发表于 2009-3-26 16:25:57
请各位大侠帮帮忙,看看这样改后会不会有问题。
以下是dbgu.h文件。
//! \addtogroup BOOTLOADER
// All rights reserved ADENEO 2007
//! \file dbgu.h
//! \if subversion
/// $URL: http://centaure/svn/interne-ce_bsp_atmel/TAGS/TAGS50/SAM9261EK_v170_rc4/PLATFORM/AT91SAM9261EK/SRC/BOOTLOADER/FirstBoot/dbgu.h $
//! $Author: pblanchard $
//! $Revision: 1219 $
//! $Date: 2007-08-03 16:59:11 +0200 (ven., 03 ao没t 2007) $
//! \endif
//! \addtogroup FIRSTBOOT
#ifndef __DBGU_H__
#define __DBGU_H__
#define AT91C_CB_SIZE 40 // size of the console buffer
// Escape sequences
#define ESC \033
#define CLRSCREEN "ESC[2J" //\033 = ESC in octal
#define ClEARLINE "ESC[K" // Clear line, from cursor position to the right most position of line
// Cursor Movement
#define MOVEUP(num) "ESC[numA" // Move the cursor up num positions
#define MOVEDOWN(num) "ESC[numB" // Move the cursor down num positions
#define MOVERIGHT(num) "ESC[numC" // Move the cursor right num positions
#define MOVELEFT(num) "ESC[numD" // Move the cursor left num positions
#define MOVETO(row,col) "ESC[row;colH" // Move the cursor to the (col, row) position. Note that the row comes before column; that is, y comes before x. Either col or row can be omitted. Row and column both start with "1," not zero. (1, 1) corresponds to the top-left corner of the screen.
// Character Mode
#define TIME_OUT_CHAR '?
#define CHANGE_CHAR_MODE(attr) "ESC[attrm" //Change the character mode with attribute attr. The attributes are numbers listed below.
#define ALL_ATTRIB_OFF 0 // All attributes turned off. (Except for foreground and background color).
#define HIGH_INTENSITY 1 // Bold.
#define LOW_INTENSITY 2 // Normal.
#define UNDERLINE 4 // Underline font.
#define BLINK 5 // Blinking font.
#define RAPID_BLINK 6 // Works only on some systems.
#define REVERSE_VIDEO 7 // Swapping the foreground color and the background color.
#define FOREGROUND_BLACK 30 // Black.
#define FOREGROUND_RED 31 // Red.
#define FOREGROUND_GREEN 32 // Green.
#define FOREGROUND_YELLOW 33 // Yellow.
#define FOREGROUND_BLUE 34 // Blue.
#define FOREGROUND_MAGENTA 35 // Magenta.
#define FOREGROUND_CYAN 36 // Cyan.
#define FOREGROUND_WHITE 37 // White.
#define BACKGROUND_BLACK 40 // Black.
#define BACKGROUND_RED 41 // Red.
#define BACKGROUND_GREEN 42 // Green.
#define BACKGROUND_YELLOW 43 // Yellow.
#define BACKGROUND_BLUE 44 // Blue.
#define BACKGROUND_MAGENTA 45 // Magenta.
#define BACKGROUND_CYAN 46 // Cyan.
#define BACKGROUND_WHITE 47 // White.
int DbgPrint(char *str);
#endif //__DBGU_H__
