我的板子发现flash时常下载失败问题!
有用过nios的知道 在niosII 9.0 下 还需要定制 目标板么?
另外我用的flash是 AT49BV162A
__________________________________________________________________________________________________
下载信息如下:
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/MultiProj/SOPCprj/cpld/memtest_1/Debug
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0x1fffff --reset=0x0 --i
nput="memtest_1.elf" --output="ext_flash.flash" --boot="C:/altera/90/ip/altera/n
ios2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x00202080
--id=838130126 --timestamp=1243516509 --instance=0 "ext_flash.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00202080: verified
: Checksumming existing contents
00000000 : Reading existing contents
Checksums took 0.0s
00000000 ( 0%): Erasing
Erased 64kB in 0.1s
00000000 ( 0%): Programming
Program failed
Leaving target processor paused |
