Xmega是8位AVR的强劲性能升级版本
AVR XMEGA扩展了8位微控制器的市场领域。
XMEGA采用了第二代picoPower技术,是唯一真正使用1.6V工作电压的闪存微控制器。该系列器件的功耗超低,并具有快速12位模拟功能、一个DMA控制器、一个创新的事件系统,以及一个AES加密引擎,全部都无需占用CPU资源,能够最大限度地减少功耗和提高系统性能。
通过先进的AVR CPU,Atmel能够同时服务于8位和16位微控制器市场。由于旧式8位和16位CPU无法满足客户的要求,许多竞争对手被迫提供32位产品,但却难以在价格、功耗、易用性、EMC性能和模拟功能方面取得平衡。AVR XMEGA将Atmel的picoPower技术与扩展的任务处理能力,以及先进的外设三者结合,发展成为一个广泛的器件系列。
XMEGA系列微控制器的闪存容量从16至384KB不等,采用44至100脚的封装,工作电压为1.6V至3.6V,32MHz频率下处理性能可达到32MIPS。XMEGA器件是通用的微控制器,适合各种应用。
以下是性能参数~
• High-performance, Low-power 8/16-bit AVR XMEGA Microcontroller
• Non-Volatile Program and Data Memories
– 64K/128K/192K/256K/384K Bytes of In-System Self-Programmable Flash
– 4K/8K/8K/8K/8K Bytes Boot Section with Independent Lock Bits
– 2K/2K/2K/4K/4K Bytes EEPROM
– 4K/8K/16K/16K/32K Bytes Internal SRAM
External Bus Interface for up to 16M bytes SRAM
External Bus Interface for up to 128M bit SDRAM
• Peripheral Features
– Four-channel DMA Controller with support for external requests
– Eight-channel Event System
– Eight 16-bit Timer/Counters
Four Timer/Counters with 4 Output Compare or Input Capture channels
Four Timer/Counters with 2 Output Compare or Input Capture channels
High-Resolution Extension on all Timer/Counters
Advanced Waveform Extension on two Timer/Counters
– Eight USARTs
IrDA modulation/demodulation for one USART
– Four Two-Wire Interfaces with dual address match (I2C and SMBus compatible)
– Four SPI (Serial Peripheral Interface) peripherals
– AES and DES Crypto Engine
– 16-bit Real Time Counter with separate Oscillator
– Two Eight-channel, 12-bit, 2 Msps Analog to Digital Converters
– Two Two-channel, 12-bit, 1 Msps Digital to Analog Converters
– Four Analog Comparators with Window compare function
– External Interrupts on all General Purpose I/O pins
– Programmable Watchdog Timer with Separate On-chip Ultra Low Power Oscillator
• Special Microcontroller Features
– Power-on Reset and Programmable Brown-out Detection
– Internal and External Clock Options with PLL and Prescaler
– Programmable Multi-level Interrupt Controller
– Sleep Modes: Idle, Power-down, Standby, Power-save, Extended Standby
– Advanced Programming, Test and Debugging Interfaces
JTAG (IEEE 1149.1 Compliant) Interface for programming, test and debugging
PDI (Program and Debug Interface) for programming and debugging
• I/O and Packages
– 78 Programmable I/O Lines
– 100 - lead TQFP
– 100 - ball CBGA
• Operating Voltage
– 1.6 – 3.6V
• Speed performance
– 0 – 12 MHz @ 1.6 – 2.7V
– 0 – 32 MHz @ 2.7 – 3.6V
Xmega可应对包括音响设备、ZigBee无线设备、功率工具、医疗设备、板卡控制器、网络设备、仪表、光收发器、电机控制、白色家电以及任何电池供电的产品。
最近国内的很多行业客户已经大量使用Xmega,有兴趣的客户可以直接向代理商下订单,货源非常充足。
ourAVR这边也会在近期有芯片销售,和以前一样,廉价的评估板以及工具也会一并推出
宣传及介绍资料:
点击此处下载 ourdev_443188.pdf(文件大小:640K) (原文件名:XMEGA introduction-Nov 2008.pdf) |
