回复: 60
[21单片机]ST7920 12864液晶做的图文菜单显示及其问题【恢复】
发表于 2009-1-12 14:10:20 | 显示全部楼层 |阅读模式
 ST7920 12864液晶做的图文菜单系统可以显示图案,遗憾的是显示会有花屏,不知道是什么原因?
ST7920 12864液晶做的图文菜单系统 (原文件名:ST7920 12864液晶做的图文菜单.jpg)
发表于 2009-1-12 22:11:29 | 显示全部楼层
能否公布下源文件,我认为是的位置设置可能没有设置好。如果有半角字加进去就肯定会出乱码。我以前写的就是如此的。
 楼主| 发表于 2009-1-14 09:42:19 | 显示全部楼层
问题症状:ATMEGA16芯片+ST7920 12864液晶(SYB12864J-ZK)蓝底白字,
  1.显示汉字或大片(128*64)正常,
  2.显示小图片(32*24)周围会有很多杂点,见图所示,即使在写图片之前,写图函数
  LCD12864_opGDRAM(0x00);已经写0x00了!!!!!!并且清0了!!!!还是有杂点,换了一个旧的液晶TG12864E-03
  还是一样的,不知道什么原因?
 (原文件名:ST7920 12864液晶图文菜单显示问题.jpg)
  文件:ST7920 12864液晶图文菜单显示.C
  环境:编译为ICC AVR6.31A,仿真为AVR Studio4.14
  硬件:ATMEGA16芯片
  日期:2008年12月10日
  ** Author:ZRP QQ:978710555 E_Mail:zrp_ncu@163.com
  ** Time :  2009-1-4
#include <iom16v.h>                        //包含型号头文件
#include <macros.h>                        //包含"位"操作头文件
#include <stdio.h>                        //标准输入输出头文件
#include <AVR_EB1A.H>                //包含自定义常量头文件
#pragma data:code
//以下是字模工具取出的图片数组
/*========================== 菜单图片(宽度x高度=32*24)=============================*/
const uchar menu_pic[6][96]={
     // 调整
         {0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x40,0x00,0x00,0x02,0x40,0x00,0x00,0x02,
         0x40,0x00,0x00,0x82,0x47,0xFF,0xE1,0xC2,0x47,0xFF,0xF3,0xE2,0x47,0x38,0x68,0x02,
         0x46,0xDF,0x68,0x82,0x46,0xDF,0x69,0xC2,0x46,0xDE,0xE8,0x82,0x46,0xDD,0xE8,0x02,
         0x46,0xDD,0xE8,0x02,0x47,0x3D,0xE8,0x02,0x47,0xFF,0xE8,0x02,0x47,0xFF,0xE9,0xC2,
         0x42,0x00,0x18,0x02,0x41,0xFF,0xF3,0xE2,0x40,0x00,0x01,0xC2,0x40,0x00,0x00,0x82,
         0x40,0x00,0x00,0x02,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
        // 工具
         {0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x40,0x00,0x00,0x02,0x40,0x00,0x03,0x82,
         0x41,0xF0,0x07,0xC2,0x43,0xFF,0xCF,0xE2,0x47,0x3F,0xFE,0x02,0x47,0x3F,0xFE,0x02,
         0x43,0xFF,0xCF,0xE2,0x41,0xF0,0x0F,0xC2,0x40,0x00,0x03,0x82,0x40,0x00,0x00,0x02,
         0x40,0x00,0x03,0xC2,0x40,0x00,0x03,0xC2,0x41,0x80,0x01,0x82,0x43,0xFF,0xF3,0xC2,
         0x47,0xFF,0xFF,0xE2,0x47,0xFF,0xFF,0xE2,0x43,0xFF,0xF3,0xC2,0x41,0x80,0x01,0x82,
         0x40,0x00,0x01,0x82,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
         // 设置
         {0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x40,0x00,0x00,0x02,0x43,0x18,0x00,0x02,
         0x44,0xA4,0x0E,0x02,0x44,0xA4,0x1F,0x02,0x43,0x24,0x3F,0x02,0x40,0x00,0x7F,0x02,
         0x40,0xF0,0xFC,0x02,0x43,0xF9,0xF0,0x02,0x43,0x03,0xE0,0x02,0x46,0x77,0x80,0x02,
