发表于 2009-1-29 20:18:57
转自5iMX » 模型工具与DIY » 图示车床改造
以下为原帖子顺序图片:
600元买的床子。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603587.jpg)
(原文件名:1.jpg)
定子绕线: 用10股0.5的漆包线每级绕10圈,Y型接法.铁芯是用洗衣机甩干桶电机铁芯
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603588.jpg)
(原文件名:2.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603589.jpg)
(原文件名:3.jpg)
转子直径69mm厚24mm,16片磁钢.
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603590.jpg)
(原文件名:4.jpg)
安装电机
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603591.jpg)
(原文件名:5.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603592.jpg)
(原文件名:6.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603593.jpg)
(原文件名:7.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603594.jpg)
(原文件名:8.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603595.jpg)
(原文件名:9.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603596.jpg)
(原文件名:10.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603597.jpg)
(原文件名:11.jpg)
在绝缘漆锅里煮后,用灯烤。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603598.jpg)
(原文件名:12.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603600.jpg)
(原文件名:13.jpg)
铣涡杆用电木棍试刀
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603601.jpg)
(原文件名:14.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603602.jpg)
(原文件名:15.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603603.jpg)
(原文件名:16.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603604.jpg)
(原文件名:17.jpg)
铣3头涡杆,走三遍刀完成,铣时加机油.
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603605.jpg)
(原文件名:18.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603606.jpg)
(原文件名:19.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603607.jpg)
(原文件名:20.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603608.jpg)
(原文件名:21.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603609.jpg)
(原文件名:22.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603610.jpg)
(原文件名:23.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603611.jpg)
(原文件名:24.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603612.jpg)
(原文件名:25.jpg)
这个主轴内孔同心,外圆不同心,安装夹盘必须走一刀.轴很硬,得用合金刀。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603613.jpg)
(原文件名:26.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603614.jpg)
(原文件名:27.jpg)
用水暖件做车床手轮,优点是材料好取。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603615.jpg)
(原文件名:28.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603616.jpg)
(原文件名:29.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603617.jpg)
(原文件名:30.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603618.jpg)
(原文件名:31.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603619.jpg)
(原文件名:32.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603620.jpg)
(原文件名:33.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603621.jpg)
(原文件名:34.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603622.jpg)
(原文件名:35.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603623.jpg)
(原文件名:36.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603624.jpg)
(原文件名:37.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603625.jpg)
(原文件名:38.jpg)
分度配件
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603626.jpg)
(原文件名:39.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603627.jpg)
(原文件名:40.jpg)
有第四轴,前面也有照片。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603628.jpg)
(原文件名:41.jpg)
机械部分基本完成
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603629.jpg)
(原文件名:42.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603630.jpg)
(原文件名:43.jpg)
电机部分: 用10股0.5mm的漆包线每极绕10圈,铁芯用洗衣机甩干电机铁芯(因为没有合适的铁芯,用此铁芯就是为了取材方便) Y型接法,24伏直流供电,我用的是60A无刷电调,实际用不了这么大。 (我用的电调电压范围5.6V--22V ,用24V不工作)等高压电调邮回来后,继续报告测试结果。经实际车件,12V供电就够了,力量很大,噪音很小。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603631.jpg)
(原文件名:44.jpg)
用12伏电瓶供电就能正常工作,调速范围:实测98转到1642转,空载电流4.3A(12伏供电)。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603632.jpg)
(原文件名:45.jpg)
用无刷电调
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603633.jpg)
(原文件名:46.jpg)
调速器在绕线电位器上装配,很省事。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603634.jpg)
(原文件名:47.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603635.jpg)
(原文件名:48.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603636.jpg)
(原文件名:49.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603637.jpg)
(原文件名:50.jpg)
做一个散热片
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603638.jpg)
(原文件名:51.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603639.jpg)
(原文件名:52.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603640.jpg)
(原文件名:53.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603641.jpg)
(原文件名:54.jpg)
外壳,未完待续。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603642.jpg)
(原文件名:55.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603643.jpg)
(原文件名:56.jpg)
喷漆、改动一下位置。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603644.jpg)
(原文件名:57.jpg)
驱动器到了,正在做固定架.
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603645.jpg)
(原文件名:58.jpg)
又干一点,做一个接口板架。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603646.jpg)
(原文件名:59.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603647.jpg)
(原文件名:60.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603648.jpg)
(原文件名:61.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603649.JPG)
(原文件名:62.JPG)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603650.JPG)
(原文件名:63.JPG)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603651.JPG)
(原文件名:64.JPG)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603652.jpg)
(原文件名:65.jpg)
用粉笔试一下刀
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603653.jpg)
(原文件名:66.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603654.jpg)
(原文件名:67.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603655.jpg)
(原文件名:68.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603656.jpg)
(原文件名:69.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603657.jpg)
(原文件名:70.jpg)
车球头
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603658.jpg)
(原文件名:71.jpg)
车手柄
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603659.jpg)
(原文件名:72.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603660.jpg)
(原文件名:73.jpg)
用电木车一个手柄,明天用铁车。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603661.jpg)
(原文件名:74.jpg)
给自己送一支辛苦花吧
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603662.jpg)
(原文件名:75.jpg)
自己的刀削自己的把
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603663.jpg)
(原文件名:76.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603664.jpg)
(原文件名:77.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603665.jpg)
(原文件名:78.jpg)
开始做第四轴
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603666.jpg)
(原文件名:79.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603667.jpg)
(原文件名:80.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603668.jpg)
(原文件名:81.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603669.jpg)
(原文件名:82.jpg)
本轴机械部分基本完成
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603670.jpg)
(原文件名:83.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603671.jpg)
(原文件名:84.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603672.jpg)
(原文件名:85.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603673.jpg)
(原文件名:86.jpg)
换铣刀用,一种固定方式的动力头不能解决下面两种工作方式。换齿轮铣刀,
1.铣齿轮。
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603674.jpg)
(原文件名:87.jpg)
2.当铣床用
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603675.jpg)
(原文件名:88.jpg)
铣个14齿齿轮
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603676.jpg)
(原文件名:89.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603677.jpg)
(原文件名:90.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603678.JPG)
(原文件名:91.JPG)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603679.jpg)
(原文件名:92.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603680.jpg)
(原文件名:93.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603681.jpg)
(原文件名:94.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603682.jpg)
(原文件名:95.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603683.jpg)
(原文件名:96.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603684.jpg)
(原文件名:97.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603685.jpg)
(原文件名:98.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603686.jpg)
(原文件名:99.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603687.jpg)
(原文件名:100.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_11/ourdev_603688.jpg)
(原文件名:101.jpg)
my god, 终于发完了。这是更详细的原帖内容:点击此处下载 ourdev_603689.rar(文件大小:3.59M) (原文件名:新建文件夹.rar)
本贴被 hn_ny_dxs 编辑过,最后修改时间:2009-01-29,21:05:32. |
