将白沙兄的代码移植到STM32平台。
我用的是红牛开发板,STM32VEt6
STM32太快了,必须延时才能点亮,刚开始是降频到32MHz时可以点亮,后来在72MHz下通过延时方式实现。
下面是我修改的lcd_code.h
照片拍的不好,A95不知道怎么才能拍微距。
有个问题:显示同样数据,开源LCD的刷新速度大约比我的TFT屏要慢1秒钟左右,不知道是什么原因?
找到问题了,不是刷新速率的问题
是我的数值转换精度出了点问题造成的
![](http://cache.amobbs.com/bbs_upload782111/files_20/ourdev_491703.jpg)
(原文件名:照片.jpg)
//这里是符号对应的显示顺序,也就对应了在HT1621B数据寄存器内的位置
#define _lcd_BUSY 0
#define _lcd_AC 1
#define _lcd_PLUS 2
#define _lcd_F1 3
#define _lcd_ERROR 4
#define _lcd_DC 5
#define _lcd_MINUS 6
#define _lcd_F2 7
#define _lcd_DOT0 12
#define _lcd_AUTO 20
#define _lcd_RUN 24
#define _lcd_PAUSE 25
#define _lcd_DOT1 26
#define _lcd_COLON0 27
#define _lcd_DOT2 32
#define _lcd_STOP 40
#define _lcd_KPA 44
#define _lcd_SETUP 45
#define _lcd_DOT3 46
#define _lcd_COLON1 47
#define _lcd_DOT4 52
#define _lcd_KG 60
#define _lcd_MM 64
#define _lcd_KM 65
#define _lcd_L 66
#define _lcd_M3 67
#define _lcd_DB 68
#define _lcd_PERCENT 69
#define _lcd_OHOM 70
#define _lcd_DEGREE 71
#define _lcd_A 72
#define _lcd_V 73
#define _lcd_MHZ 74
#define _lcd_KW 75
#define _lcd_MA 76
#define _lcd_MV 77
#define _lcd_KHZ 78
#define _lcd_W 79
#define _lcd_NG 80
#define _lcd_OK 81
#define _lcd_RX 82
#define _lcd_TX 83
#define _lcd_FM 84
#define _lcd_PM 85
#define _lcd_AM 86
#define _lcd_CARD 87
#define _lcd_AT3 88
#define _lcd_AT2 89
#define _lcd_AT1 90
#define _lcd_AT0 91
#define _lcd_LOCK 95
#define _lcd_BELL 103
#define _lcd_COLON2 111
#define _lcd_BAT 119
#define _lcd_MAX 124
#define _lcd_MIN 125
#define _lcd_CH 126
#define _lcd_FAULT 127
/*这里是我的测试板的IO口定义,用户可以根据需要修改
p2.2 = data;
p4.0 = cs;
p4.1 = rd
p4.2 = wr
__asm void wait()
nop
nop
nop
nop
nop
nop
BX lr
#define DELAY_COUNTS 0
//下面是根据我的测试板情况定义的,用户可以需要修改
#define CS_LOW {GPIO_ResetBits(GPIOD, GPIO_Pin_8) ;wait();}
#define CS_HIGH {GPIO_SetBits(GPIOD, GPIO_Pin_8) ;wait();}
#define RD_LOW {GPIO_ResetBits(GPIOD, GPIO_Pin_9) ;wait();}
#define RD_HIGH {GPIO_SetBits(GPIOD, GPIO_Pin_9) ;wait();}
#define WR_LOW {GPIO_ResetBits(GPIOD, GPIO_Pin_10);wait();}
#define WR_HIGH {GPIO_SetBits(GPIOD, GPIO_Pin_10) ;wait();}
#define DATA_LOW {GPIO_ResetBits(GPIOD, GPIO_Pin_11) ;wait();}
#define DATA_HIGH {GPIO_SetBits(GPIOD, GPIO_Pin_11) ;wait(); }
static void delay(int iCounts);
//下面是驱动程序定义的一个显示缓冲区,共16个字节,128位
unsigned int lcd_buffer[8]={0,0,0,0,0,0,0,0};
//这个函数可以向HT1621B写入一个命令;用户可能需要在语句间增加必要的延时
void send_lcd_command(unsigned char command)
unsigned short int i;
CS_LOW
WR_LOW //PRESENT 100 COMMAND CODE
DATA_HIGH
WR_HIGH
WR_LOW
DATA_LOW
WR_HIGH
WR_LOW
WR_HIGH
for (i =0;i<=7;i++)
WR_LOW
if ((command & 0x80) !=0)
DATA_HIGH
DATA_LOW
WR_HIGH
command = command << 1;
WR_LOW
WR_HIGH
CS_HIGH
//这个函数可以向HT1621B写入一个数据;用户可能需要在语句间增加必要的延时
void send_lcd_data(unsigned short int address,unsigned short int data)
CS_LOW
WR_LOW //PRESENT 101 DATA CODE
