fx1s 程序下载 串口监视数据 原始数据 可分析出协完整协议
客户给偶送来一个FX1s-10mr,正好用来分析其下载协议;
上位机软件fxgp-win-c
串口数据如下:
1:指定步数下载:
SUDT ACCESSPORT LOG FILE - Monitor mode
监控: COM1
创建时间: 2008-06-03, 10:58:29
计算机名:
系统版本: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
# Time Function Data ( Hex )
1 [00000000] IRP_MJ_CREATE Port Opened - W
2 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
3 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
4 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
5 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
6 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 30 31 45 30 30 31 03 36 41
7 [00000002] IRP_MJ_READ Length: 0006, Data: 02 30 41 03 37 34
8 [00000003] IRP_MJ_CLOSE Port Closed
9 [00000000] IRP_MJ_CREATE Port Opened - W74
10 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
11 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
12 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
13 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
14 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 30 45 30 32 30 32 03 36 43
15 [00000002] IRP_MJ_READ Length: 0008, Data: 02 43 37 35 36 03 45 38
16 [00000003] IRP_MJ_CLOSE Port Closed
17 [00000000] IRP_MJ_CREATE Port Opened - W6
18 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
19 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
20 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
21 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
22 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 30 30 32 45 03 37 32
23 [00000002] IRP_MJ_READ Length: 0008, Data: 02 30 32 30 30 32 34 32
24 [00000002] IRP_MJ_READ Length: 0008, Data: 46 30 30 30 30 30 30 30
25 [00000003] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
26 [00000004] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
27 [00000004] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
28 [00000005] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
29 [00000005] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
30 [00000006] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
31 [00000006] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
32 [00000007] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
33 [00000007] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
34 [00000008] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 03 41 46
35 [00000008] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 32 45 32 45 03 38 39
36 [00000010] IRP_MJ_READ Length: 0008, Data: 02 32 30 32 30 46 34 30
37 [00000010] IRP_MJ_READ Length: 0008, Data: 39 46 46 30 42 46 34 30
38 [00000011] IRP_MJ_READ Length: 0008, Data: 31 45 37 30 33 36 34 30
39 [00000011] IRP_MJ_READ Length: 0008, Data: 45 43 37 30 45 44 43 30
40 [00000012] IRP_MJ_READ Length: 0008, Data: 45 46 46 30 45 39 30 30
41 [00000012] IRP_MJ_READ Length: 0008, Data: 31 46 45 30 33 30 30 30
42 [00000013] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
43 [00000013] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
44 [00000014] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
45 [00000015] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
46 [00000015] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
47 [00000016] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 03 45 35
48 [00000016] IRP_MJ_CLOSE Port Closed
49 [00000000] IRP_MJ_CREATE Port Opened - W0
50 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
51 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
52 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
53 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
54 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 30 45 30 36 30 32 03 37 30
55 [00000001] IRP_MJ_READ Length: 0008, Data: 02 31 30 30 30 03 43 34
56 [00000002] IRP_MJ_CLOSE Port Closed
57 [00000000] IRP_MJ_CREATE Port Opened - W0
58 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
59 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
60 [00000001] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
61 [00000001] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
62 [00000001] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 35 43 34 30 03 37 37
63 [00000003] IRP_MJ_READ Length: 0008, Data: 02 30 30 32 38 32 38 30
64 [00000003] IRP_MJ_READ Length: 0008, Data: 30 30 31 38 30 30 30 38
65 [00000004] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
66 [00000005] IRP_MJ_READ Length: 0008, Data: 36 30 30 33 38 32 38 30
67 [00000005] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 30 30 30 38
68 [00000006] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
69 [00000006] IRP_MJ_READ Length: 0008, Data: 36 43 41 30 31 30 30 38
70 [00000007] IRP_MJ_READ Length: 0008, Data: 34 30 30 34 38 31 34 30
71 [00000007] IRP_MJ_READ Length: 0008, Data: 45 39 30 38 36 30 31 38
72 [00000008] IRP_MJ_READ Length: 0008, Data: 36 31 35 30 45 39 32 38
73 [00000008] IRP_MJ_READ Length: 0008, Data: 36 30 31 38 36 31 34 32
74 [00000009] IRP_MJ_READ Length: 0008, Data: 45 30 30 44 35 31 35 32
75 [00000009] IRP_MJ_READ Length: 0008, Data: 45 30 30 45 35 31 34 32
76 [00000010] IRP_MJ_READ Length: 0008, Data: 45 31 35 34 45 30 43 30
77 [00000010] IRP_MJ_READ Length: 0008, Data: 30 31 34 38 45 30 43 30
78 [00000011] IRP_MJ_READ Length: 0008, Data: 30 31 35 38 45 34 30 30
79 [00000011] IRP_MJ_READ Length: 0004, Data: 30 03 35 42
80 [00000011] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 39 43 33 41 03 38 42
81 [00000013] IRP_MJ_READ Length: 0008, Data: 02 39 36 38 36 30 31 38
82 [00000014] IRP_MJ_READ Length: 0008, Data: 36 46 46 46 46 46 46 46
83 [00000014] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
84 [00000015] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
85 [00000015] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
86 [00000016] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
87 [00000016] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
88 [00000017] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
89 [00000017] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
90 [00000018] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
91 [00000018] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
92 [00000019] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
93 [00000019] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
94 [00000020] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
95 [00000021] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 03 33 37
96 [00000021] IRP_MJ_CLOSE Port Closed
97 [00000000] IRP_MJ_CREATE Port Opened - WF
98 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
99 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
100 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
101 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
102 [00000008] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 30 35 43 34 30 30 30 32 38 32 38 30 30 30 31 38 30 30 30 38 30 30 30 38 36 30 30 38 36 30 30 33 38 32 38 30 30 30 30 38 30 30 30 38 30 30 30 38 36 30 30 38 36 43 41 30 31 30 30 38 34 30 30 34 38 31 34 30 45 39 30 38 36 30 31 38 36 31 35 30 45 39 32 38 36 30 31 38 36 31 34 32 45 30 30 44 35 31 35 32 45 30 30 45 35 31 34 32 45 31 35 34 45 30 43 30 30 31 34 38 45 30 43 30 30 31 35 38 45 34 30 30 30 03 44 30
103 [00000012] IRP_MJ_READ Length: 0001, Data: 06
104 [00000015] IRP_MJ_WRITE Length: 0047, Data: 02 31 38 30 39 43 31 32 39 36 38 36 30 31 38 36 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 43 46
105 [00000018] IRP_MJ_READ Length: 0001, Data: 06
106 [00000020] IRP_MJ_CLOSE Port Closed
107 [00000000] IRP_MJ_CREATE Port Opened - ntvdm.exe
108 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
109 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
110 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
111 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
112 [00000000] IRP_MJ_WRITE Length: 0005, Data: 02 42 03 34 35
113 [00000001] IRP_MJ_READ Length: 0001, Data: 06
114 [00000002] IRP_MJ_CLOSE Port Closed
115 [00000000] IRP_MJ_CREATE Port Opened - ntvdm.exe
116 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
117 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
118 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
119 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
120 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 35 43 34 30 03 37 37
121 [00000002] IRP_MJ_READ Length: 0008, Data: 02 30 30 32 38 32 38 30
122 [00000003] IRP_MJ_READ Length: 0008, Data: 30 30 31 38 30 30 30 38
123 [00000003] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
124 [00000004] IRP_MJ_READ Length: 0008, Data: 36 30 30 33 38 32 38 30
125 [00000004] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 30 30 30 38
126 [00000005] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
127 [00000005] IRP_MJ_READ Length: 0008, Data: 36 43 41 30 31 30 30 38
128 [00000006] IRP_MJ_READ Length: 0008, Data: 34 30 30 34 38 31 34 30
129 [00000006] IRP_MJ_READ Length: 0008, Data: 45 39 30 38 36 30 31 38
130 [00000007] IRP_MJ_READ Length: 0008, Data: 36 31 35 30 45 39 32 38
131 [00000007] IRP_MJ_READ Length: 0008, Data: 36 30 31 38 36 31 34 32
132 [00000008] IRP_MJ_READ Length: 0008, Data: 45 30 30 44 35 31 35 32
133 [00000008] IRP_MJ_READ Length: 0008, Data: 45 30 30 45 35 31 34 32
134 [00000009] IRP_MJ_READ Length: 0008, Data: 45 31 35 34 45 30 43 30
135 [00000010] IRP_MJ_READ Length: 0008, Data: 30 31 34 38 45 30 43 30
136 [00000010] IRP_MJ_READ Length: 0008, Data: 30 31 35 38 45 34 30 30
137 [00000011] IRP_MJ_READ Length: 0004, Data: 30 03 35 42
138 [00000011] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 39 43 31 32 03 37 41
139 [00000013] IRP_MJ_READ Length: 0008, Data: 02 39 36 38 36 30 31 38
140 [00000014] IRP_MJ_READ Length: 0008, Data: 36 46 46 46 46 46 46 46
141 [00000014] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
142 [00000015] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
143 [00000015] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 03 35 37
144 [00000017] IRP_MJ_CLOSE Port Closed
2:全部下载:
监控: COM1
创建时间: 2008-06-03, 10:59:59
计算机名:
26 [00000003] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
28 [00000004] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
47 [00000015] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 03 45 35
48 [00000017] IRP_MJ_CLOSE Port Closed
60 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
61 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
62 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 30 45 30 34 30 32 03 36 45
63 [00000002] IRP_MJ_READ Length: 0008, Data: 02 30 32 30 30 03 43 35
64 [00000003] IRP_MJ_CLOSE Port Closed
65 [00000000] IRP_MJ_CREATE Port Opened - W0
66 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
67 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
68 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
69 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
70 [00000007] IRP_MJ_WRITE Length: 0103, Data: 02 31 38 30 30 30 32 45 30 32 30 30 32 34 32 46 30 30 30 30 30 30 30 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 03 31 46
71 [00000008] IRP_MJ_READ Length: 0001, Data: 06
72 [00000015] IRP_MJ_WRITE Length: 0103, Data: 02 31 38 30 32 45 32 45 32 30 32 30 46 34 30 39 46 46 30 42 46 34 30 31 45 37 30 33 36 34 30 45 43 37 30 45 44 43 30 45 46 46 30 45 39 30 30 31 46 45 30 33 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 03 36 43
73 [00000016] IRP_MJ_READ Length: 0001, Data: 06
74 [00000017] IRP_MJ_CLOSE Port Closed
75 [00000000] IRP_MJ_CREATE Port Opened - W2E
76 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
77 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
78 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
79 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
80 [00000009] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 30 35 43 34 30 30 30 32 38 32 38 30 30 30 31 38 30 30 30 38 30 30 30 38 36 30 30 38 36 30 30 33 38 32 38 30 30 30 30 38 30 30 30 38 30 30 30 38 36 30 30 38 36 43 41 30 31 30 30 38 34 30 30 34 38 31 34 30 45 39 30 38 36 30 31 38 36 31 35 30 45 39 32 38 36 30 31 38 36 31 34 32 45 30 30 44 35 31 35 32 45 30 30 45 35 31 34 32 45 31 35 34 45 30 43 30 30 31 34 38 45 30 43 30 30 31 35 38 45 34 30 30 30 03 44 30
81 [00000012] IRP_MJ_READ Length: 0001, Data: 06
