#include "ILI9320.h"
const uint color[]={0xF800,0x7E0,0x1F,0xffe0,0x0000,0xffff,0x07ff,0xf81f,0x07e0,0x0eff,
/*红色 橘黄 蓝色 黄色 黑色 白色 青色 紫色 绿色 天蓝*/
0x000F,0x03E0,0x03EF,0x7800};
void DelayNS(uint32 dly)
uint32 i;
for(; dly > 0; dly--)
for(i=0; i<4000; i++);
void LCD_WR_REG(uint index)
CRS();
CCS();
OutData_L(index);
OutData_H(index>>8);
CWR();
SWR();
SSCS();
//SRS();
void LCD_WR_CMD(uint index,uint val)
CRS();
CCS();
OutData_L(index);
CWR();
SWR();
//SSCS();
SRS();
//CCS();
OutData_L(val);
OutData_H(val>>8);
CWR();
SWR();
SSCS();
CRS();
void LCD_WR_Data(uint val)
SRS();
CCS();
OutData_L(val);
OutData_H(val>>8);
CWR();
SWR();
SSCS();
void LCD_Init()
PINSEL0 = PINSEL0&0x00000000;
PINSEL1 = PINSEL1&0x00000000;
PINSEL2 = PINSEL2&(~0x08);
IO0DIR = IO0DIR|(1<<RST)|(1<<CS)|(1<<WR)|(1<<RS)|(1<<RD)|(0xff<<16);
IO1DIR = IO1DIR|(0xff<<16);
void LCM_DispInit()
LCD_Init();
SRST();
DelayNS(100);
CRST();
DelayNS(100);
SRST();
DelayNS(100);
LCD_WR_CMD(0x00E5, 0x8000); // Set the internal vcore voltage
LCD_WR_CMD(0x0000, 0x0001); // Start internal OSC.
DelayNS(400);
LCD_WR_CMD(0x0001, 0x0000); // set SS and SM bit
LCD_WR_CMD(0x0002, 0x0700); // set 1 line inversion
LCD_WR_CMD(0x0003, 0x1038); // set GRAM write direction and BGR=1.
LCD_WR_CMD(0x0004, 0x0000); // Resize register
LCD_WR_CMD(0x0008, 0x0202); // set the back porch and front porch
LCD_WR_CMD(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
LCD_WR_CMD(0x000A, 0x0000); // FMARK function
LCD_WR_CMD(0x000C, 0x0000); // RGB interface setting
LCD_WR_CMD(0x000D, 0x0000); // Frame marker Position
LCD_WR_CMD(0x000F, 0x0000); // RGB interface polarity
LCD_WR_CMD(0x002b, 0x0020); //frame rate and color control(0x0000)
//*************Power On sequence ****************
LCD_WR_CMD(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_WR_CMD(0x0011, 0x0004); // DC1[2:0], DC0[2:0], VC[2:0]
LCD_WR_CMD(0x0012, 0x0000); // VREG1OUT voltage
LCD_WR_CMD(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
DelayNS(100); // Dis-charge capacitor power voltage
LCD_WR_CMD(0x0010, 0x17B0); // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_WR_CMD(0x0011, 0x0001); // DC1[2:0], DC0[2:0], VC[2:0]
DelayNS(50); // Delay 50ms
LCD_WR_CMD(0x0012, 0x013e); // VREG1OUT voltage
LCD_WR_CMD(0x0013, 0x1c00); // VDV[4:0] for VCOM amplitude
LCD_WR_CMD(0x0029, 0x001e); // VCM[4:0] for VCOMH
DelayNS(50);
LCD_WR_CMD(0x0020, 0x0000); // GRAM horizontal Address
LCD_WR_CMD(0x0021, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
LCD_WR_CMD(0x0030, 0x0002);
LCD_WR_CMD(0x0031, 0x0606);
LCD_WR_CMD(0x0032, 0x0501);
LCD_WR_CMD(0x0035, 0x0206);
LCD_WR_CMD(0x0036, 0x0504);
LCD_WR_CMD(0x0037, 0x0707);
LCD_WR_CMD(0x0038, 0x0306);
LCD_WR_CMD(0x0039, 0x0007);
LCD_WR_CMD(0x003C, 0x0700);
LCD_WR_CMD(0x003D, 0x0700);
//------------------ Set GRAM area ---------------//
LCD_WR_CMD(0x0050, 0x0000); // Horizontal GRAM Start Address
LCD_WR_CMD(0x0051, 0x00EF); // Horizontal GRAM End Address
LCD_WR_CMD(0x0052, 0x0000); // Vertical GRAM Start Address
LCD_WR_CMD(0x0053, 0x013F); // Vertical GRAM Start Address
LCD_WR_CMD(0x0060, 0x2700); // Gate Scan Line
LCD_WR_CMD(0x0061, 0x0001); // NDL,VLE, REV
LCD_WR_CMD(0x006A, 0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
LCD_WR_CMD(0x0080, 0x0000);
LCD_WR_CMD(0x0081, 0x0000);
LCD_WR_CMD(0x0082, 0x0000);
LCD_WR_CMD(0x0083, 0x0000);
LCD_WR_CMD(0x0084, 0x0000);
LCD_WR_CMD(0x0085, 0x0000);
//-------------- Panel Control -------------------//
LCD_WR_CMD(0x0090, 0x0010);
LCD_WR_CMD(0x0092, 0x0000);
LCD_WR_CMD(0x0093, 0x0003);
LCD_WR_CMD(0x0095, 0x0110);
LCD_WR_CMD(0x0097, 0x0000);
LCD_WR_CMD(0x0098, 0x0000);
LCD_WR_CMD(0x0007, 0x0173); // 262K color and display ON
LCD_WR_REG(0x0022);
void lcd_bk()
uint16 temp,n,num;
// temp=color[bk];
LCD_WR_CMD(0x20,0); //0-239
LCD_WR_CMD(0x21,0); //0-319
LCD_WR_REG(0x0022);
for (n=0;n<320;n++)
for (num=0;num<240;num++)
LCD_WR_Data(0xffff);
DelayNS(50);
int main (void)
LCM_DispInit();
lcd_bk();
DelayNS(100);
return 0;
我这样做,一直不能正常的现实,其实为只是测测屏,保证屏是好的。但是不知道我这么做有什么地方不对的吗?请指教下,谢谢了! |
