调用了avrxdelay函数之后不能返回
估计是bug
代码如下:
AVRX_GCC_TASK(task1, 20, 3);
AVRX_GCC_TASK(task2, 20, 1);
AVRX_GCC_TASK(task3, 20, 1);
AVRX_MUTEX(TimerSemaphore); //声明一个信号量
AVRX_TIMER(myTimer);
//TimerControlBlock myTimer,myTimer2,myTimer3;
int main(void)
AvrXSetKernelStack(0);
DS1302_Init();
GUI_Init();
GUI_VarInit();
Key_Init();
MCUCR = _BV(SE); // Initialize Timer Hardware
TCNT0 = TCNT0_INIT;
TCCR0 = TMC8_CK256;
TIMSK = _BV(TOIE0); // Enable Timer overflow interrupt
AvrXRunTask(&task1Tcb);
AvrXRunTask(&task2Tcb);
AvrXRunTask(&task3Tcb);
Epilog(); // Switch from AvrX Stack to first task
while (1);
AVRX_SIGINT(SIG_OVERFLOW0)
IntProlog();
TCNT0 = TCNT0_INIT;
AvrXTimerHandler(); // Call Time queue manager
// while (AvrXIntTestSemaphore(&TimerSemaphore) == SEM_WAIT)
// AvrXIntSetSemaphore(&TimerSemaphore); // Flush all waiting tasks
AvrXIntSetSemaphore(&TimerSemaphore); // Set Semaphore (short path)
Epilog();
NAKEDFUNC(task1)
uint myKey;
uchar Key; //按键
while (1)
AvrXWaitSemaphore(&TimerSemaphore);
if(GUI_Flash)
cli();
GUI_Clear(); //清空
str1=*(pMenu[Language].Text+Item);
str2=*(pMenu[Language].Text+Item+1);
GUI_PutStrAt(str1,0,0);
GUI_PutStrAt(str2,0,1);
if(Where<MaxDispY)
GUI_SetPos(15,Where);
GUI_PutStr("<");
GUI_Flash=0;
sei();
myKey=PINA;
AvrXDelay(&myTimer,20);//<-----------------------------程序会在这里死掉,诸君可以验证
Key=PINA;
if(Key!=myKey)continue;
while(myKey!=0xf0)
myKey=PINA;
myKey&=0xf0;
AvrXDelay(&myTimer,1);
if(myKey!=0xf0)continue;
Key&=0xf0;
cli();
GUI_Clear(); //清空
GUI_PutStrAt("Key=",0,0);
GUI_PutNum(myKey&0xf0);
GUI_PutStrAt("Keytest",0,1);
GUI_PutStr("<");
sei();
continue;
switch (Key)
case UP: //向上键
KeyFuncIndex=KeyTab[KeyFuncIndex].KeyUpState;
KeyFuncPtr=KeyTab[KeyFuncIndex].CurrentOperate;
(*KeyFuncPtr)();//执行当前按键的操作
case DN: //向下键
KeyFuncIndex=KeyTab[KeyFuncIndex].KeyDnState;
case ESC: //返回键
KeyFuncIndex=KeyTab[KeyFuncIndex].KeyEscState;
case ETR: //进入键
KeyFuncIndex=KeyTab[KeyFuncIndex].KeyEtrState;
default:
NAKEDFUNC(task2)
while (1)
NAKEDFUNC(task3)
