在44b0X上移植uclinux 2.6.14,以前做过一些碰到问题暂时放下了,今天网上看资料时想到一个自己移植时可能忽略的问题,下午开始动手继续做,终于把sash 跑起来了,以后有空再把网络和文件系统弄上,跑上自己的程序看看稳定不稳定。显示信息如下:
Starting kernel ...
Linux version 2.6.14-hsc0 (root@tpdwyy) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 200
10318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.
com/)) #200 Fri Sep 11 16:42:57 CST 2009
CPU: <NULL> [44b07700]
Machine: S3C44B0X Development Board
Memory management: Non-Paged(unused/noMMU)
Built 1 zonelists
Kernel command line: root=/dev/ram0 rw initrd=0xc800000,1M console=ttyS0 init=/bin/init
PID hash table entries: 128 (order: 7, 2048 bytes)
drivers/serial/serial_s3c44b0.c:628 __s3c44b0_console_init
pdata addr:0xc167830
pdata addr.tty_driver:0xc167854
drivers/serial/serial_s3c44b0.c:595 __s3c44b0_console_setup
this is in drivers/serial/serial_s3c44b0.c:336 __s3c44b0_initdivisor=32
divisor=32
start initrd config
end initrd config
initrd addr=0x0c800000
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 16MB = 16MB total
Memory: 13696KB available (1286K code, 118K data, 76K init)
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
initrd addr in ramfsc=0x0c800000
Freeing initrd memory: 1024K
softlockup thread 0 started up.
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
s3c44b0 serial init!!!!!!!
Samsung S3C44B0X Internal UART0 at I/O 0x1d00000 (irq = 3) is a Samsung S3C44B0X Internal UART
Samsung S3C44B0X Internal UART1 at I/O 0x1d04000 (irq = 2) is a Samsung S3C44B0X Internal UART
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
creat dev
RAMDISK: romfs filesystem found at block 0
RAMDISK: Loading 141KiB [1 disk] into ram disk... done.
VFS: Mounted root (romfs filesystem) readonly.
Mounted devfs on /dev
Freeing init memory: 76K
divisor=32
begin sys_dup
begin if (ramdisk_execute_command)
begin if (execute_command)
begin memset
begin execve
end execve
the ret is 0x0
Shell invoked to run file: /etc/rc
Command: hostname Samsung
Command: /bin/expand /etc/ramfs.img /dev/ram1
in execvp
/bin/expand: Bad command or file name
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Command: dhcpcd &
in execvp
dhcpcd: Bad command or file name
sh 12: Child 14 died
[14]
Execution Finished, Exiting
toks= /bin/sh (null) (null) (null)
tty= console
termcap= linux
tty= console
termcap= linux
Sash command shell (version 1.1.1)
