我编写的串口通信测试程序在运行初 出现“必须有启动窗体或sub Main() 这是什么原因啊?请教一下Vb高手指点,谢谢啦~
我的源程序如下:
'串口初始化
Private Sub Form_Load()
MSComm1.CommPort = 1 '设置通信端口号为COM1
MSComm1.Settings = "9600,n,8,1" '设置串口参数
MSComm1.InputMode = 0 '接收文本型数据
End Sub
'打开通信端口
'把字符通过串口发送出去
Private Sub Cmdsend_Click()
If MSComm1.PortOpen = False Then MSComm1.PortOpen = True
MSComm1.Output = Trim(Textsend.Text)
End Sub
Private Sub CmdReceive_Click()
Dim buf$
Timer1.Enabled = False
buf = Trim(MSComm1.Input) '将缓冲区内的数据读入buf变量中
If Len(buf) = 0 Then '判断缓冲区内是否存在数据
TextReceive.Text = ""
Else
TextReceive.Text = buf
End If
End Sub
'启动定时器
'进入自动接收模式
Private Sub Cmdauto_Click()
Timer1.Enabled = True
End Sub
Private Sub TextReceive_Change()
End Sub
'定时自动从输入缓冲区读取字符
Private Sub Timer1_Timer()
If MSComm1.InBufferCount > 0 Then
TextReceive.Text = TextReceive.Text + MSComm1.Input
End If
End Sub
'关闭通信端口,停止程序运行
Private Sub Cmdquit_Click()
End
End Sub |
