发表于 2009-8-21 21:44:06
LCD:5.7寸液晶屏FSTN单色
![](http://cache.amobbs.com/bbs_upload782111/files_17/ourdev_473336.jpg)
(原文件名:复制 (1) 从 图片 8中.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_17/ourdev_473337.jpg)
(原文件名:复制 (1) 从 图片 9中.jpg)
型号LTBHBT349H2K
接口定义如下:
1.Vadj (Vo) 对比度调节,负电压 -10V~-22VDC
2.Vee LCD供电,负电压 -23V~-25V
3.Display Data Signal
4.Display Data Signal
5.Display Data Signal
6.Display Data Signal
7.NC
8.Vss
9.Vdd +5V
10. CP2 ,CLK时钟,1.89MHz CLK (528ns period) 50% duty cycle,appears in bursts CLK
11. CP1 ,Input Data Latch Signal,19.3KHz CLK(51.7us period) 16% duty cycle VFRAME,LY,FRM行频
12.S(FLM)Scan Startup Signal场频,75.5Hz CLK(13.2ms period) 0.4% duty cycle即1/240 duty VLINE, LP场频
机械参数:对角线145mm,5.7英寸,x=116,y=87mm,尺寸178X110X8 mm
电气参数:分辨率320 X 240,60cd / m2,0.33X0.33,FSTN / TSTN type,负显,对比度可调,12点钟,Normally Black,黑白,带温度补偿,-20~70℃,常温暨广温高对比液晶
测接口电压如下:
1.Vadj (Vo) 0.29V
2.Vee 0.34V
3.Display Data Signal 5.07V
4.Display Data Signal 5.07V
5.Display Data Signal 5.07V
6.Display Data Signal 5.07V
7.NC 0V
8.Vss 0V
9.Vdd 4.8V
10. 2.52V
11. 0.03V
12. 0.00V
好像不对,是否主板有问题? |
