for(dis_i=4;dis_i<10;dis_i++)
dis_send_data[dis_i]|=dis_bianma_6[dis_shuma_6_0]&0xf0;
dis_send_data[dis_i+1]=dis_bianma_6[dis_shuma_6_0]&0x0f;
dis_send_data[3]=(dis_bianma_3[dis_shuma_3_0]>>4)&0x0f;
dis_send_data[2]=(dis_bianma_3[dis_shuma_3_0]<<4)&0xf0;
dis_send_data[2]|=(dis_bianma_3[dis_shuma_3_1]>>4)&0x0f;
dis_send_data[1]=(dis_bianma_3[dis_shuma_3_1]<<4)&0xf0;
dis_send_data[1]|=(dis_bianma_3[dis_shuma_3_2]>>4)&0x0f;
dis_send_data[0]=(dis_bianma_3[dis_shuma_3_2]<<4)&0xf0;
加上这一段就编译不过去,不调用所在子程序能过去,或者注释掉上面一些内容也能编译
编译器
IAR C/C++ Compiler for NEC 78K0 and 78K0S
4.62.1.20009 [Evaluation] (4.62.1.20009)
器件 9222
原来dis_shuma_3_2这些我是数组,改了不用数组也一样,
信息
Building configuration: yibiao - Debug
Updating build tree...
6 file(s) deleted.
yibiao.c
Linking
Error[e16]: Segment NEAR_Z (size: 0x1f align: 0x1) is too long for segment definition. At least 0x1 more bytes needed.
The problem occurred while processing the segment placement command
"-Z(DATA)NEAR_I,NEAR_Z,NEAR_N,HEAP+_HEAP_SIZE=FE00-FE1F", where at the moment of placement the
available memory ranges were "CODE:fe02-fe1f"
Reserved ranges relevant to this placement:
fe00-fe1f NEAR_I
710-727 SADDR_A
760-777 SADDR_A
810-827 NEAR_A
860-867 NEAR_A
890-8a7 NEAR_A
8e0-8e7 NEAR_A
940-94f NEAR_A
a00-a17 NEAR_A
a80-a87 NEAR_A
d60-d77 NEAR_A
e20-e2f NEAR_A
e68-e6f NEAR_A
e98-e9f NEAR_A
ed8-edf NEAR_A
Error while running Linker
Build aborted. |
