发表于 2009-3-26 18:39:01
Изменения по сравнению с предидущей версией:
对比先前版本发生的变化
добавлена симуляция моделей:
新增仿真模型
THAT4301 - Analog Engine
THAT2180A, THAT2180B, THAT2180C - VCA
THAT2181A, THAT2181B, THAT2181C - VCA
THAT2252 - RMS detector
THAT1240, THAT1243, THAT1246 - Line Receiver
THAT1200, THAT1203, THAT1206 - InGenius Line Receiver
PCF8563 - Real time clock
MCP3421 - 18-Bit Analog-to-Digital Converter with I2C Interface and On-Board Reference.
MCP3422/3 - 18-Bit Analog-to-Digital Converter with I2C Interface and On-Board Reference.
MCP3424 - 18-Bit Analog-to-Digital Converter with I2C Interface and On-Board Reference.
MAX335 - Serial Controlled, 8-Channel SPST Switch.
DG417/8/9 - Improved, SPST/SPDT Analog Switches.
DG508/9 - Monolithic CMOS Analog Multiplexers.
Microchip - PIC18F2423/2523/4423/4523
M145026 - Remote control encoder
M145027 - Remote control decoder
Исправлены ошибки:
纠正如下错误
ARES - Problem with nested copper regions which form partially outside of the drawn polygon boundary and can then short with other entities. See above.
ARES - "All layers" option appearing in layer selectors where it shouldn't.
ARES - Zone body does not change colour when layer is changed from the context menu.
ARES - Object selectors not refreshed after generating a gerber view (can result in UAE).
EASYHDL - ON TIMER AT 0 causes spurious boot events.
PIC16 - pull-up are now enabled when ECCP1 module is set for standard PWM (CCP1CON=0b00001100) and P1B to P1D are inputs.
PIC16F87/88 - problem with RB3 and LPV settings.
PIC18F2455/2458/2550/2553/4450 - both CCPx are not extended ones.
PIC18F4555/4458/4550/4553 - CCP1 to work as extended ECCP1.
ST & MICROCHIP SPI memory devices greater than 65536 bytes (512kbit) - now accepts 24bit address (3 bytes).
USB Simulation - Various fixes to improve robustness of the software stack when single stepping |