         0x46,0x7F,0x00,0x02,0x46,0x7E,0x00,0x02,0x46,0x7C,0x00,0x02,0x47,0x3D,0x00,0x02,
         0x43,0x1D,0x81,0x22,0x43,0x81,0xB2,0x42,0x41,0xC3,0x4F,0xE2,0x40,0xFE,0x4A,0x42,
         0x40,0x3C,0x32,0x42,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
        // 保密
         {0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x40,0x00,0x00,0x02,0x40,0xFC,0x03,0x02,
         0x41,0xFE,0x1F,0x02,0x43,0x87,0x03,0x82,0x43,0x03,0x03,0x02,0x43,0x03,0x03,0x02,
         0x43,0x03,0x0F,0x02,0x43,0x03,0x03,0x02,0x43,0x03,0x03,0x02,0x47,0xFF,0x83,0x02,
         0x47,0xFF,0x83,0x02,0x47,0xCF,0x83,0x02,0x47,0x87,0x83,0x02,0x47,0xCF,0x83,0x02,
         0x47,0xCF,0x87,0x82,0x47,0xCF,0x8F,0xC2,0x47,0xCF,0x9C,0xE2,0x47,0xFF,0x8F,0xC2,
         0x43,0xFF,0x07,0x82,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
        // 版本
         0x40,0x0F,0x00,0x62,0x40,0x1D,0x80,0xF2,0x40,0x38,0x41,0xF2,0x40,0x70,0x23,0xE2,
         0x40,0xE2,0x17,0xC2,0x41,0xE4,0x4F,0x82,0x41,0xF0,0x9F,0x02,0x41,0x59,0x16,0x02,
         0x42,0x4C,0x1D,0x02,0x42,0x46,0x20,0x82,0x42,0x47,0x00,0x42,0x44,0x43,0x80,0xC2,
         0x44,0x44,0xC1,0xC2,0x44,0xC8,0x63,0x82,0x45,0x50,0x37,0x02,0x46,0x60,0x1E,0x02,
         0x40,0x40,0x0C,0x02,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
        // 退出
         {0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x40,0x00,0x00,0x02,0x40,0x40,0xFF,0xE2,
         0x40,0x60,0x80,0x62,0x43,0xF0,0x80,0xA2,0x43,0xF0,0x81,0x22,0x40,0x60,0x82,0x22,
         0x40,0x40,0x84,0x22,0x40,0x00,0x88,0x22,0x40,0x00,0x88,0x22,0x47,0xFF,0xF8,0x22,
         0x47,0xFF,0xF8,0x22,0x46,0x2A,0x2A,0x22,0x46,0xE3,0x78,0x22,0x46,0x77,0x78,0x22,
         0x46,0xE3,0x78,0x62,0x46,0x2A,0x38,0x82,0x47,0xFF,0xF9,0x02,0x47,0xFF,0xFA,0x02,
         0x40,0x00,0x0C,0x02,0x40,0x00,0x00,0x02,0x7F,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00
#pragma data:data
uchar menu_cn[6][8]={"调    整","工    具","设    置","保    密","版    本","退    出"};
函数名称: EN_Toggle
功    能: EN端产生一个高电平使能脉冲,写LCD
参    数: 无
返回值  : 无
void EN_Toggle(void)  //EN端产生一个高电平使能脉冲,写LCD
        LCDb_SET_E;     //拉高使能位
        Delayus(50);    //保持高电平一定的写时间,如果晶振频率太高,则可相应提高延时
        LCDb_CLR_E;
        Delayus(50);
函数名称: LCD12864_readbyte
功    能: 从12864液晶读出一个字节数据或者指令
参    数: DatCmd--为iDat时是数据,为iCmd时是指令
返回值  : dByte--读回的数据或者指令
uchar LCD12864_readbyte(uchar DatCmd)
         uchar dByte;
        if (DatCmd == iCmd)                 //指令操作
                LCDb_CLR_RS;
                LCDb_SET_RS;
        LCDb_SET_RW;                              //读操作
        LCDb_SET_E;
