发表于 2009-4-16 22:42:09
BCB6的安装方法:
Iocomp Components C++ Builder 6 Install Notes
Installation
These instructions must be completed only if the automatic compile fails during the install process...
Open Borland C++ Builder 6.0.
From the Main Menu, select File->Open
From the Open dialog, browse to "c:\iocomp\product\CBuilder6" or to the installed directory if different than the default directory.
From the Open dialog, select and open iocomp65.bpk (iocomp65clx.bpk for CLX components)..
The Package Project Manager dialog should now be open. The project is by default set up for the Professional Pack and Plot Pack products. If you did not purchase both of these products, you will need to modify the BPK file as follows...
For VCL Component Package...
Instrument Pack Only
Remove iPlotPackPropertyEditorsReg.pas
Remove iPlotPackReg.dcr
Remove iPlotPackReg.pas
Remove iProfessionalPropertyEditorsReg.pas
Remove iProfessionalReg.dcr
Remove iProfessionalReg.pas
ProfessionalPack Only
Plot Pack Only
Remove iInstrumentPackPropertyEditorsReg.pas
Remove iInstrumentPackReg.dcr
Remove iInstrumentPackReg.pas
For CLX Component Package...
Remove QiPlotPackPropertyEditorsReg.pas
Remove QiPlotPackReg.dcr
Remove QiPlotPackReg.pas
Remove QiProfessionalPropertyEditorsReg.pas
Remove QiProfessionalReg.dcr
Remove QiProfessionalReg.pas
Plot Pack Only
Remove QiInstrumentPackPropertyEditorsReg.pas
Remove QiInstrumentPackReg.dcr
Remove QiInstrumentPackReg.pas
From the Project Manager, click the Install button.
Click OK on the Information Dialog showing the installed components.
Close the Project Manager and click YES when prompted to save changes.
From the Main Menu, select Tools->Environment Options.
Select the Library tab.
Click on the Library Path browse button ("...") to modify.
From the Directories dialog, click on the browse button ("...").
For VCL Application Development: From the Browse For Folder dialog, browse to "c:\iocomp\product\CBuilder6" or to the installed directory if different than the default directory.
For CLX Application Development: From the Browse For Folder dialog, browse to "c:\iocomp\product\CBuilder6clx" or to the installed directory if different than the default directory.
From the Browse For Folder dialog, click the OK button.
From the Directories dialog, click the ADD button, then the OK button.
From the Environment Options dialog, click OK.
You are now ready to start using Iocomp Instrumentation Components. |
