#include <reg52.h>
#include <intrins.h>
void (*current_operation_index)();//
#define uint unsigned int
uchar code datas1[] = {"彭勋"};
uchar code datas2[] = {"马鹏辉"};
uchar code datas3[] = {"河南"};
uchar code datas4[] = {"湘潭"};
uchar code datas5[] = {"返回"};
uchar code datas6[] = {"湖工"};
uchar code datas7[] = {"请稍等"};
uchar func_index;
unsigned char k;
unsigned char keycodetable[]={0xee,0xde,0xbe,0x7e,
0xed,0xdd,0xbd,0x7d,
0xeb,0xdb,0xbb,0x7b};
int i;
sbit dula = P2^6;
sbit wela = P2^7;
//SCM12864-05端口定义
#define LCD_DATA P0 //数据口
sbit RS = P3^5; //并行的指令/数据选择信号, H数据, L命令
sbit RW = P3^6; //并行读写选择信号, H读, L写
sbit E = P3^4; //并行使能端, H有效, L无效
sbit PSB = P3^7; //并/串接口选择, H并,L串
sbit RET = P3^3; //复位, L有效
///12864读写和初始化////////
//延时约2us
void delayUs()
_nop_();_nop_();
//延时 a * 1ms
void delayMs(uint a)
uint i, j;
for(i = a; i > 0; i--)
for(j = 100; j > 0; j--);
//检测LCD是否处于忙状态, 若忙返回1, 空闲返回0
bit checkBusy()
bit busy;
RS = 0;
RW = 1;
E = 1;
delayUs();
busy = (bit)(LCD_DATA&0x80);
E = 0;
return busy;
//等待LCD到空闲
void wait()
while(checkBusy());
//写命令
void WriteCmd(uchar cmd)
wait();
RS = 0;
RW = 0;
E = 0;
delayUs();
LCD_DATA = cmd;
delayUs();
E = 1;
delayUs();
E = 0;
//写数据
void WriteData(uchar dat)
wait();
RS = 1;
RW = 0;
E = 0;
delayUs();
LCD_DATA = dat;
delayUs();
E = 1;
delayUs();
E = 0;
//初始化LCD
void init()
PSB = 1; //并口方式
WriteCmd(0x30); //基本指令, 扩充指令为34H
delayMs(10);
WriteCmd(0x0c); //显示开, 关光标
delayMs(10);
WriteCmd(0x01); //清屏
delayMs(10);
void WriteString(uchar * str)
uchar i = 0;
while(str != '\0')
WriteData(str[i++]);
//////反白函数//////////////////////
//第一.三行反白,传递函数的不同
LcdFill_Leve1(uint c,uint d,uint e)
{ unsigned char x,y,a,b,ii;
for(ii=0;ii<8;ii+=8)
{for(y=0;y<0x10;y++)//行地址
{for(x=0;x<8;x++)
{ //下刘行是使第一行反白
WriteCmd(0x36); //扩充指令 绘图显示
WriteCmd(y+0x80); //行地址
WriteCmd(x+0x80+ii); //列地址
WriteData(c);
WriteData(c);
WriteCmd(0x30); ///可以不要下两行,效果稍差
//下刘行是使第三行不反白
WriteCmd(x+0x80+8); //列地址
WriteData(d);
WriteData(d);
WriteCmd(0x30);
//下面的三个for 是使2,4不反白
for(ii=0;ii<9;ii+=8)
for(a=0x10;a<0x20;a++)
for(b=0;b<8;b++)
WriteCmd(a+0x80); //行地址
WriteCmd(b+0x80+ii); //列地址
WriteData(e);
WriteData(e);
WriteCmd(0x30);
//第二.四行反白
LcdFill_Leve2(uint k,uint j,uint h)
for(x=0;x<8;x++)
WriteData(k);
WriteData(k);
WriteCmd(0x30);
for(b=0;b<8;b++)
WriteData(j);
WriteData(j);
WriteCmd(0x30);
WriteCmd(b+0x88); //列地址
WriteData(h);
WriteData(h);
WriteCmd(0x30);
/**************************************显示函数*****************************************/
void fun0()
void init();
WriteCmd(0x80);
WriteString(datas1);
WriteCmd(0x90);
WriteString(datas2);
WriteCmd(0x88);
WriteString(datas5);
LcdFill_Leve1(0xff,0,0);
void fun1()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteString(datas6);
WriteCmd(0x90);
WriteString(datas4);
WriteCmd(0x88);
void fun2()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
LcdFill_Leve2(0,0xff,0);
}void fun3()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
LcdFill_Leve1(0,0xff,0);
void fun4()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
void fun5()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteString(datas3);
WriteCmd(0x88);
void fun6()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
void fun7()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
void fun8()
void init();
WriteCmd(0x01);
WriteCmd(0x80);
WriteCmd(0x90);
WriteCmd(0x88);
void dengdai()
void init();
WriteCmd(0x01);
WriteCmd(0x90);
WriteString(datas7);
delayMs(1000);
typedef struct
uchar current;
uchar up;
uchar down;
uchar enter;
void (*current_operation)();
} key_table;
key_table code table[56]=
{0,8,4,1,(*fun0)}, //0//第一层,显示[彭勋],马鹏辉,返回
{1,3,2,1,(*fun1)},//1-0按回车,进第二层,显示[湖工],湘潭,返回
{2,1,3,2,(*fun2)},//4-1向下,显示湖工,[湘潭],返回
{3,2,1,0,(*fun3)},//7-4向下,显示湖工,湘潭,[返回]
{4,0,8,5,(*fun4)},//12-0 >down>显示彭勋,[马鹏辉],返回
{5,7,6,5,(*fun5)},//13-12 >enter>[河南],湖工,返回
{6,5,7,6,(*fun6)},//16-13 >down>河南,[湖工],返回
{7,6,5,4,(*fun7)},//19-16 >down>河南,湖工,[返回]
{8,4,0,8,(*fun8)},//22-19 >down>彭勋,马鹏辉,[返回]
delay00(int x)
int i;
while(x--)
for(i=20;i>0;i--)
unsigned int readkey(void)
{ bit mark;
unsigned char keycode,key1;
P2=0XF0;
while(P2!=0XF0)
{ delay00(50);
if(P2!=0XF0){key1=P2;
P2=0X0F;
keycode=key1|P2;
P2=0Xf0;
mark=1;
if(mark){for(i=0;i<12;i++)
if(keycode==keycodetable)return (i);
else return(0xff);
{ void init();
/*******************find index****************************/
switch(readkey())
case 0x1:
func_index=table[func_index].up; //向上翻
case 0x5:
dengdai();
func_index=table[func_index].enter;//回车
WriteCmd(0x01);
case 0x9:
func_index=table[func_index].down;//向下翻
default:
current_operation_index=table[func_index].current_operation;
(*current_operation_index)();//执行当前操作函数