82 [00000021] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 30 39 43 34 30 39 36 38 36 30 31 38 36 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 46 38
83 [00000025] IRP_MJ_READ Length: 0001, Data: 06
84 [00000034] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 30 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 37
85 [00000038] IRP_MJ_READ Length: 0001, Data: 06
86 [00000047] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 31 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 35
87 [00000051] IRP_MJ_READ Length: 0001, Data: 06
88 [00000060] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 31 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 39
89 [00000063] IRP_MJ_READ Length: 0001, Data: 06
90 [00000072] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 31 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 44
91 [00000076] IRP_MJ_READ Length: 0001, Data: 06
92 [00000085] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 31 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 38
93 [00000089] IRP_MJ_READ Length: 0001, Data: 06
94 [00000098] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 32 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 36
95 [00000102] IRP_MJ_READ Length: 0001, Data: 06
96 [00000111] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 32 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 41
97 [00000114] IRP_MJ_READ Length: 0001, Data: 06
98 [00000124] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 32 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 45
99 [00000127] IRP_MJ_READ Length: 0001, Data: 06
100 [00000136] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 32 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 39
101 [00000140] IRP_MJ_READ Length: 0001, Data: 06
102 [00000149] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 33 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 37
103 [00000153] IRP_MJ_READ Length: 0001, Data: 06
104 [00000162] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 33 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 42
105 [00000165] IRP_MJ_READ Length: 0001, Data: 06
106 [00000174] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 33 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 46
107 [00000178] IRP_MJ_READ Length: 0001, Data: 06
108 [00000186] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 33 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 41
109 [00000190] IRP_MJ_READ Length: 0001, Data: 06
110 [00000199] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 34 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 38
111 [00000203] IRP_MJ_READ Length: 0001, Data: 06
112 [00000212] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 34 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 43
113 [00000216] IRP_MJ_READ Length: 0001, Data: 06
114 [00000224] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 34 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 30
115 [00000228] IRP_MJ_READ Length: 0001, Data: 06
116 [00000237] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 34 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 42
117 [00000241] IRP_MJ_READ Length: 0001, Data: 06
118 [00000250] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 35 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 39
119 [00000253] IRP_MJ_READ Length: 0001, Data: 06
120 [00000262] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 35 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 44
121 [00000266] IRP_MJ_READ Length: 0001, Data: 06
122 [00000275] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 35 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 31
123 [00000279] IRP_MJ_READ Length: 0001, Data: 06
124 [00000288] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 35 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 43
125 [00000292] IRP_MJ_READ Length: 0001, Data: 06
126 [00000300] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 36 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 41
127 [00000304] IRP_MJ_READ Length: 0001, Data: 06
128 [00000313] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 36 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 45
129 [00000317] IRP_MJ_READ Length: 0001, Data: 06
130 [00000326] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 36 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 32
131 [00000330] IRP_MJ_READ Length: 0001, Data: 06
132 [00000339] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 36 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 44
133 [00000342] IRP_MJ_READ Length: 0001, Data: 06
134 [00000351] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 37 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 42
135 [00000355] IRP_MJ_READ Length: 0001, Data: 06
136 [00000364] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 37 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 46
137 [00000368] IRP_MJ_READ Length: 0001, Data: 06
138 [00000377] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 37 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 33
139 [00000381] IRP_MJ_READ Length: 0001, Data: 06
140 [00000390] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 37 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 45
141 [00000393] IRP_MJ_READ Length: 0001, Data: 06
142 [00000402] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 38 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 43
143 [00000406] IRP_MJ_READ Length: 0001, Data: 06
144 [00000414] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 38 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 30
145 [00000418] IRP_MJ_READ Length: 0001, Data: 06
146 [00000427] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 38 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 34
147 [00000431] IRP_MJ_READ Length: 0001, Data: 06
148 [00000440] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 38 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 46
149 [00000444] IRP_MJ_READ Length: 0001, Data: 06
150 [00000452] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 39 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 37 44
151 [00000456] IRP_MJ_READ Length: 0001, Data: 06
152 [00000465] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 39 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 31
153 [00000469] IRP_MJ_READ Length: 0001, Data: 06
154 [00000478] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 39 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 35
155 [00000482] IRP_MJ_READ Length: 0001, Data: 06
156 [00000490] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 39 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 30
157 [00000494] IRP_MJ_READ Length: 0001, Data: 06
158 [00000503] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 41 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 35
159 [00000507] IRP_MJ_READ Length: 0001, Data: 06
160 [00000515] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 41 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 39
161 [00000519] IRP_MJ_READ Length: 0001, Data: 06
162 [00000528] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 41 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 44
163 [00000532] IRP_MJ_READ Length: 0001, Data: 06
164 [00000541] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 41 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 38
165 [00000544] IRP_MJ_READ Length: 0001, Data: 06
166 [00000553] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 42 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 36
167 [00000557] IRP_MJ_READ Length: 0001, Data: 06
168 [00000566] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 42 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 41
169 [00000570] IRP_MJ_READ Length: 0001, Data: 06
170 [00000578] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 42 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 45
171 [00000582] IRP_MJ_READ Length: 0001, Data: 06
172 [00000591] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 42 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 39
173 [00000595] IRP_MJ_READ Length: 0001, Data: 06
174 [00000604] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 43 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 37
175 [00000607] IRP_MJ_READ Length: 0001, Data: 06
176 [00000616] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 43 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 42
177 [00000620] IRP_MJ_READ Length: 0001, Data: 06
178 [00000629] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 43 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 46
179 [00000633] IRP_MJ_READ Length: 0001, Data: 06
180 [00000642] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 43 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 41
181 [00000646] IRP_MJ_READ Length: 0001, Data: 06
182 [00000655] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 44 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 38
183 [00000658] IRP_MJ_READ Length: 0001, Data: 06
184 [00000667] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 44 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 43
185 [00000671] IRP_MJ_READ Length: 0001, Data: 06
186 [00000680] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 44 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 30
187 [00000684] IRP_MJ_READ Length: 0001, Data: 06
188 [00000693] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 44 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 42
189 [00000696] IRP_MJ_READ Length: 0001, Data: 06
190 [00000705] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 45 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 39
191 [00000709] IRP_MJ_READ Length: 0001, Data: 06
192 [00000718] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 45 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 44
193 [00000722] IRP_MJ_READ Length: 0001, Data: 06
194 [00000731] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 45 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 31
195 [00000734] IRP_MJ_READ Length: 0001, Data: 06
196 [00000743] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 45 44 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 43
197 [00000747] IRP_MJ_READ Length: 0001, Data: 06
198 [00000756] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 46 31 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 41
199 [00000760] IRP_MJ_READ Length: 0001, Data: 06
200 [00000769] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 46 35 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 38 45
201 [00000772] IRP_MJ_READ Length: 0001, Data: 06
202 [00000781] IRP_MJ_WRITE Length: 0139, Data: 02 31 38 46 39 43 34 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 39 32
203 [00000785] IRP_MJ_READ Length: 0001, Data: 06
204 [00000790] IRP_MJ_WRITE Length: 0075, Data: 02 31 38 46 44 43 32 30 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 31 42
205 [00000793] IRP_MJ_READ Length: 0001, Data: 06
206 [00000794] IRP_MJ_CLOSE Port Closed
207 [00000000] IRP_MJ_CREATE Port Opened - WDC
208 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
209 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
210 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
211 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
212 [00000001] IRP_MJ_WRITE Length: 0015, Data: 02 31 38 46 46 45 30 32 46 46 46 37 03 41 38
213 [00000002] IRP_MJ_READ Length: 0001, Data: 06
214 [00000004] IRP_MJ_CLOSE Port Closed
215 [00000000] IRP_MJ_CREATE Port Opened - WFE
216 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
217 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
218 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
219 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
220 [00000000] IRP_MJ_WRITE Length: 0005, Data: 02 42 03 34 35
221 [00000001] IRP_MJ_READ Length: 0001, Data: 06
222 [00000002] IRP_MJ_CLOSE Port Closed
223 [00000000] IRP_MJ_CREATE Port Opened - W5E
224 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
225 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
226 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
