回复: 6
用VB显示Access数据库中OLE长二进制格式字段
发表于 2009-3-26 22:40:38 | 显示全部楼层 |阅读模式
附件为Access数据库ourdev_428692.rar(文件大小:10K) (原文件名:20090318094206.rar)
上面附件为一个Access 数据库,该文件中有个ZoneInfo的表,表中Param段为OLE格式。请路上的高手指教下,如何显示。具体内容为一个产品的参数。先谢了。
 楼主| 发表于 2009-3-29 02:37:35 | 显示全部楼层
怎么没人回复啊,是不是太繁了啊。那位有什么关于这个的资料推荐一个,自己慢慢来,目前可以显示模块的名称,但就是不知怎么显示汉字。
 楼主| 发表于 2009-3-29 02:37:38 | 显示全部楼层
 楼主| 发表于 2009-3-30 00:23:14 | 显示全部楼层
郁闷啊,
出330入0汤圆
发表于 2009-3-30 10:08:24 | 显示全部楼层
不妨到CSDN上去问,毕竟那里是搞纯软件开发的。这里大多是硬件起家的。
VB.NET 操作 ACCESS OLE 字段内容-.NET教程,VB.Net语言2009-03-21 16:54数据库结构:
test.mdb [放在bin目录下]
表 test(id 自动编号, img ole)
代码:
使用 一个 openfiledialog ,两个 picturebox
imports system.io
public class form1
inherits system.windows.forms.form
dim cnn as data.oledb.oledbconnection
private sub button4_click(byval sender as system.object, byval e as system.eventargs) handles button4.click
me.dispose(true)
end sub
private sub button1_click(byval sender as system.object, byval e as system.eventargs) handles button1.click
if openfiledialog1.showdialog = dialogresult.ok then
picturebox1.image = image.fromfile(openfiledialog1.filename)
end if
end sub
private sub dbinit()
try
cnn = new data.oledb.oledbconnection("provider=microsoft.jet.oledb.4.0;data source=" & application.startuppath & "\test.mdb")
cnn.open()
catch exp as oledb.oledbexception
msgbox(exp.message)
end
end try
end sub
private sub dbrelease()
cnn.close()
cnn = nothing
end sub
private sub button2_click(byval sender as system.object, byval e as system.eventargs) handles button2.click
if picturebox1.image is nothing then
msgbox("请先选择图片", msgboxstyle.exclamation)
exit sub
end if
dim fs as filestream = new filestream(openfiledialog1.filename, filemode.open, fileaccess.read)
dim bt(fs.length) as byte
fs.read(bt, 0, fs.length)
fs.close()
fs = nothing
dim olecmd as oledb.oledbcommand = new oledb.oledbcommand
dbinit()
olecmd.connection = cnn
olecmd.commandtype = commandtype.text
olecmd.commandtext = "insert into test (img) values (@img)"
olecmd.parameters.add("@img", oledb.oledbtype.binary).value = bt
olecmd.executenonquery()
olecmd = nothing
dbrelease()
msgbox("图片插入成功")
end sub
private sub button3_click(byval sender as system.object, byval e as system.eventargs) handles button3.click
dim olecmd as oledb.oledbcommand = new oledb.oledbcommand("select img from test where id=1")
dbinit()
dim dr as oledb.oledbdatareader = olecmd.executereader(commandbehavior.singlerow)
if dr.read then
if not isdbnull(dr.item(0)) then
dim bt() as byte = dr.item(0)
dim ms as memorystream = new memorystream(bt)
picturebox2.image = image.fromstream(ms)
msgbox("无图片")
end if
msgbox("无数据")
end if
dr.close()
dr = nothing
olecmd = nothing
dbrelease()
end sub
end class
出1070入962汤圆
发表于 2009-3-30 10:10:22 | 显示全部楼层
赞同楼上的观点,一些软件问题到CSDN去,基本不用提问,搜一些都是大把的答案和例程。
 楼主| 发表于 2009-3-30 21:23:06 | 显示全部楼层
谢谢人楼上2位的解答,用GOOGLE和BAIDU搜过问的人很多,就是没答案。
GMT+8, 2024-8-26 16:15