DATA_HIGH
WR_HIGH
WR_LOW
DATA_LOW
WR_HIGH
WR_LOW
DATA_HIGH
WR_HIGH
address = address << 2;
for ( i =0;i<=5;i++)
WR_LOW
if ((address & 0x80) !=0)
DATA_HIGH
DATA_LOW
WR_HIGH
address = address << 1;
for (i =0;i<=3;i++)
WR_LOW
if ((data & 0x01) !=0) DATA_HIGH
else DATA_LOW
WR_HIGH
data = data >> 1;
CS_HIGH
//这个函数可以将显示缓冲区刷新到HT1621B;用户可能需要在语句间增加必要的延时
void flood_lcd_data(void)
unsigned int temp_data;
unsigned short int i,j;
CS_LOW
DATA_HIGH
WR_HIGH
WR_LOW
DATA_LOW
WR_HIGH
WR_LOW
DATA_HIGH
WR_HIGH
for (i =0;i<=5;i++)
WR_LOW
DATA_LOW
WR_HIGH
for (i =0;i<=7;i++)
temp_data = lcd_buffer;
for (j=0;j<=15;j++)
WR_LOW
if ((temp_data & 0x01) !=0) DATA_HIGH
else DATA_LOW
WR_HIGH
temp_data = temp_data >> 1;
CS_HIGH
//初始化HT1621B
void lcd_init(void)
int i;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
send_lcd_command(0x28); //1/2bias,4comm
//for(i=0;i<=1000;i++);
send_lcd_command(0x03); //启动内部振荡器
send_lcd_command(0x01); //打开显示
// RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
//向液晶写一个符号
//name:可直接写0~127的整数,也可以写程序开始定义的标号,如:_lcd_BUSY
//display:符号
void lcd_char(unsigned short int name,unsigned short int display)
i= name/16;
j= name%16;
if (display == 1) lcd_buffer |= 1<<j;
else lcd_buffer &= ~(1<<j);
flood_lcd_data();
//清除全部液晶的显示,同时清空显示缓冲区
void lcd_clr()
int i;
for (i=0; i<=7;i++) lcd_buffer=0;
flood_lcd_data();
//向液晶的数位处写一个0~9的数
//数位为大数码的左至右为0~5,小数码的右至左为6~9;
//number:想显示的数 0~9
//position:显示的数位
//display:显示开关,0 关闭该数位显示(此时number值无效),1 显示该数位数字
void lcd_number(unsigned short int number,unsigned short int position,unsigned short int display )
switch (position)
case 0:
if (display == 0) lcd_buffer[0] &= 0x10ff;
switch (number)
case 0:lcd_buffer[0] |= 0xEB00;
case 1:lcd_buffer[0] |= 0x6000;
case 2:lcd_buffer[0] |= 0xC700;
case 3:lcd_buffer[0] |= 0xE500;
case 4:lcd_buffer[0] |= 0x6C00;
case 5:lcd_buffer[0] |= 0xAD00;
case 6:lcd_buffer[0] |= 0xAF00;
case 7:lcd_buffer[0] |= 0xE000;
case 8:lcd_buffer[0] |= 0xEF00;
case 9:lcd_buffer[0] |= 0xED00;
case 1:
if (display == 0) lcd_buffer[0] &= 0xff10;
lcd_buffer[1] &= 0xff10;
switch (number)
case 0:lcd_buffer[1] |= 0x00EB;
case 1:lcd_buffer[1] |= 0x0060;
case 2:lcd_buffer[1] |= 0x00C7;
case 3:lcd_buffer[1] |= 0x00E5;
case 4:lcd_buffer[1] |= 0x006C;
case 5:lcd_buffer[1] |= 0x00AD;
case 6:lcd_buffer[1] |= 0x00AF;
case 7:lcd_buffer[1] |= 0x00E0;
case 8:lcd_buffer[1] |= 0x00EF;
case 9:lcd_buffer[1] |= 0x00ED;
case 2:
lcd_buffer[1] &= 0x0fff;
lcd_buffer[2] &= 0xfff1;
if (display == 0) break;
else switch (number)
case 0:
lcd_buffer[1] |= 0xB000;
lcd_buffer[2] |= 0x000E;
case 1:
lcd_buffer[2] |= 0x0006;
case 2:
lcd_buffer[1] |= 0x7000;
lcd_buffer[2] |= 0x000C;
case 3:
lcd_buffer[1] |= 0x5000;
case 4:
lcd_buffer[1] |= 0xC000;
case 5:
lcd_buffer[1] |= 0xD000;
