发表于 2009-7-28 10:38:48
IR2101是否需要给他提供一个单独的稳定电源,比如上图的 +12V/+10V?
IR2101 DATASHEET 数据
Symbol Definition Min. Max. Units
VB High Side Floating Supply Voltage -0.3 625
VS High Side Floating Supply Offset Voltage VB - 25 VB + 0.3
VHO High Side Floating Output Voltage VS - 0.3 VB + 0.3 V
VCC Low Side and Logic Fixed Supply Voltage -0.3 25
VLO Low Side Output Voltage -0.3 VCC + 0.3
VIN Logic Input Voltage (HIN & LIN) -0.3 VCC + 0.3
此电源电压VCC由什么因数决定?
因VIN是用MCU输出,一般为+5V,那么按照DATASHEET,VCC也应该是+5V的呀!
但经过测试,VCC少于10V,电机就很难启动.
请大大门指点!!!! |
