问题1:
《第五篇: 完善的协作式的内核 》里面的寄存器变量OSTaskRunningPrio的运算很不对劲!!!
定义方式:register unsigned char OSTaskRunningPrio asm("r3");//正在运行的任务
语 句:OSRdyTbl &= ~(1<<OSTaskRunningPrio);
编译后的汇编结果:
+00000121: 2DE3 MOV R30,R3 Copy register
+00000122: E0F0 LDI R31,0x00 Load immediate
+00000123: E081 LDI R24,0x01 Load immediate
+00000124: E090 LDI R25,0x00 Load immediate
+00000125: C002 RJMP PC+0x0003 Relative jump
+00000126: 0F88 LSL R24 Logical Shift Left
+00000127: 1F99 ROL R25 Rotate Left Through Carry
+00000128: 943A DEC R3 Decrement
+00000129: F7E2 BRPL PC-0x03 Branch if plus
+0000012A: 9580 COM R24 One's complement
+0000012B: 2228 AND R2,R24 Logical AND
“r3”寄存器的值竟然被改的面目全非了!!!后续也没有还原!!!
很恶心的地方!是编译器的问题么?花费了偶2天的时间(汇编菜鸟哈)!
问题2:
原帖地址:http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=574348&bbs_id=3004
里面的任务调度函数压栈的寄存器是不是有点问题啊?
我使用AVR STUDIO 仿真来看中断函数的压栈,如下:
@0000016C: __vector_9
150: {
+0000016C: 921F PUSH R1 Push register on stack
+0000016D: 920F PUSH R0 Push register on stack
+0000016E: B60F IN R0,0x3F In from I/O location
+0000016F: 920F PUSH R0 Push register on stack
+00000170: 2411 CLR R1 Clear Register
+00000171: 932F PUSH R18 Push register on stack
+00000172: 933F PUSH R19 Push register on stack
+00000173: 934F PUSH R20 Push register on stack
+00000174: 935F PUSH R21 Push register on stack
+00000175: 936F PUSH R22 Push register on stack
+00000176: 937F PUSH R23 Push register on stack
+00000177: 938F PUSH R24 Push register on stack
+00000178: 939F PUSH R25 Push register on stack
+00000179: 93EF PUSH R30 Push register on stack
+0000017A: 93FF PUSH R31 Push register on stack
+0000017B: 2D42 MOV R20,R2 Copy register
+0000017C: E6E2 LDI R30,0x62 Load immediate
+0000017D: E0F0 LDI R31,0x00 Load immediate
+0000017E: E020 LDI R18,0x00 Load immediate
但是原帖里面使用的顺序是:
//根据中断时保存寄存器的次序入栈,模拟一次中断后,入栈的情况
__asm__ __volatile__("PUSH __zero_reg__");//R1
__asm__ __volatile__("PUSH __tmp_reg__");//R0
//保存状态寄存器SREG
__asm__ __volatile__("IN __tmp_reg__,__SREG__");//先将SREG转存到temp_reg,再PUSH
__asm__ __volatile__("PUSh __tmp_reg__");//保存状态寄存器SREG
__asm__ __volatile__("CLR __zero_reg__");//重新清零R0临时寄存器
__asm__ __volatile__("PUSH r18");//R18
__asm__ __volatile__("PUSH r19");//R19
__asm__ __volatile__("PUSH r20");//R20
__asm__ __volatile__("PUSH r21");//R21
__asm__ __volatile__("PUSH r22");//R22
__asm__ __volatile__("PUSH r23");//R23
__asm__ __volatile__("PUSH r24");//R24
__asm__ __volatile__("PUSH r25");//R25
__asm__ __volatile__("PUSH r26");//R26
__asm__ __volatile__("PUSH r27");//R27
__asm__ __volatile__("PUSH r30");//R30
__asm__ __volatile__("PUSH r31");//R31
//R28与R29用于建立在堆栈上的指针
__asm__ __volatile__("PUSH r28");//R28
__asm__ __volatile__("PUSH r29");//R29
//入栈完
这里到底应该采用那种方案来压栈和出栈呢?(偶是菜鸟,高手误骂哈~) |
