发表于 2009-2-24 13:30:13
谢谢。。pitolan 的帮助(呵呵!,,,你比我想象的更加热情,连PCB都LAYOUT图都上来了,,,再次感谢你!!!)。。。。呵呵!我的电调PCB都有了,现在就是在调试遇到了不少的麻烦,没有电机测试。。。。。也不会用simTxData.exe工具调试(具体不知道烧录引导程序和升级文件)。以下是德国网站的原话:
With this little SimTxData.exe program it is possible to simulate throttle input. Only works until version <0.35!
The data are sent over the serial interface at a baudrate of 38400 in the following format:
0xF5 aa bb cc dd (aa = Motor 1, bb = Motor 2, etc.)
Connecting the ESCs for such testing is easy.
An excellent interface for such testing is our serial converter (SerCon):
As the ESCs already have a set of 2x 5 pins, only the jumper on the SerCon needs to be removed (jumper on SerCon = programming mode, jumper off = serial connection / debugging mode). After that the speed contolers can be tested with the 'SimTxData.EXE' tool.
Alternatively a simple transistor inverter could also be used: Only 1 NPN-Transistor (e.g. BC337 or similar) and two 10KOhm resistors are needed:
大概的意思是可以用两种方法进行调试。 |