        LCDb_DATA_DDR=0x00;             //数据总线定义为输入
        dByte=LCDb_DI;                         //读数据或者指令
        LCDb_CLR_E;
        LCDb_DATA_DDR|=0xff;         //数据总线还原为输出
        return dByte;
函数名称: LCD12864_writebyte
功    能: 向12864液晶写入一个字节数据或者指令
                    dByte--为写入12864的数据或者指令
返回值  : 无
void LCD12864_writebyte(uchar DatCmd, uchar dByte)
                LCDb_CLR_RS;
                LCDb_SET_RS;
        LCDb_CLR_RW;                        //写操作
        //LCDb_SET_E;
        LCDb_DO = dByte;                //写入数据
        //LCDb_CLR_E;
        EN_Toggle();                //EN端产生一个高电平使能脉冲,写LCD
函数名称: LCD12864_sendstr
功    能: 向12864液晶写入一个字符串
参    数: ptString--字符串指针
返回值  : 无
void LCD12864_sendstr(uchar *ptString)
        while((*ptString)!='\0')                          //字符串未结束一直写
         LCD12864_writebyte(iDat, *ptString++);
函数名称: LCD12864_clear
功    能: 12864液晶清屏
参    数: 无
返回值  : 无
void LCD12864_clear(void)
        LCD12864_writebyte(iCmd,LCDb_CLS);
        Delayms(2);// 清屏指令写入后,2ms 的延时是很必要的!!!
函数名称: LCD12864_readBF
功    能: 12864液晶清屏
参    数: 无
返回值  : busy--为1时忙,为0时可以接收指令
uchar LCD12864_readBF(void)
        uchar busy;
        busy=LCD12864_readbyte(iCmd);                //读回BF标志和地址
        if(busy&0x80)                                                //读最高位PB7,为0表示空闲,如果忙返回正在忙的状态
                busy=1;
        else        //不忙,可以写入
                busy=0;
        return busy;
函数名称: LCD12864_gotoXY
功    能: 移动到指定位置
参    数: Row--指定的行
                    Col--指定的列
返回值  : 无
void LCD12864_gotoXY(uchar Row, uchar Col)
        switch (Row)                  //选择行
                case 2:
                        LCD12864_writebyte(iCmd, LCDb_L2 + Col); break;        //写入第2行的指定列
                case 3:
                        LCD12864_writebyte(iCmd, LCDb_L3 + Col); break;        //写入第3行的指定列
                case 4:
                        LCD12864_writebyte(iCmd, LCDb_L4 + Col); break;        //写入第4行的指定列
                default:
                        LCD12864_writebyte(iCmd, LCDb_L1 + Col); break;        //写入第1行的指定列
函数名称: LCD12864_opGDRAM
功    能: 向GDRAM写入数据,并显示(完成绘图功能)
参    数: ptGDRAM--GDRAM数据指针
返回值  : 无
void LCD12864_opGDRAM(const uchar *ptGDRAM)
        uchar i,j;
        uint x=0;
        while(LCD12864_readBF());          //读忙标志
        LCD12864_writebyte(iCmd,LCDb_EXTCMD1);                //扩充指令集,并关闭绘图显示
        //写入并显示上半屏幕
        for(i=0;i<32;i++)                                            //行地址计数
           for(j=0;j<8;j++)                                      //列地址计数