227 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
228 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 30 30 32 45 03 37 32
229 [00000002] IRP_MJ_READ Length: 0008, Data: 02 30 32 30 30 32 34 32
230 [00000003] IRP_MJ_READ Length: 0008, Data: 46 30 30 30 30 30 30 30
231 [00000003] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
232 [00000004] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
233 [00000004] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
234 [00000005] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
235 [00000005] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
236 [00000006] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
237 [00000006] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
238 [00000007] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
239 [00000007] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 32 30 32
240 [00000008] IRP_MJ_READ Length: 0008, Data: 30 32 30 32 30 03 41 46
241 [00000009] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 32 45 32 45 03 38 39
242 [00000010] IRP_MJ_READ Length: 0008, Data: 02 32 30 32 30 46 34 30
243 [00000011] IRP_MJ_READ Length: 0008, Data: 39 46 46 30 42 46 34 30
244 [00000011] IRP_MJ_READ Length: 0008, Data: 31 45 37 30 33 36 34 30
245 [00000012] IRP_MJ_READ Length: 0008, Data: 45 43 37 30 45 44 43 30
246 [00000012] IRP_MJ_READ Length: 0008, Data: 45 46 46 30 45 39 30 30
247 [00000013] IRP_MJ_READ Length: 0008, Data: 31 46 45 30 33 30 30 30
248 [00000013] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
249 [00000014] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
250 [00000014] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
251 [00000015] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
252 [00000016] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 30 30 30
253 [00000016] IRP_MJ_READ Length: 0008, Data: 30 30 30 30 30 03 45 35
254 [00000018] IRP_MJ_CLOSE Port Closed
255 [00000000] IRP_MJ_CREATE Port Opened - W0
256 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
257 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
258 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
259 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
260 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 35 43 34 30 03 37 37
261 [00000002] IRP_MJ_READ Length: 0008, Data: 02 30 30 32 38 32 38 30
262 [00000002] IRP_MJ_READ Length: 0008, Data: 30 30 31 38 30 30 30 38
263 [00000003] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
264 [00000003] IRP_MJ_READ Length: 0008, Data: 36 30 30 33 38 32 38 30
265 [00000004] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 30 30 30 38
266 [00000004] IRP_MJ_READ Length: 0008, Data: 30 30 30 38 36 30 30 38
267 [00000005] IRP_MJ_READ Length: 0016, Data: 36 43 41 30 31 30 30 38 34 30 30 34 38 31 34 30
268 [00000006] IRP_MJ_READ Length: 0008, Data: 45 39 30 38 36 30 31 38
269 [00000006] IRP_MJ_READ Length: 0008, Data: 36 31 35 30 45 39 32 38
270 [00000007] IRP_MJ_READ Length: 0008, Data: 36 30 31 38 36 31 34 32
271 [00000007] IRP_MJ_READ Length: 0008, Data: 45 30 30 44 35 31 35 32
272 [00000008] IRP_MJ_READ Length: 0008, Data: 45 30 30 45 35 31 34 32
273 [00000008] IRP_MJ_READ Length: 0008, Data: 45 31 35 34 45 30 43 30
274 [00000009] IRP_MJ_READ Length: 0008, Data: 30 31 34 38 45 30 43 30
275 [00000010] IRP_MJ_READ Length: 0008, Data: 30 31 35 38 45 34 30 30
276 [00000010] IRP_MJ_READ Length: 0004, Data: 30 03 35 42
277 [00000011] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 39 43 34 30 03 37 42
278 [00000012] IRP_MJ_READ Length: 0008, Data: 02 39 36 38 36 30 31 38
279 [00000013] IRP_MJ_READ Length: 0008, Data: 36 46 46 46 46 46 46 46
280 [00000013] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
281 [00000014] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
282 [00000014] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
283 [00000015] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
284 [00000016] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
285 [00000016] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
286 [00000017] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
287 [00000017] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
288 [00000018] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
289 [00000018] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
290 [00000019] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
291 [00000019] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
292 [00000020] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
293 [00000020] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
294 [00000021] IRP_MJ_READ Length: 0004, Data: 46 03 37 46
295 [00000021] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 30 44 43 34 30 03 38 36
296 [00000023] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
297 [00000024] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
298 [00000024] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
299 [00000025] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
300 [00000025] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
301 [00000026] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
302 [00000026] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
303 [00000027] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
304 [00000027] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
305 [00000028] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
306 [00000028] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
307 [00000029] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
308 [00000029] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
309 [00000030] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
310 [00000030] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
311 [00000031] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
312 [00000032] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
313 [00000032] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 31 31 43 34 30 03 37 34
314 [00000034] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
315 [00000034] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
316 [00000035] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
317 [00000036] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
318 [00000036] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
319 [00000037] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
320 [00000037] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
321 [00000038] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
322 [00000038] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
323 [00000039] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
324 [00000039] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
325 [00000040] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
326 [00000040] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
327 [00000041] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
328 [00000041] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
329 [00000042] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
330 [00000042] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
331 [00000043] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 31 35 43 34 30 03 37 38
332 [00000044] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
333 [00000045] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
334 [00000046] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
335 [00000046] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
336 [00000047] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
337 [00000047] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
338 [00000048] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
339 [00000048] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
340 [00000049] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
341 [00000049] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
342 [00000050] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
343 [00000050] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
344 [00000051] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
345 [00000051] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
346 [00000052] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
347 [00000052] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
348 [00000053] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
349 [00000053] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 31 39 43 34 30 03 37 43
350 [00000055] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
351 [00000055] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
352 [00000056] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
353 [00000057] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
354 [00000057] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
355 [00000058] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
356 [00000058] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
357 [00000059] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
358 [00000059] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
359 [00000060] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
360 [00000060] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
361 [00000061] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
362 [00000062] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
363 [00000062] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
364 [00000063] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
365 [00000063] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
366 [00000064] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 31 44 43 34 30 03 38 37
367 [00000065] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
368 [00000066] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
369 [00000066] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
370 [00000067] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
371 [00000067] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
372 [00000068] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
373 [00000068] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
374 [00000069] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
375 [00000070] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
376 [00000070] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
377 [00000071] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
378 [00000071] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
379 [00000072] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
380 [00000072] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
381 [00000073] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
382 [00000073] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
383 [00000074] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
384 [00000074] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 32 31 43 34 30 03 37 35
385 [00000076] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
386 [00000076] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
387 [00000077] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
388 [00000077] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
389 [00000078] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
390 [00000078] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
391 [00000079] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
392 [00000080] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
393 [00000080] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
394 [00000081] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
395 [00000081] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
396 [00000082] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
397 [00000082] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
398 [00000083] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
399 [00000083] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
400 [00000084] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
401 [00000084] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
402 [00000085] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 32 35 43 34 30 03 37 39
403 [00000086] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
