回复: 9
求助:请问如何用单片机实现modbus协议?
发表于 2009-5-27 23:07:28 | 显示全部楼层 |阅读模式
怎么才叫实现了modbus协议 消息帧的格式和规定的一样就行吗?地址是如何分配的,从机如何知道自己的地址是多少
发表于 2009-5-28 07:58:35 | 显示全部楼层
先找份协议好好看看!
发表于 2009-5-28 21:15:23 | 显示全部楼层
给你一个参考:
/*------------------ CRC 高位字节值表------------------ */
const unsigned char CRCHi_TABLE[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
/*------------------ CRC 低位字节值表------------------ */
const unsigned char CRCLo_TABLE[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
unsigned int crc16(unsigned char *Msg , unsigned int DataLen)
        unsigned char CRCHi_TMP = 0xFF ;         //        高CRC字节初始化
        unsigned char CRCLo_TMP = 0xFF ;         //        低CRC 字节初始化
        unsigned long Index ;                 //        CRC循环中的索引
        DataLen=DataLen;
        while (DataLen>0)                         //        传输消息缓冲区
        DataLen--;
                Index = CRCHi_TMP ^ *Msg++ ;                                 //        计算CRC
                CRCHi_TMP = CRCLo_TMP ^ CRCHi_TABLE[Index] ;
                CRCLo_TMP = CRCLo_TABLE[Index] ;
        return (CRCHi_TMP << 8 | CRCLo_TMP) ;
发表于 2009-5-28 21:17:11 | 显示全部楼层
这是CRC校验的程序,MODBUS协议里面要用的
出110入109汤圆
发表于 2009-5-31 01:54:35 | 显示全部楼层
用Winavr时,<util/crc16>里有CRC16的实现的,但看来坛子里少有人用的。有试过的弟兄不?
发表于 2009-5-31 07:48:24 | 显示全部楼层
要用查表法做crc16!
发表于 2009-8-22 10:17:27 | 显示全部楼层
二楼的朋友请问
其中unsigned char *Msg, 什么意思?
正好我也在搞MODBUS通信,非常想知道,先谢了!
发表于 2012-10-29 17:04:06 | 显示全部楼层
发表于 2012-10-29 18:45:09 | 显示全部楼层
http://www.amobbs.com/thread-5503682-1-1.html
这是我上传的一个通讯程序
发表于 2012-10-29 18:47:07 | 显示全部楼层
sddlwym 发表于 2009-8-22 10:17
二楼的朋友请问
定义一个指针型形参,
GMT+8, 2024-8-27 01:17