                                    LCD12864_writebyte(iCmd,0x80|i);//输入行地址
                                    LCD12864_writebyte(iCmd,0x80|j);//输入列地址
                 LCD12864_writebyte(iDat,ptGDRAM[x++]); //输入高位字节数据
                                 LCD12864_writebyte(iDat,ptGDRAM[x++]); //输入低位字节数据
         //写入并显示下半屏幕
         for(i=0;i<32;i++)
           for(j=8;j<16;j++)
         Delayus(10);
         LCD12864_writebyte(iCmd,LCDb_EXTCMD2);                         //打开绘图显示
         LCD12864_writebyte(iCmd,LCDb_BASCMD);                         //还原回基本指令集模式
函数名称: LCD12864_portini
功    能: 初始化12864液晶用到的IO口
参    数: 无
返回值  : 无
void LCD12864_portini(void)
        LCDb_CTRL_DDR |= BIT(LCDb_RS)|BIT(LCDb_RW)|BIT(LCDb_E)|BIT(LCDb_RST);//配置控制管脚为输出
        LCDb_DATA_DDR |= 0xFF;  //配置数据管脚为输出
        LCDb_SET_RST;                    //不使能复位端
 函数名称:画面构造
 功能描述:界面1、2、3,图片菜单,反白,标头,16*16(32)图片
 全局变量:无
 参数说明:函数说明
 返回说明:无
 说    明:X坐标每一格每次16点
/*反白或显示图片 参数格式:(H)8bit数据,(L)8bit数据,X0坐标(16bit),Y0坐标(1bit),X坐标(16bit),Y坐标(1bit)*/
void con_disp (uchar data1,uchar data2,uchar x0,uchar y0,uchar xl,uchar yl)
  uchar i,j;
  for(j=0;j<yl;j++)
    for(i=0;i<xl;i++)
      LCD12864_writebyte(iCmd,0x34);     // 扩展功能
      LCD12864_writebyte(iCmd,y0+j);         // 写Y坐标
      LCD12864_writebyte(iCmd,x0+i);         // 写X坐标
      LCD12864_writebyte(iCmd,0x30);         // 普通功能,基本指令集
      LCD12864_writebyte(iDat,data1);
      LCD12864_writebyte(iDat,data2);
  LCD12864_writebyte(iCmd,0x36);                 // 开绘图显示
/*显示字体 参数格式: 显示位置(0x80-0x9f),显示个数,显示内容指针*/
void display_cnasc(uchar dis_bit,uchar num,uchar *cnasc)
  LCD12864_writebyte(iCmd,dis_bit);             // 写地址
  while(num>0)
    LCD12864_writebyte(iDat,*(cnasc++));
        num--;
  Delayus(10);
/*图片显示标头*/
void dis_title_pic(void)
  display_cnasc(0x80,2,"〓〓");
  display_cnasc(0x86,2,"〓〓");
/*显示菜单图片  格式:图片反显(1)或正常显示(0),显示图片的号码*/
void anti_nor_pic(uchar cpl_sign,uchar menu_num)
  uchar i,j,x,y;
  x=menu_num*3;                // 计算图片显示坐标
  if(x>6) x--;
  if(menu_num<3) y=16;        //下半屏显示
  else y=8;          // 上半屏显示
  if(cpl_sign==1)
    display_cnasc(0x82,4,menu_cn[menu_num]);  //显示选择的菜单标题
  for(j=0;j<24;j++)
   for(i=0;i<2;i++)
     LCD12864_writebyte(iCmd,0x34);  // 扩充指令集,关闭绘图显示
     LCD12864_writebyte(iCmd,0x80+y);
     LCD12864_writebyte(iCmd,0x80+x+i);  // 分两次显示16bit
     LCD12864_writebyte(iCmd,0x30);      // 基本指令集
     if(cpl_sign==1)              // 图片反选
           con_disp(~menu_pic[menu_num][j*4+i*2]);
       con_disp(~menu_pic[menu_num][j*4+i*2+1]);
     else                                          // 正常显示
