程序是丛Micrium 下载的 AT91SAM7X256 ucosii
Wed Dec 24 10:27:56 2008: Loaded macro file: C:\Documents and Settings\桌面\Micrium\Software\EvalBoards\Atmel\AT91SAM7X256\IAR\OS-Probe\..\
BSP\AT91SAM7X256_Flash.mac
Wed Dec 24 10:27:56 2008: DLL version: V3.78b, compiled Dec 10 2007 17:56:48
Wed Dec 24 10:27:56 2008: Firmware: J-Link compiled Mar 3 2008 19:52:16 ARM Rev.5
Wed Dec 24 10:27:56 2008: JTAG speed is initially set to: 32 kHz
Wed Dec 24 10:27:56 2008: TotalIRLen = 4, IRPrint = 0x01
Wed Dec 24 10:27:56 2008: Halting CPU core
Wed Dec 24 10:27:56 2008: Software reset was performed
Wed Dec 24 10:27:56 2008: Initial reset was performed
Wed Dec 24 10:27:56 2008: J-Link found 1 JTAG device. ARM core Id: 3F0F0F0F
Wed Dec 24 10:27:56 2008: Device at TAP0 selected
Wed Dec 24 10:27:56 2008: ------------------------------- The Remap is NOT -----------------------------------------
Wed Dec 24 10:27:56 2008: ---------------------------------------- Chip ID 0x275B0940
Wed Dec 24 10:27:56 2008: ---------------------------------------- Extention 0x00000000
Wed Dec 24 10:27:56 2008: ------------------------------- AIC 2 INIT ---------------------------------------------
Wed Dec 24 10:27:57 2008: ------------------------------- Watchdog Disable ----------------------------------------
Wed Dec 24 10:27:57 2008: RTCK seems to be bridged with TCK
Wed Dec 24 10:27:57 2008: Auto JTAG speed: 8000 kHz
Wed Dec 24 10:27:58 2008: 27276 bytes downloaded and verified (22.75 Kbytes/sec)
Wed Dec 24 10:27:58 2008: Warning:
Verify error at address 0x00000000, target byte: 0x21, byte in file: 0x18
Verify error at address 0x00000001, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x00000002, target byte: 0x00, byte in file: 0x9F
Verify error at address 0x00000003, target byte: 0xEA, byte in file: 0xE5
Verify error at address 0x00000004, target byte: 0xFE, byte in file: 0x18
Verify error at address 0x00000005, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x00000006, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x00000007, target byte: 0xEA, byte in file: 0xE5
Verify error at address 0x00000188, target byte: 0xED, byte in file: 0x01
Verify error at address 0x00000189, target byte: 0xFF, byte in file: 0x61
Wed Dec 24 10:27:58 2008: Warning: Too many verify errors, only the first 200 are displayed
Wed Dec 24 10:27:58 2008: Warning: There were warnings during download, see Log Window
Wed Dec 24 10:27:59 2008: Loaded debugee: C:\Documents and Settings\桌面\Micrium\Software\EvalBoards\Atmel\AT91SAM7X256\IAR\OS-Probe\
FLASH\Exe\AT91SAM7X256-OS-Probe-v5.out
Wed Dec 24 10:27:59 2008: Target reset
Wed Dec 24 10:28:00 2008: -------------------------------Set PC ---------------------------------------- |