lcd_buffer[2] |= 0x000A;
case 6:
lcd_buffer[1] |= 0xF000;
case 7:
lcd_buffer[1] |= 0x0000;
case 8:
case 9:
case 3:
lcd_buffer[2] &= 0xF10F;
case 0:lcd_buffer[2] |= 0x0EB0;
case 1:lcd_buffer[2] |= 0x0600;
case 2:lcd_buffer[2] |= 0x0C70;
case 3:lcd_buffer[2] |= 0x0E50;
case 4:lcd_buffer[2] |= 0x06C0;
case 5:lcd_buffer[2] |= 0x0AD0;
case 6:lcd_buffer[2] |= 0x0AF0;
case 7:lcd_buffer[2] |= 0x0E00;
case 8:lcd_buffer[2] |= 0x0EF0;
case 9:lcd_buffer[2] |= 0x0ED0;
case 4:
lcd_buffer[3] &= 0xFF10;
case 0:lcd_buffer[3] |= 0x00EB;
case 1:lcd_buffer[3] |= 0x0060;
case 2:lcd_buffer[3] |= 0x00C7;
case 3:lcd_buffer[3] |= 0x00E5;
case 4:lcd_buffer[3] |= 0x006C;
case 5:lcd_buffer[3] |= 0x00AD;
case 6:lcd_buffer[3] |= 0x00AF;
case 7:lcd_buffer[3] |= 0x00E0;
case 8:lcd_buffer[3] |= 0x00EF;
case 9:lcd_buffer[3] |= 0x00ED;
case 5:
lcd_buffer[3] &= 0x10FF;
case 0:lcd_buffer[3] |= 0xEB00;
case 1:lcd_buffer[3] |= 0x6000;
case 2:lcd_buffer[3] |= 0xC700;
case 3:lcd_buffer[3] |= 0xE500;
case 4:lcd_buffer[3] |= 0x6C00;
case 5:lcd_buffer[3] |= 0xAD00;
case 6:lcd_buffer[3] |= 0xAF00;
case 7:lcd_buffer[3] |= 0xE000;
case 8:lcd_buffer[3] |= 0xEF00;
case 9:lcd_buffer[3] |= 0xED00;
case 6:
lcd_buffer[5] &= 0x8fff;
lcd_buffer[6] &= 0xfff0;
case 0:
lcd_buffer[5] |= 0x7000;
lcd_buffer[6] |= 0x000D;
case 1:
lcd_buffer[5] |= 0x6000;
case 2:
lcd_buffer[5] |= 0x3000;
lcd_buffer[6] |= 0x000E;
case 3:
lcd_buffer[6] |= 0x000A;
case 4:
lcd_buffer[6] |= 0x0003;
case 5:
lcd_buffer[5] |= 0x5000;
lcd_buffer[6] |= 0x000B;
case 6:
lcd_buffer[6] |= 0x000F;
case 7:
lcd_buffer[6] |= 0x0000;
case 8:
case 9:
case 7:
lcd_buffer[6] &= 0xF08F;
case 0:lcd_buffer[6] |= 0x0D70;
case 1:lcd_buffer[6] |= 0x0060;
case 2:lcd_buffer[6] |= 0x0E30;
case 3:lcd_buffer[6] |= 0x0A70;
case 4:lcd_buffer[6] |= 0x0360;
case 5:lcd_buffer[6] |= 0x0B50;
case 6:lcd_buffer[6] |= 0x0F50;
case 7:lcd_buffer[6] |= 0x0070;
case 8:lcd_buffer[6] |= 0x0F70;
case 9:lcd_buffer[6] |= 0x0B70;
case 8:
lcd_buffer[6] &= 0x8fff;
lcd_buffer[7] &= 0xfff0;
case 0:
lcd_buffer[6] |= 0x7000;
lcd_buffer[7] |= 0x000D;
case 1:
lcd_buffer[6] |= 0x6000;
case 2:
lcd_buffer[6] |= 0x3000;
lcd_buffer[7] |= 0x000E;
case 3:
lcd_buffer[7] |= 0x000A;
case 4:
lcd_buffer[7] |= 0x0003;
case 5:
lcd_buffer[6] |= 0x5000;
lcd_buffer[7] |= 0x000B;
case 6:
lcd_buffer[7] |= 0x000F;
case 7:
lcd_buffer[7] |= 0x0000;
case 8:
case 9:
case 9:
lcd_buffer[7] &= 0xF08F;
case 0:lcd_buffer[7] |= 0x0D70;
case 1:lcd_buffer[7] |= 0x0060;
case 2:lcd_buffer[7] |= 0x0E30;
case 3:lcd_buffer[7] |= 0x0A70;
case 4:lcd_buffer[7] |= 0x0360;
case 5:lcd_buffer[7] |= 0x0B50;
case 6:lcd_buffer[7] |= 0x0F50;
case 7:lcd_buffer[7] |= 0x0070;
case 8:lcd_buffer[7] |= 0x0F70;
case 9:lcd_buffer[7] |= 0x0B70;
flood_lcd_data();
int i;
for(i=0;i<iCounts;i++)