404 [00000087] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
405 [00000087] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
406 [00000088] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
407 [00000088] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
408 [00000089] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
409 [00000089] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
410 [00000090] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
411 [00000090] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
412 [00000091] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
413 [00000092] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
414 [00000092] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
415 [00000093] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
416 [00000093] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
417 [00000094] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
418 [00000094] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
419 [00000095] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
420 [00000096] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 32 39 43 34 30 03 37 44
421 [00000097] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
422 [00000098] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
423 [00000098] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
424 [00000099] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
425 [00000099] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
426 [00000100] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
427 [00000100] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
428 [00000101] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
429 [00000102] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
430 [00000102] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
431 [00000103] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
432 [00000103] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
433 [00000104] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
434 [00000104] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
435 [00000105] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
436 [00000105] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
437 [00000106] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
438 [00000106] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 32 44 43 34 30 03 38 38
439 [00000108] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
440 [00000109] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
441 [00000109] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
442 [00000110] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
443 [00000110] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
444 [00000111] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
445 [00000111] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
446 [00000112] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
447 [00000112] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
448 [00000113] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
449 [00000113] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
450 [00000114] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
451 [00000114] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
452 [00000115] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
453 [00000115] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
454 [00000116] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
455 [00000117] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
456 [00000117] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 33 31 43 34 30 03 37 36
457 [00000119] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
458 [00000120] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
459 [00000120] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
460 [00000121] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
461 [00000121] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
462 [00000122] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
463 [00000122] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
464 [00000123] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
465 [00000123] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
466 [00000124] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
467 [00000124] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
468 [00000125] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
469 [00000126] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
470 [00000126] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
471 [00000127] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
472 [00000127] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
473 [00000128] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
474 [00000128] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 33 35 43 34 30 03 37 41
475 [00000131] IRP_MJ_READ Length: 0016, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
476 [00000131] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
477 [00000131] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
478 [00000132] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
479 [00000132] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
480 [00000133] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
481 [00000134] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
482 [00000134] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
483 [00000135] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
484 [00000135] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
485 [00000136] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
486 [00000136] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
487 [00000137] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
488 [00000137] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
489 [00000138] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
490 [00000139] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
491 [00000139] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 33 39 43 34 30 03 37 45
492 [00000141] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
493 [00000141] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
494 [00000142] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
495 [00000143] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
496 [00000143] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
497 [00000144] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
498 [00000144] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
499 [00000145] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
500 [00000145] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
501 [00000146] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
502 [00000146] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
503 [00000147] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
504 [00000147] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
505 [00000148] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
506 [00000148] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
507 [00000149] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
508 [00000149] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
509 [00000150] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 33 44 43 34 30 03 38 39
510 [00000152] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
511 [00000152] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
512 [00000153] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
513 [00000153] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
514 [00000154] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
515 [00000154] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
516 [00000155] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
517 [00000155] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
518 [00000156] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
519 [00000156] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
520 [00000157] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
521 [00000158] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
522 [00000158] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
523 [00000159] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
524 [00000159] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
525 [00000160] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
526 [00000160] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
527 [00000161] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 34 31 43 34 30 03 37 37
528 [00000163] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
529 [00000163] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
530 [00000164] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
531 [00000164] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
532 [00000165] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
533 [00000165] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
534 [00000166] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
535 [00000167] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
536 [00000167] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
537 [00000168] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
538 [00000168] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
539 [00000169] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
540 [00000169] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
541 [00000170] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
542 [00000170] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
543 [00000171] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
544 [00000171] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
545 [00000172] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 34 35 43 34 30 03 37 42
546 [00000174] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
547 [00000174] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
548 [00000175] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
549 [00000175] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
550 [00000176] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
551 [00000176] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
552 [00000177] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
553 [00000177] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
554 [00000178] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
555 [00000178] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
556 [00000179] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
557 [00000179] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
558 [00000180] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
559 [00000181] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
560 [00000181] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
561 [00000182] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
562 [00000182] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
563 [00000182] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 34 39 43 34 30 03 37 46
564 [00000184] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
565 [00000185] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
566 [00000186] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
567 [00000186] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
568 [00000186] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
569 [00000187] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
570 [00000187] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
571 [00000188] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
572 [00000188] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
573 [00000189] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
574 [00000189] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
575 [00000190] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
576 [00000190] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
577 [00000191] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
578 [00000191] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
579 [00000192] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
580 [00000193] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
