回复: 15
ULINKPro 出来了!
发表于 2009-7-2 11:32:20 | 显示全部楼层 |阅读模式
ULINKPro Debug and Trace Unit 出来了,多了一个TRACE的功能.
http://www.keil.com/ulink/cmp.asp
发表于 2009-7-2 11:47:08 | 显示全部楼层
ULINK2买来花了3800
ULINKPro will be available September 2009
Pro?难道硬件不支持?还是软件不让升级来支持,强迫买新硬件?
发表于 2009-7-2 12:15:31 | 显示全部楼层
TRACE功能的仿真器好像要能跑到ARM芯片的全速或者半速,一般靠FPGA实现的,以ULINK2的硬件是无法做到的吧。
发表于 2009-7-2 18:29:18 | 显示全部楼层
9月份才出来看到应该都不容易
发表于 2009-11-25 22:27:44 | 显示全部楼层
ULINKPro提供大量的分析功能:
通过逻辑分析仪进行数据分析跟踪
代码覆盖率的统计分析
性能分析器帮助分析和优化代码
发表于 2009-11-26 04:22:32 | 显示全部楼层
"ULINKPro提供大量的分析功能"
what does it do that your existing hardware / software cannot do?
how often do you use those features?
After that analysis, you will quickly come to a clear decision as to if you need to invest in this new tool.
发表于 2009-11-26 09:40:28 | 显示全部楼层
(原文件名:ulinkpro_target_cables.jpg)
发表于 2009-11-26 12:01:38 | 显示全部楼层
MARK
发表于 2009-11-27 22:22:55 | 显示全部楼层
To:【6楼】 SWJ-DP
还是兄弟您强,刚刚推出来,您就让大家看到了庐山真面目。。。有时间可以让XilinxUSB分析一下。
发表于 2009-11-27 22:25:26 | 显示全部楼层
居然是 Virtex-4 + CY7C68013A
发表于 2009-12-4 14:56:51 | 显示全部楼层
to 【8楼】 cznlpy SOPC创业联盟
我没有ULINKPro仿真器
6楼的图片是来自www.keil.com
发表于 2009-12-4 15:06:41 | 显示全部楼层
Features
■Supports ARM7, ARM9, Cortex-M0, Cortex-M1, and Cortex-M3 devices
■JTAG support for ARM7, ARM9, and Cortex-Mx
■Serial Wire Debug (SWD) support for Cortex-Mx
■Serial Wire Viewer (SWV) Data Trace for Cortex-M3
■Instruction Trace (via ETM) for Cortex-M3
■Trace streamed direct to your PC, provides unlimited trace buffer
■USB 2.0 High-Speed (480Mbits/s) connection to your PC
■JTAG Clock Speed up to 50MHz
■Supports Cortex-Mx devices running at up to 200MHz
■High-Speed Flash Download up to 600KBytes/sec
■USB powered (no power supply required)
■Target connectors:
■10-pin (0.05") - Cortex Debug Connector
■20-pin (0.10") - ARM Standard JTAG Connector
■20-pin (0.05") - Cortex Debug+ETM Connector
ULINKPro provides extensive analysis features such as:
■Data Trace analysis via a Logic Analyzer
■Code Coverage information about your programs execution
■Performance Analysis enabling you to efficiently optimize your application
以上摘引自www.keil.com
发表于 2009-12-30 15:56:23 | 显示全部楼层
哈哈,这个估计绝不会有克隆了,竟然带后备电池,看来FPGA的位流是加密的了……
发表于 2011-3-14 16:52:30 | 显示全部楼层
mark
发表于 2014-3-11 18:13:58 | 显示全部楼层
发表于 2017-11-16 13:23:26 | 显示全部楼层
yyccaa 发表于 2009-7-2 12:15
TRACE功能的仿真器好像要能跑到ARM芯片的全速或者半速,一般靠FPGA实现的,以ULINK2的硬件是无法做到的吧。 ...
了解了,谢谢!
GMT+8, 2024-8-25 14:26
