System Requirements(系统要求)
486DX2-66 or later PC compatible computer with at least 4MB RAM and a DOS compatible file system
Open 25-pin parallel port for control
500k free disk space (7M for source code and development tools). TurboCNC can be run from a floppy disk, but a hard drive installation is generally better
A 66 MHz or faster clock speed is recommended for satisfactory performance.
Almost any home or office computer system made after 1993 will meet these requirements. However, some fairly modern industrial control computers may not. Consult your owner's manuals to be sure. TurboCNC will report if any critical things are missing at startup.
For very old computers or those that don't have a math coprocessor, try using version 3.0f of TurboCNC instead. This is available in the web archive for download at http://www.dakeng.com/archive.html and although it lacks many features compared to the later versions, it can and has been used for production grade work on even very old 286-10 machines. In some countries these may be the only computers available to private citizens.
点击此处下载 ourdev_459559.zip(文件大小:5.42M) (原文件名:turbocnc.zip) |