581 [00000193] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 34 44 43 34 30 03 38 41
582 [00000195] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
583 [00000196] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
584 [00000196] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
585 [00000197] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
586 [00000197] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
587 [00000198] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
588 [00000198] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
589 [00000199] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
590 [00000200] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
591 [00000201] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
592 [00000201] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
593 [00000202] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
594 [00000202] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
595 [00000203] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
596 [00000203] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
597 [00000204] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
598 [00000204] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 35 31 43 34 30 03 37 38
599 [00000206] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
600 [00000206] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
601 [00000207] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
602 [00000207] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
603 [00000208] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
604 [00000209] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
605 [00000209] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
606 [00000210] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
607 [00000210] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
608 [00000211] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
609 [00000211] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
610 [00000212] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
611 [00000212] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
612 [00000214] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
613 [00000214] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
614 [00000214] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
615 [00000215] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 35 35 43 34 30 03 37 43
616 [00000216] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
617 [00000217] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
618 [00000217] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
619 [00000218] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
620 [00000218] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
621 [00000219] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
622 [00000220] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
623 [00000220] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
624 [00000221] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
625 [00000221] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
626 [00000222] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
627 [00000222] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
628 [00000223] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
629 [00000223] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
630 [00000224] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
631 [00000224] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
632 [00000225] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
633 [00000225] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 35 39 43 34 30 03 38 30
634 [00000227] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
635 [00000227] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
636 [00000228] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
637 [00000228] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
638 [00000229] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
639 [00000230] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
640 [00000230] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
641 [00000231] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
642 [00000231] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
643 [00000232] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
644 [00000232] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
645 [00000233] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
646 [00000233] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
647 [00000234] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
648 [00000234] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
649 [00000235] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
650 [00000235] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
651 [00000236] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 35 44 43 34 30 03 38 42
652 [00000238] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
653 [00000238] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
654 [00000239] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
655 [00000239] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
656 [00000240] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
657 [00000240] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
658 [00000241] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
659 [00000241] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
660 [00000242] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
661 [00000242] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
662 [00000243] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
663 [00000243] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
664 [00000244] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
665 [00000245] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
666 [00000245] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
667 [00000246] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
668 [00000246] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
669 [00000246] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 36 31 43 34 30 03 37 39
670 [00000248] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
671 [00000249] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
672 [00000249] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
673 [00000250] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
674 [00000250] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
675 [00000251] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
676 [00000251] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
677 [00000252] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
678 [00000253] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
679 [00000253] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
680 [00000254] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
681 [00000254] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
682 [00000255] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
683 [00000255] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
684 [00000256] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
685 [00000257] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
686 [00000257] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 36 35 43 34 30 03 37 44
687 [00000259] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
688 [00000260] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
689 [00000260] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
690 [00000261] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
691 [00000261] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
692 [00000262] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
693 [00000262] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
694 [00000263] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
695 [00000263] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
696 [00000264] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
697 [00000264] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
698 [00000265] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
699 [00000265] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
700 [00000266] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
701 [00000266] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
702 [00000267] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
703 [00000268] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
704 [00000268] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 36 39 43 34 30 03 38 31
705 [00000270] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
706 [00000270] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
707 [00000271] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
708 [00000272] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
709 [00000273] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
710 [00000274] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
711 [00000274] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
712 [00000275] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
713 [00000275] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
714 [00000276] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
715 [00000277] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
716 [00000277] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
717 [00000278] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
718 [00000278] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
719 [00000279] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 36 44 43 34 30 03 38 43
720 [00000280] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
721 [00000281] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
722 [00000282] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
723 [00000282] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
724 [00000283] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
725 [00000283] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
726 [00000284] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
727 [00000284] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
728 [00000285] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
729 [00000286] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
730 [00000286] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
731 [00000287] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
732 [00000288] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
733 [00000288] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
734 [00000289] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
735 [00000289] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 37 31 43 34 30 03 37 41
736 [00000291] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
737 [00000291] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
738 [00000292] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
739 [00000293] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
740 [00000293] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
741 [00000294] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
742 [00000294] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
743 [00000295] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
744 [00000295] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
745 [00000296] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
746 [00000296] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
747 [00000297] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
748 [00000297] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
749 [00000298] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
750 [00000298] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
751 [00000299] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
752 [00000299] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
753 [00000300] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 37 35 43 34 30 03 37 45
754 [00000304] IRP_MJ_READ Length: 0032, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
755 [00000305] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
756 [00000305] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
