5, "KEY5"},
static irqreturn_t buttons_interrupt(int irq, void *dev_id)
//获取当前按键的资源数据
struct button_irq_desc *button_irq = (struct button_irq_desc *)dev_id;
//屏蔽当前按键的中断
disable_irq(button_irq->irq);
//设置当前按键按下去抖定时器的延时并启动定时器
key_timers[button_irq->number].expires = jiffies + KEY_TIMER_DELAY1;
add_timer(&key_timers[button_irq->number]);
return IRQ_RETVAL(IRQ_HANDLED);
static void buttons_timer(unsigned long arg)
//获取当前按键的资源数据
int key = arg;
struct button_irq_desc *button_irq = (struct button_irq_desc *)&button_irqs[key];
//获取当前按键引脚上的电平值来判断按键是按下还是抬起
int up = s3c2410_gpio_getpin(button_irq->pin);
if(!up)//低电平,按键按下
if(key_status[key] == KEY_UNCERTAIN)
//标识当前按键状态为按下
key_status[key] = KEY_DOWN;
//标识当前按键的中断已被触发并唤醒等待队列
ev_press = 1;
wake_up_interruptible(&button_waitq);
//设置当前按键抬起去抖定时器的延时并启动定时器
key_timers[key].expires = jiffies + KEY_TIMER_DELAY2;
add_timer(&key_timers[key]);
else//高电平,按键抬起
//标识当前按键状态为抬起
key_status[key] = KEY_UP;
//使能当前按键的中断
enable_irq(button_irqs[key].irq);
static int buttons_open(struct inode *inode, struct file *file)
int i, ret;
for(i = 0; i < KEY_COUNT; i++)
//设置6个IO口为中断触发方式
s3c2410_gpio_cfgpin(button_irqs.pin, button_irqs.pin_setting);
//设置中断下降沿为有效触发
set_irq_type(button_irqs.irq, IRQ_TYPE_EDGE_FALLING);
//申请中断
ret = request_irq(button_irqs.irq, buttons_interrupt, IRQF_DISABLED, button_irqs.name, (void *)&button_irqs);
if(ret)
//初始化6个按键的状态为不确定
key_status = KEY_UNCERTAIN;
//初始化并设置6个去抖定时器
init_timer(&key_timers);
key_timers.function = buttons_timer;
key_timers.data = i;
if(ret)
//中断申请失败处理
i--;
for(; i >= 0; i--)
disable_irq(button_irqs.irq);
free_irq(button_irqs.irq, (void *)&button_irqs);
return -EBUSY;
return 0;
static int buttons_close(struct inode *inode, struct file *file)
int i;
//释放6个定时器和中断
del_timer(&key_timers);
return 0;
static int buttons_read(struct file *file, char __user *buf, size_t count, loff_t *offp)
unsigned long ret;
if(!ev_press)//判断中断发生标识,0没有发生
if(file->f_flags & O_NONBLOCK)
//若采用非阻塞方式读取则返回错误
return -EAGAIN;
//以阻塞方式读取,让等待队列进入睡眠
wait_event_interruptible(button_waitq, ev_press);
//1为发生了中断,并清除0标识,准备给下一次判断用
ev_press = 0;
//将内核中的按键状态数据拷贝到用户空间给应用程序使用
ret = copy_to_user(buf, (void *)key_status, min(sizeof(key_status), count));
//复位6个按键的状态为不确定
memset((void *)key_status, KEY_UNCERTAIN , sizeof(key_status));
return ret ? -EFAULT : min(sizeof(key_status), count);
static int buttons_poll(struct file *file, struct poll_table_struct *wait)
unsigned int mask = 0;
poll_wait(file, &button_waitq, wait);
if(ev_press)
mask |= POLLIN | POLLRDNORM;
return mask;
static struct file_operations buttons_fops =
.owner = THIS_MODULE,
.open = buttons_open,
.release = buttons_close,
.read = buttons_read,
.poll = buttons_poll,
static int __init button_init(void)
int ret;
//注册字符设备
ret = register_chrdev(DEVICE_MAJOR, DEVICE_NAME, &buttons_fops);
if(ret < 0)
printk(DEVICE_NAME " register faild!\n");
return ret;
return 0;
static void __exit button_exit(void)
//注销字符设备
unregister_chrdev(DEVICE_MAJOR, DEVICE_NAME);
module_init(button_init);
module_exit(button_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Huang Gang");
MODULE_DESCRIPTION("My2440 button driver");
测试代码:
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
int main(int argc, char **argv)
int fd;
int key_status[6];
memset(key_status, 2, sizeof(key_status));
fd = open("/dev/my2440_buttons", 0);
if(fd < 0)
printf("Open Buttons Device Faild!\n");
exit(1);
int ret, i;
fd_set rds;
FD_ZERO(&rds);
FD_SET(fd, &rds);
ret = select(fd + 1, &rds, NULL, NULL, NULL);
if(ret < 0)
printf("Read Buttons Device Faild!\n");
exit(1);
if(ret == 0)
printf("Read Buttons Device Timeout!\n");
else if(FD_ISSET(fd, &rds))
ret = read(fd, key_status, sizeof(key_status));
if(ret != sizeof(key_status))
if(errno != EAGAIN)
printf("Read Button Device Faild!\n");
continue;
for(i = 0; i < 6; i++)
if(key_status != 2)
printf("Key%d %s\n", i + 1, (key_status) ? "UP" : "DOWN");
close(fd);
return 0;
