我用的44B0X的芯片,公版。
调试时碰到这样的情况:
大部分时候,接上电源程序直接运行,若使用Jlink Flash ARM连接,则出现短暂复位(LED灯闪一下)后继续运行,而且运行正常,串口也能收到消息,但Jlink提示找不到Flash,在MDK中调试时,则复位两次,但运行失败,程序没有下载到存储器内,运行的仍是以前烧入的程序。但偶尔又能碰巧连上烧入了Flash。MDK中烧录调试则一直不正常,一直卡在这里,不知怎么回事。望有经验的坛友指点一二,谢谢!
这是Jlink的输出信息:
Opening data file [C:\Documents and Settings\Administrator\桌面\UART.bin] ...
- Data file opened successfully (20120 bytes, 1 range, CRC = 0x00000000)
Connecting ...
- Connecting via USB to J-Link device 0
- J-Link firmware: V1.20 (J-Link ARM V7 compiled Jun 30 2009 11:05:27)
- JTAG speed: 8000 kHz (Auto)
- Initializing CPU core (Init sequence) ...
- Initialized successfully
- J-Link found 1 JTAG device. Core ID: 0x1F0F0F0F (ARM7)
- Reading CFI info ...
- Could not find CFI compliant flash device
- Detecting flash memory ...
- ERROR: Could not find any flash devices
- ERROR: Failed to connect |
