//刚学完atmega16,写了个小程序控制电机转速。不知是否正确,有什么缺点错误,多指教
//s1——停止
//s2——低速
//s3——高速
//s4——最大速度
//小弟初出茅庐,望各位仁兄不吝赐教!
//ICC-AVR application builder : 2009-8-4 14:35:24
// Target : M16
// Crystal: 8.0000Mhz
#include <iom16v.h>
#include <macros.h>
#define s1 (PIND&0xfe)
#define s2 (PIND&0xfd)
#define s3 (PIND&0xfb)
#define s4 (PIND&0xf7)
void port_init(void)
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x08; //PWM波输出口——PB3
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0x00; //按键s1,s2,s3,s4对应PD1~4
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
init_devices();
//insert your functional code here...
TCCR0=0x61; //相位修正模式,无分频,上升匹配时OCR0清零,下降匹配时置位OCR0
if(s1==0)
OCR0=0x00; //S1_STOP
TCNT0=0x00;
else if(s2==0)
OCR0=0x4b; //S2-LOW SPEED
TCNT0=0x00;
else if(s3==0)
OCR0=0x96; //S3-HIGH SPEED
TCNT0=0x00;
OCR0=0XFF; //S4-MAX SPEED
TCNT0=0x00;