757 [00000305] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
758 [00000306] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
759 [00000307] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
760 [00000307] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
761 [00000308] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
762 [00000308] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
763 [00000309] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
764 [00000309] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
765 [00000310] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
766 [00000310] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
767 [00000311] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 37 39 43 34 30 03 38 32
768 [00000312] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
769 [00000313] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
770 [00000313] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
771 [00000314] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
772 [00000314] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
773 [00000315] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
774 [00000315] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
775 [00000316] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
776 [00000317] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
777 [00000317] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
778 [00000317] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
779 [00000318] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
780 [00000319] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
781 [00000319] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
782 [00000320] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
783 [00000320] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
784 [00000321] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
785 [00000321] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 37 44 43 34 30 03 38 44
786 [00000325] IRP_MJ_READ Length: 0032, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
787 [00000327] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
788 [00000331] IRP_MJ_READ Length: 0056, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
789 [00000331] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
790 [00000337] IRP_MJ_READ Length: 0012, Data: 46 46 46 46 46 46 46 46 46 03 30 33
791 [00000337] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 38 31 43 34 30 03 37 42
792 [00000346] IRP_MJ_READ Length: 0104, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
793 [00000351] IRP_MJ_READ Length: 0028, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 30 33
794 [00000351] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 38 35 43 34 30 03 37 46
795 [00000353] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
796 [00000354] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
797 [00000354] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
798 [00000355] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
799 [00000355] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
800 [00000356] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
801 [00000356] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
802 [00000357] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
803 [00000357] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
804 [00000358] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
805 [00000358] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
806 [00000359] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
807 [00000360] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
808 [00000361] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
809 [00000361] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
810 [00000362] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
811 [00000362] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 38 39 43 34 30 03 38 33
812 [00000364] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
813 [00000364] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
814 [00000365] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
815 [00000365] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
816 [00000366] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
817 [00000366] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
818 [00000367] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
819 [00000367] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
820 [00000368] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
821 [00000368] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
822 [00000369] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
823 [00000369] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
824 [00000370] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
825 [00000370] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
826 [00000371] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
827 [00000372] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
828 [00000372] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
829 [00000372] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 38 44 43 34 30 03 38 45
830 [00000374] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
831 [00000375] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
832 [00000375] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
833 [00000376] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
834 [00000376] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
835 [00000377] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
836 [00000377] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
837 [00000378] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
838 [00000379] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
839 [00000379] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
840 [00000380] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
841 [00000381] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
842 [00000381] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
843 [00000382] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
844 [00000382] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
845 [00000383] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
846 [00000383] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 39 31 43 34 30 03 37 43
847 [00000385] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
848 [00000385] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
849 [00000386] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
850 [00000387] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
851 [00000387] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
852 [00000387] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
853 [00000388] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
854 [00000389] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
855 [00000389] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
856 [00000390] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
857 [00000391] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
858 [00000391] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
859 [00000391] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
860 [00000392] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
861 [00000392] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
862 [00000393] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
863 [00000393] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
864 [00000394] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 39 35 43 34 30 03 38 30
865 [00000395] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
866 [00000396] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
867 [00000396] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
868 [00000397] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
869 [00000397] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
870 [00000398] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
871 [00000398] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
872 [00000401] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
873 [00000403] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
874 [00000403] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
875 [00000405] IRP_MJ_READ Length: 0012, Data: 46 46 46 46 46 46 46 46 46 03 30 33
876 [00000405] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 39 39 43 34 30 03 38 34
877 [00000407] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
878 [00000409] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
879 [00000412] IRP_MJ_READ Length: 0048, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
880 [00000412] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
881 [00000414] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
882 [00000414] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
883 [00000416] IRP_MJ_READ Length: 0020, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 30 33
884 [00000416] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 39 44 43 34 30 03 38 46
885 [00000419] IRP_MJ_READ Length: 0024, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
886 [00000421] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
887 [00000423] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
888 [00000425] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
889 [00000427] IRP_MJ_READ Length: 0028, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 03 30 33
890 [00000427] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 41 31 43 34 30 03 38 34
891 [00000429] IRP_MJ_READ Length: 0016, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
892 [00000431] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
893 [00000433] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
894 [00000435] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
895 [00000437] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
896 [00000437] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
897 [00000437] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 41 35 43 34 30 03 38 38
898 [00000440] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
899 [00000440] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
900 [00000442] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
901 [00000444] IRP_MJ_READ Length: 0032, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
902 [00000446] IRP_MJ_READ Length: 0024, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
903 [00000446] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
904 [00000447] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
905 [00000447] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
906 [00000448] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
907 [00000448] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 41 39 43 34 30 03 38 43
908 [00000450] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
909 [00000450] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
910 [00000451] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
911 [00000452] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
912 [00000453] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
913 [00000453] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
914 [00000454] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
915 [00000454] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
916 [00000455] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
917 [00000455] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
918 [00000456] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
919 [00000456] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
920 [00000457] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
921 [00000457] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
922 [00000458] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
923 [00000458] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
924 [00000463] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 41 44 43 34 30 03 39 37
925 [00000464] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
926 [00000465] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
