各位大侠:谁帮我看看!!!
我为什么不能驱动液晶LCD12864呀!
我的硬件连接是这样的:
接线关系为:
----LCD (LCD12864) -------------ARM (s3c2410)--------
DB0~DB7 LDATA0~LDATA7(2410数据总线0-7)
RS ADDR2 (2410地址总线2)
R/W ADDR3 (2410地址总线3)
是LCD的E: GCS2(片选) 控制的
以下是我的程序:
主函数:
void Main(void)
SerialSwitch(0);
SerialChgBaud(115200);
printf("please Enter any key to run test\n");
getch();
LcdPutString( 0,0, "电子工程师之家") ;
子函数:
#define BASE 0x20000000UL
#define WriteComond(base) (*(volatile unsigned short*)(base + 0x00)) //RS=0 RW=0
#defineWriteData(base) (*(volatile unsigned short*)(base + 0x20)) //RS=1 RW=0
#define ReadComond(base) (*(volatile unsigned short*)(base + 0x10)) //RS=0 RW=1
#defineReadData(base) (*(volatile unsigned short*)(base + 0x30)) //RS=1 RW=1
LCD读忙
void LCD_B_Ready(void)
volatile int i;
while (ReadComond(BASE)&0x80)
for(i=0;i<50;i++);
向LCD发送指令
void LCD_B_W_Command(unsigned char Command)
int i;
LCD_B_Ready(); //LCD读忙
WriteComond(BASE) = (unsigned int)Command;
for(i=0; i<50; i++);
向LCD发送数据
void LCD_B_W_Data(unsigned char Data)
int i;
WriteData(BASE) = (unsigned int)Data;
void LcdAddress(unsigned char x,unsigned char y ) //地址转换
unsigned char byAddress ;
switch( y )
case 0 : byAddress = 0x80 + x ;
case 1 : byAddress = 0x90 + x ;
break ;
case 2 : byAddress = 0x88 + x ;
break ;
case 3 : byAddress = 0x98 + x ;
break ;
default :
break ;
LCD_B_W_Command( byAddress ) ;
void LcdPutString( unsigned char x, unsigned char y, unsigned char *pData )
LcdAddress( x, y );
while( *pData != '\0' )
LCD_B_W_Data( *pData++ ) ;