           con_disp(menu_pic[menu_num][j*4+i*2]);
       con_disp(menu_pic[menu_num][j*4+i*2+1]);
   y++;
   if(y==32&&menu_num<3) {x+=8;y=0;}  // 上下屏切换
  LCD12864_writebyte(iCmd,0x36);      // 扩充指令集,打开绘图显示
 函数名称: LCD12864_initial
 功    能: 12864液晶初始化
 参    数: 无
 返回值  : 无
void LCD12864_initial(void)
        Delayms(100);                                // 等待内部复位
        LCD12864_portini();                        //端口初始化
        LCD12864_writebyte(iCmd, LCDb_FUNCTION_8BIT);        //功能、模式设定
        LCD12864_writebyte(iCmd, LCDb_ON);                //打开显示
        LCD12864_clear();                                //清屏
        LCD12864_writebyte(iCmd, LCDb_ENTRY);        // 输入模式设定
        //clear_dis();
        //LCD12864_writebyte(iCmd,LCDb_CURON);        // 显示光标
    //LCD12864_writebyte(iCmd,LCDb_CURFLA); // 打开光标闪烁
        //LCD12864_writebyte(iCmd,LCDb_C2R);    //光标右移
函数名称: DIS_12864M
功    能: DIS_12864M
参    数: keynum[]--键值数组
返回值  : 无
void DIS_12864M(void)
   uchar i,j;
   for(i=0;i<6;i++)
    dis_title_pic();     //显示图片菜单
    anti_nor_pic(0,i);
    anti_nor_pic(1,2);   //后面数字是要显示的图片位置
    Delayms(2000);
函数名称:main
功    能: Dis_inputkey
参    数: 无
返回值  : 无
void main(void)
 uchar i=0;
 Board_init();                    //初始化开发板
 LCD12864_initial();          //初始化12864液晶
                         //调用显示程序
 while (1)
  DIS_12864M();
**********************头文件*********************************
  文件:AVR_EB1A.H
  功能:定义一些AVR_EB1A开发板上应用程序用到的常量
/******************数据类型宏定义******************/
#define uchar unsigned char
#define uint unsigned int
函数名称: Delayus
功    能: 延时指定微秒(8M晶振)
参    数: US--延时的微秒数(大约,不是很精确,MS越大越准确)
返回值  : 无
void Delayus(uint US)
 uint i;
 US=US*5/4;                           //5/4是在8MHz晶振下,通过软件仿真反复实验得到的数值
 for( i=0;i<US;i++);
函数名称: Delayms
功    能: 延时指定毫秒(8M晶振)
参    数: MS--延时的毫秒数
返回值  : 无
void Delayms(uint MS)
 uint i,j;
 for( i=0;i<MS;i++)
 for(j=0;j<1141;j++);        //1141是在8MHz晶振下,通过软件仿真反复实验得到的数值
函数名称: Board_init
功    能: 初始化实验板,关闭全部功能
参    数: 无
返回值  : 无
void Board_init(void)
        DDRA=0xFF;        //将四个IO口全部配置为输出
        DDRB=0xFF;
        DDRC=0xFF;
        DDRD=0xFF;
/******************12864液晶(4-8线并行传输)常量及操作******************/
#define LCDb_CTRL            PORTD        //12864控制端口定义
#define LCDb_CTRL_DDR            DDRD        //控制端口方向寄存器定义
#define LCDb_RS                           PD4                //定义四个控制引脚
#define LCDb_RW                    PD5
#define LCDb_E                           PD6
#define LCDb_RST            PD7
#define LCDb_L1                0x80        //第一行的地址