927 [00000465] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
928 [00000466] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
929 [00000466] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
930 [00000467] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
931 [00000467] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
932 [00000468] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
933 [00000469] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
934 [00000469] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
935 [00000470] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
936 [00000470] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
937 [00000471] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
938 [00000471] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
939 [00000472] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
940 [00000472] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
941 [00000473] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
942 [00000473] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 42 31 43 34 30 03 38 35
943 [00000475] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
944 [00000475] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
945 [00000476] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
946 [00000476] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
947 [00000477] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
948 [00000482] IRP_MJ_READ Length: 0072, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
949 [00000482] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
950 [00000483] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
951 [00000483] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
952 [00000484] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 42 35 43 34 30 03 38 39
953 [00000485] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
954 [00000486] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
955 [00000486] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
956 [00000487] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
957 [00000487] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
958 [00000488] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
959 [00000488] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
960 [00000489] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
961 [00000490] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
962 [00000490] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
963 [00000491] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
964 [00000491] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
965 [00000492] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
966 [00000492] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
967 [00000493] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
968 [00000493] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
969 [00000494] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
970 [00000499] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 42 39 43 34 30 03 38 44
971 [00000501] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
972 [00000501] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
973 [00000502] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
974 [00000502] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
975 [00000503] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
976 [00000503] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
977 [00000504] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
978 [00000505] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
979 [00000505] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
980 [00000505] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
981 [00000506] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
982 [00000507] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
983 [00000507] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
984 [00000508] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
985 [00000508] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
986 [00000509] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
987 [00000509] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
988 [00000510] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 42 44 43 34 30 03 39 38
989 [00000511] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
990 [00000518] IRP_MJ_READ Length: 0088, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
991 [00000518] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
992 [00000519] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
993 [00000519] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
994 [00000519] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
995 [00000520] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
996 [00000520] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 43 31 43 34 30 03 38 36
997 [00000522] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
998 [00000522] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
999 [00000523] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1000 [00000523] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1001 [00000524] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1002 [00000524] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1003 [00000525] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1004 [00000526] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1005 [00000526] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1006 [00000527] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1007 [00000527] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1008 [00000528] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1009 [00000529] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
1010 [00000529] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1011 [00000530] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1012 [00000530] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1013 [00000530] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 43 35 43 34 30 03 38 41
1014 [00000532] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1015 [00000533] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1016 [00000533] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1017 [00000534] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1018 [00000534] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1019 [00000535] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1020 [00000535] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1021 [00000536] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1022 [00000536] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1023 [00000537] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1024 [00000537] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1025 [00000538] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1026 [00000539] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1027 [00000539] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1028 [00000540] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1029 [00000540] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1030 [00000541] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1031 [00000541] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 43 39 43 34 30 03 38 45
1032 [00000543] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1033 [00000543] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1034 [00000544] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1035 [00000544] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1036 [00000545] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1037 [00000546] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1038 [00000546] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1039 [00000547] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1040 [00000547] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1041 [00000548] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1042 [00000548] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1043 [00000549] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1044 [00000549] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1045 [00000550] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1046 [00000550] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1047 [00000551] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1048 [00000551] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1049 [00000552] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 43 44 43 34 30 03 39 39
1050 [00000553] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1051 [00000554] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1052 [00000554] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1053 [00000555] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1054 [00000555] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1055 [00000556] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1056 [00000556] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1057 [00000557] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1058 [00000558] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1059 [00000558] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1060 [00000559] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1061 [00000559] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1062 [00000560] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1063 [00000560] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1064 [00000561] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1065 [00000561] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1066 [00000569] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1067 [00000569] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 44 31 43 34 30 03 38 37
1068 [00000573] IRP_MJ_READ Length: 0040, Data: 02 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
1069 [00000574] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1070 [00000574] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1071 [00000575] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1072 [00000575] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1073 [00000576] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1074 [00000576] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1075 [00000577] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1076 [00000577] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1077 [00000578] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1078 [00000579] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1079 [00000579] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1080 [00000580] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1081 [00000580] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 44 35 43 34 30 03 38 42
1082 [00000581] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1083 [00000582] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1084 [00000582] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1085 [00000583] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1086 [00000584] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1087 [00000584] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1088 [00000585] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1089 [00000585] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1090 [00000586] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1091 [00000586] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1092 [00000587] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1093 [00000587] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1094 [00000588] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1095 [00000588] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1096 [00000589] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1097 [00000589] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1098 [00000590] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1099 [00000590] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 44 39 43 34 30 03 38 46
