关于AT89C51的端口扩展。急求哪位高手帮忙解决。我的万年历没有星期显示 ,想再加个星期显示,用的是138扩展的C51的端口 但是不知道对不对
也不知道程序部分怎么改。原图是![](http://cache.amobbs.com/bbs_upload782111/files_21/ourdev_496772.jpg)
原图 (原文件名:123.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_21/ourdev_496773.jpg)
扩展后的图 (原文件名:75B772E6-5D22-48E0-A49D-41BDE57AB93F.jpg)
下面的是源程序:
#define uint unsigned int
#define DQ P3_7
#include<AT89X51.H>
uint sec;
uint min=50;
uint hour=9;
uint day=16;
uint month=12;
uint yearl=8;
uint yearh=20;
uint tcnt;
uint cursor=0;
uchar a=0xff;
uchar code Seg[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(uint t)
uint i;
while(t--)
{for (i=0;i<125;i++);}
void Tdelay(unsigned int i)
while(i--);
void Kdelay()
uchar i,j;
for(i=100;i>0;i--)
for(j=248;j>0;j--);
Init_DS18B20(void)
unsigned char x=0;
DQ = 1;
Tdelay(8);
DQ = 0;
Tdelay(80);
DQ = 1;
Tdelay(14);
Tdelay(20);
//读一个字节
ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0;
dat>>=1;
DQ = 1;
if(DQ)
dat|=0x80;
Tdelay(4);
return(dat);
//写一个字节
WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Tdelay(5);
DQ = 1;
dat>>=1;
//读取温度
ReadTemperature(void)
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5;
return(t);
void display(uchar L1,uchar L2,uchar L3,uchar L4,uchar L5,uchar L6,uchar L7,uchar L8,uchar L9,uchar L10,uchar L11,uchar L12,uchar L13,uchar L14,uchar L15,uchar L16)
P2=0x7F;P0=L1;delay(1); //yearh
P2=0xBF;P0=L2;delay(1); //yearh
if(cursor==6){P2=0xDF|a;P0=L3;delay(1);}else{P2=0xDF;P0=L3;delay(1);} //yearl
if(cursor==6){P2=0xEF|a;P0=L4;delay(1);}else{P2=0xEF;P0=L4;delay(1);} //yearl
if(cursor==5){P2=0xF7|a;P0=L5;delay(1);}else{P2=0xF7;P0=L5;delay(1);} //month
if(cursor==5){P2=0xFB|a;P0=L6;delay(1);}else{P2=0xFB;P0=L6;delay(1);} //month
if(cursor==4){P2=0xFD|a;P0=L7;delay(1);}else{P2=0xFD;P0=L7;delay(1);} //day
if(cursor==4){P2=0xFE|a;P0=L8;delay(1);}else{P2=0xFE;P0=L8;delay(1);} //day
P2=0xFF;
if(cursor==3){P1_0=0x7F|a;P0=L9;delay(1);}else{P1=0x7F;P0=L9;delay(1);} //hour
if(cursor==3){P1_0=0xBF|a;P0=L10;delay(1);}else{P1=0xBF;P0=L10;delay(1);} //hour
if(cursor==2){P1=0xDF|a;P0=L11;delay(1);}else{P1=0xDF;P0=L11;delay(1);} //min
if(cursor==2){P1=0xEF|a;P0=L12;delay(1);}else{P1=0xEF;P0=L12;delay(1);} //min
if(cursor==1){P1=0xF7|a;P0=L13;delay(1);}else{P1=0xF7;P0=L13;delay(1);} //sec
if(cursor==1){P1=0xFB|a;P0=L14;delay(1);}else{P1=0xFB;P0=L14;delay(1);} //sec
P1=0xFD;P0=L15;delay(1); //temp
P1=0xFE;P0=L16;delay(1); //temp
P1=0xFF;
main()
uint i;
TMOD=0x02; //设置模式为定时器T0的模式2 (8位自动重装计数初值的计数值)
TH0=0x06; //设置计数器初值,靠TH0存储重装的计数值X0=256-250=6
TL0=0x06;
TR0=1; //启动T0
ET0=1; //开启定时器T0中断允许
EA=1; //开启中断总控制
if(P3_0==0)
Kdelay();
if(P3_0==0)
cursor++;
if(cursor>=7){cursor=0;}
if(P3_1==0)
Kdelay();
if(P3_1==0)
if(cursor==1){sec++;if(sec==60)sec=0;}
if(cursor==2){min++;if(min==60)min=0;}
if(cursor==3){hour++;if(hour==24)hour=0;}
if(cursor==4){day++;if(day==31)day=0;}
if(cursor==5){month++;if(month==12)month=0;}
if(cursor==6){yearl++;if(yearl==100)yearl=0;}
if(cursor==7){yearh++;if(yearh==30)yearh=20;}
if(P3_2==0)
Kdelay();
if(P3_2==0)
if(cursor==1){sec--;}
if(cursor==2){min--;}
if(cursor==3){hour--;}
if(cursor==4){day--;}
if(cursor==5){month--;}
if(cursor==6){yearl--;}
if(cursor==7){yearh--;}
i=ReadTemperature();
display(Seg[yearh/10],Seg[yearh%10],Seg[yearl/10],Seg[yearl%10],Seg[month/10],Seg[month%10],Seg[day/10],Seg[day%10],Seg[hour/10],Seg[hour%10],Seg[min/10],Seg[min%10],Seg[sec/10],Seg[sec%10],Seg[i/100],Seg[i/10%10]);
void t0(void)interrupt 1 using 0 //t0的中断程序
tcnt++;
if(tcnt==4000)//定时器的定时计数,4000次250us为1秒
tcnt=0;
P3_3=~P3_3;
a=~a;
sec++;
if(sec==60)
sec=0;
min++;
if(min==60)
min=0;
hour++;
if(hour==24)
hour=0;
day++;
if(month==2&&((yearl==0&&yearh%4==0)||(yearl!=0&&yearl%4==0))&&day==30)day=1;
else if(month==2&&day==29)day=1;
else if((month==4||month==6||month==9||month==11)&&day==31)day=1;
else if(day==32)day=1;
if(day==1)
month++;
if(month==13)
month=1;
yearl++;
if(yearl==100)
yearl=0;
yearh++;
if(yearh==100)
yearh=20;
请哪位高手帮忙改下
如果东西部够详细请留下邮箱 我将原文件发过去
十分感谢!!万分感谢!!! |