#define LCDb_L2                0x90        //第二行的地址
#define LCDb_L3                0x88        //第三行的地址
#define LCDb_L4                0x98        //第四行的地址
#define LCDb_CGRAM_ADDR        0x40        //CGRAM的开始地址
#define LCDb_CGMAX         64        //CGRAM存储的最大字节数
#define LCDb_SET_RS                LCDb_CTRL|=BIT(LCDb_RS)        //四个控制管脚的控制操作
#define LCDb_SET_RW         LCDb_CTRL|=BIT(LCDb_RW)
#define LCDb_SET_E          LCDb_CTRL|=BIT(LCDb_E)
#define LCDb_SET_RST          LCDb_CTRL|=BIT(LCDb_RST)
#define LCDb_CLR_RS                 LCDb_CTRL&=~BIT(LCDb_RS)
#define LCDb_CLR_RW                 LCDb_CTRL&=~BIT(LCDb_RW)
#define LCDb_CLR_E                  LCDb_CTRL&=~BIT(LCDb_E)
#define LCDb_CLR_RST                 LCDb_CTRL&=~BIT(LCDb_RST)
#define LCDb_DO                PORTB        //输出数据总线端口定义
#define LCDb_DI                PINB        //输入数据总线端口定义
#define LCDb_DATA_DDR        DDRB        //数据总线方向寄存器定义
#define LCDb_DATA       0Xf0        //((1<<PB4)|(1<<PB5)|(1<<PB6)|(1<<PB7))
                                    //portB4/5/6/7out,输出数据总线端口定义
#define LCDb_FUNCTION_8BIT        0x38           //液晶模式为8位
#define LCDb_FUNCTION_4BIT      0x20    //液晶模式为4位
#define LCDb_BASCMD        0x30                // 基本指令集
#define LCDb_CLS        0x01                // 清屏
#define LCDb_HOME        0x02                // 地址返回原点,不改变DDRAM内容
#define LCDb_ENTRY         0x06                // 设定输入模式,光标加,屏幕不移动
#define LCDb_CURON      0x0E                // 显示光标
#define LCDb_CURFLA        0x0F                // 打开光标闪烁
#define LCDb_C2L        0x10                // 光标左移
#define LCDb_C2R        0x14                // 光标右移
#define LCDb_D2L        0x18                // 屏幕左移
#define LCDb_D2R        0x1C                // 屏幕又移
#define LCDb_ON                0x0C                // 打开显示
#define LCDb_OFF        0x08                // 关闭显示
#define LCDb_EXTCMD1        0x34                // 扩充指令集,关闭绘图显示
#define LCDb_EXTCMD2        0x36                // 扩充指令集,打开绘图显示
#define LCDb_EXTCLS        0x01                // 清屏
#define LCDb_REVL1        0x04                // 反显第1行
#define LCDb_REVL2        0x05                // 反显第2行
#define LCDb_REVL3        0x06                // 反显第3行
#define LCDb_REVL4        0x07                // 反显第4行
本贴被 21mcuel 编辑过,最后修改时间:2009-01-14,13:13:04.
发表于 2009-1-14 09:51:03 | 显示全部楼层
显示图片前,要先清下GDRAM,全写0X00。
发表于 2009-1-14 10:36:13 | 显示全部楼层
同意3楼
 楼主| 发表于 2009-1-14 13:10:43 | 显示全部楼层
    我已经说了呀!在写图片之前,写图函数LCD12864_opGDRAM(0x00);已经写0x00了,已经清了GDRAM,还是有杂点,
 换了一个旧的ST7920的 12864液晶(TG12864E-03)还是一样的。
    大家有机会可以试试我上面的这些小图片32*24的显示,是否有噪点?
