不少朋友(有使用我的飞控板的,也有使用其他飞控板的朋友)问我关于MK高度保持的问题。今天无意中翻看资料,发现这个或许对大家有帮助
http://www.mikrokopter.de/ucwiki/en/heightsensor?highlight=%28height%29
请特别留意这段里面的这句 (the set point work like a ceiling, not a floor.)
Flight-activating the sensor with a switch
If you use a switch, just fly to your intended altitude, flip the switch on, increase the throttle (up to 100% if you want to). The MK should remain within cm of the altitude it was at when you activated the switch. If you decrease the throttle the MK will descend - the set point work like a ceiling, not a floor.
BEWARE: if you deactivate the switch, immeditely reduce the throttle, otherwise the MK will become VERY small, VERY quickly. |
