无论如何1602就是不亮,下面是我的程序
#include <avr\io.h>
#include <avr\delay.h>
#include <avr\interrupt.h>
#define LCD_EN_PORT PORTA //以下2个要设为同一个口
#define LCD_EN_DDR DDRA
#define LCD_RS_PORT PORTA //以下2个要设为同一个口
#define LCD_RS_DDR DDRA
#define LCD_DATA_PORT PORTA //以下3个要设为同一个口
#define LCD_DATA_DDR DDRA //一定要用高4位
#define LCD_DATA_PIN PINA
#define LCD_RS (1<<PA2) //0x04 portA2 out
#define LCD_EN (1<<PA3) //0x08 portA3 out
#define LCD_DATA ((1<<PA4)|(1<<PA5)|(1<<PA6)|(1<<PA7)) //0xf0 portA4/5/6/7 out
void LCD_init(void);
void LCD_en_write(void);
void LCD_write_command(unsigned char command) ;
void LCD_write_data(unsigned char data);
void LCD_set_xy (unsigned char x, unsigned char y);
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char data);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
void delay_1us(void) //1us延时函数
asm("nop");
void delay_nus(unsigned int n) //N us延时函数
unsigned int i=0;
for (i=0;i<n;i++)
delay_1us();
void delay_1ms(void) //1ms延时函数
unsigned int i;
for (i=0;i<1140;i++);
void delay_nms(unsigned int n) //N ms延时函数
unsigned int i=0;
for (i=0;i<n;i++)
delay_1ms();
void LCD_init(void) //液晶初始化
LCD_DATA_DDR|=LCD_DATA; //数据口方向为输出
LCD_EN_DDR|=LCD_EN; //设置EN方向为输出
LCD_RS_DDR|=LCD_RS; //设置RS方向为输出
LCD_write_command(0x28);
LCD_en_write();
delay_nus(40);
LCD_write_command(0x28); //4位显示
LCD_write_command(0x0c); //显示开
LCD_write_command(0x01); //清屏
delay_nms(2);
void LCD_en_write(void) //液晶使能
LCD_EN_PORT|=LCD_EN;
delay_nus(1);
LCD_EN_PORT&=~LCD_EN;
void LCD_write_command(unsigned char command) //写指令
delay_nus(16);
LCD_RS_PORT&=~LCD_RS; //RS=0
LCD_DATA_PORT&=0X0f; //清高四位
LCD_DATA_PORT|=command&0xf0; //写高四位
LCD_en_write();
command=command<<4; //低四位移到高四位
LCD_DATA_PORT&=0x0f; //清高四位
LCD_DATA_PORT|=command&0xf0; //写低四位
LCD_en_write();
void LCD_write_data(unsigned char data) //写数据
delay_nus(16);
LCD_RS_PORT|=LCD_RS; //RS=1
LCD_DATA_PORT|=data&0xf0; //写高四位
LCD_en_write();
data=data<<4; //低四位移到高四位
LCD_DATA_PORT|=data&0xf0; //写低四位
LCD_en_write();
void LCD_set_xy( unsigned char x, unsigned char y ) //写地址函数
unsigned char address;
if (y == 0) address = 0x80 + x;
else address = 0xc0 + x;
LCD_write_command( address);
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s) //列x=0~15,行y=0,1
LCD_set_xy( X, Y ); //写地址
while (*s) // 写显示字符
LCD_write_data( *s );
s ++;
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char data) //列x=0~15,行y=0,1
LCD_write_data( data);
void init_devices(void)
cli(); //disable all interrupts
LCD_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
sei(); //re-enable interrupts
int main(void)
DDRA= 0xff;
init_devices();
LCD_write_string(1,0,"OK");
for(;;)
LCD_write_string(0,1,"HELLO");
LCD_write_char(13,0,'R');
return 0;