发表于 2009-1-15 09:46:45 | 显示全部楼层
LCD12864_opGDRAM(0x00);一句不行,要在绘图模式下把所有显存空间写0。
算来直接给你代码好了:
名称: void ST7920_ClearGDRAM(void)
功能: 清除GDRAM数据
参数:
返回: 无
        unsigned char i;
        unsigned char j;
        unsigned char k;
        unsigned char bDx = 0x80;        //GDRAM水平地址
        unsigned char bDy = 0x80;        //GDRAM垂直地址
        for(i = 0; i < 2; i++)        // 在绘图GDRAM中写满屏0x00数据
                for(j = 0; j < 32; j++)
                        for(k = 0; k < 8; k++)
                                ST7920_WriteCMD(0x34);        ST7920_WriteCMD(bDy + j);//先写入垂直地址        ST7920_WriteCMD(bDx + k);//再写入水平地址
                                ST7920_WriteCMD(0x30);
                                ST7920_WriteData(0x00);
                bDx = 0x88;
        ST7920_WriteCMD(0x36);
函数上电后调用一次即可。
本贴被 wormchen 编辑过,最后修改时间:2009-01-15,09:49:44.
 楼主| 发表于 2009-1-15 11:41:50 | 显示全部楼层
  谢谢,昨天已经解决了,是写屏函数问题。需要多写0x00几次。
发表于 2009-5-2 19:45:35 | 显示全部楼层
刚买了一个12864
发表于 2009-9-14 09:03:49 | 显示全部楼层
在anti_nor_pic()函数里有个con_disp()参数调用好像不对啊
发表于 2009-9-14 20:42:14 | 显示全部楼层
在anti_nor_pic()函数里有个con_disp()参数调用好像不对啊 麻烦楼主解释一下 我不太明白
发表于 2009-9-15 11:17:19 | 显示全部楼层
mark
发表于 2009-9-15 12:11:11 | 显示全部楼层
写的不错.
发表于 2009-11-2 23:29:08 | 显示全部楼层
mark
发表于 2010-1-27 13:10:55 | 显示全部楼层
这个绘图区清0程序应该可以给你省点代码。
void LcmClearBMP( void )
     Uchar i,j;
     wr_lcd(comm,0x34);      //8Bit扩充指令集,即使是36H也要写两次
     wr_lcd(comm,0x36);      //绘图ON,基本指令集里面36H不能开绘图
     for(i=0;i<32;i++)            //12864实际为256x32
           wr_lcd(comm,0x80|i);      //行位置
           wr_lcd(comm,0x80);        //列位置
           for(j=0;j<32;j++)            //256/8=32 byte
                wr_lcd(dat,0);
发表于 2010-1-27 13:25:49 | 显示全部楼层
拿下,需要用
发表于 2010-1-27 13:36:52 | 显示全部楼层
mark
发表于 2010-1-27 16:45:50 | 显示全部楼层
mark
发表于 2010-1-27 17:44:17 | 显示全部楼层
不管程序就版式来说LZ有一手好"书法" 程序看着让人舒服.有入有出,可读性非常好,赞一个! 界面也很漂亮再赞一个! 问题解决了就只好混分儿了~~~
发表于 2010-4-11 04:55:37 | 显示全部楼层
发表于 2010-4-11 06:46:26 | 显示全部楼层
mark
发表于 2010-4-11 10:00:26 | 显示全部楼层
mark
发表于 2010-8-21 10:03:22 | 显示全部楼层
顶下!顺便收藏
发表于 2010-8-22 08:48:31 | 显示全部楼层
lz的图片在哪截的啊
发表于 2010-8-26 11:49:29 | 显示全部楼层
mark
发表于 2010-8-26 13:23:20 | 显示全部楼层
mark!
发表于 2010-8-26 14:48:36 | 显示全部楼层
mark~学习一下
发表于 2010-8-30 21:26:17 | 显示全部楼层
必须好的啊
发表于 2010-8-30 21:46:12 | 显示全部楼层
mark
发表于 2010-8-30 21:50:44 | 显示全部楼层
你是不是屏的片选一直拉低了?我记得有个帖子问的是这个ST7920 如果一直片选有效,会出现乱码
发表于 2010-8-30 23:01:49 | 显示全部楼层
做的不错!