1100 [00000592] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1101 [00000592] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1102 [00000593] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1103 [00000594] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1104 [00000594] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1105 [00000595] IRP_MJ_READ Length: 0016, Data: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
1106 [00000596] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1107 [00000596] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1108 [00000597] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1109 [00000597] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1110 [00000598] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1111 [00000598] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1112 [00000599] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1113 [00000599] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1114 [00000600] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1115 [00000601] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1116 [00000601] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 44 44 43 34 30 03 39 41
1117 [00000603] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1118 [00000603] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1119 [00000604] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1120 [00000604] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1121 [00000605] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1122 [00000605] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1123 [00000606] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1124 [00000606] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1125 [00000607] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1126 [00000607] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1127 [00000608] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1128 [00000608] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1129 [00000609] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1130 [00000609] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1131 [00000610] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1132 [00000611] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1133 [00000611] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1134 [00000611] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 45 31 43 34 30 03 38 38
1135 [00000613] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1136 [00000613] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1137 [00000614] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1138 [00000615] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1139 [00000615] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1140 [00000616] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1141 [00000616] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1142 [00000617] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1143 [00000617] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1144 [00000618] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1145 [00000618] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1146 [00000619] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1147 [00000619] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1148 [00000620] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1149 [00000620] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1150 [00000621] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1151 [00000621] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1152 [00000622] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 45 35 43 34 30 03 38 43
1153 [00000623] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1154 [00000624] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1155 [00000624] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1156 [00000625] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1157 [00000625] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1158 [00000626] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1159 [00000626] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1160 [00000627] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1161 [00000628] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1162 [00000628] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1163 [00000629] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1164 [00000629] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1165 [00000630] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1166 [00000630] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1167 [00000631] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1168 [00000631] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1169 [00000632] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1170 [00000632] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 45 39 43 34 30 03 39 30
1171 [00000634] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1172 [00000634] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1173 [00000635] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1174 [00000635] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1175 [00000636] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1176 [00000636] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1177 [00000637] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1178 [00000637] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1179 [00000638] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1180 [00000638] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1181 [00000639] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1182 [00000640] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1183 [00000640] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1184 [00000641] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1185 [00000641] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1186 [00000642] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1187 [00000642] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1188 [00000642] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 45 44 43 34 30 03 39 42
1189 [00000644] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1190 [00000645] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1191 [00000645] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1192 [00000646] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1193 [00000646] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1194 [00000647] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1195 [00000647] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1196 [00000648] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1197 [00000648] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1198 [00000649] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1199 [00000649] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1200 [00000650] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1201 [00000650] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1202 [00000651] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1203 [00000651] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1204 [00000652] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1205 [00000653] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1206 [00000653] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 46 31 43 34 30 03 38 39
1207 [00000655] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1208 [00000656] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1209 [00000656] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1210 [00000657] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1211 [00000657] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1212 [00000658] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1213 [00000658] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1214 [00000659] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1215 [00000659] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1216 [00000660] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1217 [00000660] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1218 [00000661] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1219 [00000661] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1220 [00000662] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1221 [00000662] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1222 [00000663] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1223 [00000663] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1224 [00000664] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 46 35 43 34 30 03 38 44
1225 [00000666] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1226 [00000666] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1227 [00000667] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1228 [00000667] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1229 [00000668] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1230 [00000668] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1231 [00000669] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1232 [00000669] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1233 [00000670] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1234 [00000670] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1235 [00000671] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1236 [00000672] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1237 [00000672] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1238 [00000673] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1239 [00000673] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1240 [00000674] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1241 [00000674] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1242 [00000674] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 46 39 43 34 30 03 39 31
1243 [00000676] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1244 [00000677] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1245 [00000677] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1246 [00000678] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1247 [00000678] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1248 [00000679] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1249 [00000679] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1250 [00000680] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1251 [00000680] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1252 [00000681] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1253 [00000681] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1254 [00000682] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1255 [00000682] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1256 [00000683] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1257 [00000684] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1258 [00000684] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1259 [00000685] IRP_MJ_READ Length: 0004, Data: 46 03 30 33
1260 [00000685] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 46 44 43 32 30 03 39 41
1261 [00000686] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 46 46 46 46
1262 [00000687] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1263 [00000688] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1264 [00000688] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1265 [00000689] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1266 [00000689] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1267 [00000690] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1268 [00000690] IRP_MJ_READ Length: 0008, Data: 46 46 46 46 46 46 46 46
1269 [00000691] IRP_MJ_READ Length: 0004, Data: 46 03 38 33
1270 [00000692] IRP_MJ_CLOSE Port Closed
1271 [00000000] IRP_MJ_CREATE Port Opened - ntvdm.exe
1272 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
1273 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
1274 [00000000] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
1275 [00000000] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: Even, DataBits: 7
1276 [00000000] IRP_MJ_WRITE Length: 0011, Data: 02 30 38 46 46 45 30 32 03 39 45
1277 [00000002] IRP_MJ_READ Length: 0008, Data: 02 46 46 46 37 03 30 43
1278 [00000003] IRP_MJ_CLOSE Port Closed |
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