发表于 2010-10-12 17:10:55 | 显示全部楼层
学习一下
发表于 2010-10-26 16:06:22 | 显示全部楼层
楼主以及各位高手:
    我一直在琢磨菜单结构,看大家用的大都是结构体,里面把数据和处理数据的函数放在一个结构体里面,我百看也不能理解是怎么实现的? 这个好像是面向对象的程序设计了吧!? 可是我没有学过C++, 对面向对象的程序设计方法不理解? 楼主以及各位高手能不能详细的指导指导我一下啊!?不胜感激!!!!!!!!!!!
发表于 2010-11-7 20:15:30 | 显示全部楼层
学习
发表于 2010-11-8 10:26:19 | 显示全部楼层
个人习惯一行行的刷新。即使空白都要写个00进去。
类似的麻皮屏也遇到过,一般都是DDRAM没初始化写00造成的。
发表于 2010-11-22 23:08:41 | 显示全部楼层
ST7920 12864液晶做的图文菜单系统可以显示图案,我也试过了,最后我在百度找到了答案,自己亲自试验了,我看了你的图,12864是能显示中文的,就是因为这个所以才导致了花屏。
解决办法很简单,在初始化的时候出来给液晶写入0x01的命令,还有想液晶整屏写入0x00!
发表于 2010-12-7 15:44:44 | 显示全部楼层
MARK
发表于 2011-1-2 19:41:36 | 显示全部楼层
学习
发表于 2011-3-7 12:33:37 | 显示全部楼层
好像不对吧!每次读写都要忙判别的吧!把忙判别加到读写字节函数里。我是这样认为的。
发表于 2011-3-7 17:40:33 | 显示全部楼层
如果盘忙的话,就可以不用延时的,这样可以节省单片机的资源,是单片机的运行速度提高
发表于 2011-4-2 08:57:23 | 显示全部楼层
MARK
发表于 2011-4-5 18:01:41 | 显示全部楼层
几个号,以后用的上
发表于 2011-5-7 11:02:52 | 显示全部楼层
mark,
发表于 2011-5-7 11:26:42 | 显示全部楼层
马克
发表于 2011-5-12 13:43:34 | 显示全部楼层
标记
发表于 2011-5-26 16:48:56 | 显示全部楼层
留爪
发表于 2011-6-4 15:11:38 | 显示全部楼层
mark
发表于 2011-6-17 08:46:22 | 显示全部楼层
回复【2楼】21mcuel
好东西,用了两年的液晶可是液晶显示方面还没有弄通,我用1302和12864(带字库)做的电子钟,在调时间的时候不会出现光标,那位有这样的程序发一段看看
发表于 2011-6-21 20:59:16 | 显示全部楼层
马克一个。
发表于 2011-8-13 14:50:53 | 显示全部楼层
蛋筒,俺移植的一个1602的菜单程序,想的我蛋筒啊,同志们!看到楼主这个,俺才知道,俺有多菜!唉。。。
发表于 2011-8-14 15:32:14 | 显示全部楼层
这个程序里con_disp()有点问题,能否解释一下。。或者加正确这个程序里的这个函数
发表于 2011-8-15 11:04:08 | 显示全部楼层
mark
发表于 2011-8-15 11:32:10 | 显示全部楼层
菜鸟一个,来学习的
发表于 2011-8-18 16:55:31 | 显示全部楼层
MARK
发表于 2011-8-21 10:16:34 | 显示全部楼层
mark
发表于 2011-9-14 15:44:41 | 显示全部楼层
大家初始化写0x00,这个过程慢不慢啊?我的清屏怎么要5秒左右呢,急死俺了!
是我程序的问题吗?
发表于 2011-11-3 16:50:59 | 显示全部楼层
好像有看过你的博客 小峰
发表于 2011-11-4 23:24:23 | 显示全部楼层
发表于 2013-10-16 13:24:35 | 显示全部楼层
我也在学习这个菜单程序,
GMT+8, 2024-8-26 22:22
