回复: 80
一个AVR USART(RS232)低层驱动+中间层软件示例
发表于 2004-12-3 13:17:58 | 显示全部楼层 |阅读模式
一个USART(RS232)低层驱动+中间层软件示例
    一般教科书上提供的UART收发的程序往往是一段采用轮循(Polling)方式完成收发的简单代码。但对于高速的AVR来讲,采用这种方式大大降低了MUC的效率。在使用AVR时,应根据芯片本身的特点(片内大容量数据存储器RAM,更适合采用高级语言编写系统程序),编写高效可靠的UART收发接口(低层)程序。下面是一个典型的USART的接口程序。
#include <mega128.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART0 Receiver buffer
#define RX_BUFFER_SIZE0 8
char rx_buffer0[RX_BUFFER_SIZE0];
unsigned char rx_wr_index0,rx_rd_index0,rx_counter0;
// This flag is set on USART0 Receiver buffer overflow
bit rx_buffer_overflow0;
// USART0 Receiver interrupt service routine
#pragma savereg-
interrupt [USART0_RXC] void uart0_rx_isr(void)
char status,data;
#asm
         push r26
            push r27
            push r30
            push r31
            in   r26,sreg
            push r26
#endasm
status=UCSR0A;
data=UDR0;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
       rx_buffer0[rx_wr_index0]=data;
       if (++rx_wr_index0 == RX_BUFFER_SIZE0) rx_wr_index0=0;
       if (++rx_counter0 == RX_BUFFER_SIZE0)
              rx_counter0=0;
              rx_buffer_overflow0=1;
#asm
       pop  r26
       out  sreg,r26
       pop  r31
       pop  r30
       pop  r27
       pop  r26
#endasm
#pragma savereg+
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART0 Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
  char data;
  while (rx_counter0==0);
  data=rx_buffer0[rx_rd_index0];
  if (++rx_rd_index0 == RX_BUFFER_SIZE0) rx_rd_index0=0;
  #asm("cli")
    --rx_counter0;
  #asm("sei")
  return data;
#pragma used-
// USART0 Transmitter buffer
#define TX_BUFFER_SIZE0 8
char tx_buffer0[TX_BUFFER_SIZE0];
unsigned char tx_wr_index0,tx_rd_index0,tx_counter0;
// USART0 Transmitter interrupt service routine
#pragma savereg-
interrupt [USART0_TXC] void uart0_tx_isr(void)
  #asm
      push r26
      push r27
      push r30
      push r31
      in   r26,sreg
      push r26
  #edasm
  if (tx_counter0)
         --tx_counter0;
       UDR0=tx_buffer0[tx_rd_index0];
       if (++tx_rd_index0 == TX_BUFFER_SIZE0) tx_rd_index0=0;
  #asm
      pop  r26
      out  sreg,r26
      pop  r31
      pop  r30
      pop  r27
      pop  r26
  #endasm
#pragma savereg+
// Write a character to the USART0 Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
  while (tx_counter0 == TX_BUFFER_SIZE0);
  #asm("cli")
   if (tx_counter0 || ((UCSR0A & DATA_REGISTER_EMPTY)==0))
       tx_buffer0[tx_wr_index0]=c;
       if (++tx_wr_index0 == TX_BUFFER_SIZE0) tx_wr_index0=0;
       ++tx_counter0;
       UDR0=c;
  #asm("sei")
#pragma used-
// Standard Input/Output functions
#include <stdio.h>
// Declare your global variables here
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
// USART0 Baud rate: 9600
UCSR0A=0x00;
UCSR0B=0xD8;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x67;
// Global enable interrupts
#asm("sei")
while (1)
          // Place your code here
    这段由CVAVR程序生成器产生的UART接口代码是一个非常好的、高效可靠,并且值得认真学习和体会的。其特点如下:
   l.它采用两个8字节的接收和发送缓冲器来提高MCU的效率,如当主程序调用Putchar()发送数据时,如果UART口不空闲,就将数据放入发送缓冲器中,MCU不必等待,可以继续执行其它的工作。而UART的硬件发送完一个数据后,产生中断,由中断服务程序负责将发送缓冲器中数据依次送出。
   2.数据缓冲器结构是一个线性的循环队列,由读、写和队列计数器3个指针控制,用于判断队列是否空、溢出,以及当前数据在队列中的位置。
   3.用编译控制命令#pragma savereg-和#pragma savereg+,使得由CVAVR在生成的中断服务程序中不进行中断保护(CVAVR生成中断保护会将比较多的寄存器压入堆栈中),而在中断中嵌入汇编,只将5个在本中断中必须要保护的寄存器压栈。这样提高了UART中断处理的速度,也意味着提高了MCU的效率。
   4.由于在接口程序Putchar()、Getchar()和中断服务程序中都要对数据缓冲器的读、写和队列计数器3个指针判断和操作,为了防止冲突,在Putchar()、Getchar()中对3个指针操作时临时将中断关闭,提高了程序的可靠性。
    建议读者能逐字逐句地仔细分析该段代码,真正理解和领会每一句语句(包括编译控制命令的作用)的作用,从中体会和学习如何编写效率高,可靠性好,结构优良的系统代码。这段程序使用的方法和技巧,对编写SPI、I2C的串行通信接口程序都是非常好的借鉴。
    作为现在的单片机和嵌入式系统的工程师,不仅要深入全面的掌握芯片和各种器件的性能,具备丰富的硬件设计能力;同时也必须提高软件的设计能力。要学习和掌握有关数据结构、操作系统、软件工程、网络协议等方面的知识,具有设计编写大的复杂系统程序的能力。
USART应用实例
    使用ATmega128实现一个工业设备的主控制板,它与由ATmega8管理的按键和LED显示构成的控制面板距离在2米左右,两者之间采用USART通信联系。考虑到在实际应用中,俩者之间交换的数据很少,通信速度也不需要很高,重要的是保证通信的可靠和抗干扰,因此在硬件设计上采用电流环的连接方式,见图5.4。
   在图中通信双方采用光隔和三极管,将USART的电平变化变成电流变化后传送连接,如同工业上使用的20mA电流环通信一样,大大提高了通信的抗干扰能力。
通信协议和规程的制定:
   l.通信速率采用2400bps(速率太高时电流环的变化会跟不上)。
   2. 用户数据包采用定长格式,每个数据包长度为6个字节,其中第1个字节是数据包起始字节0xBB,第6字节为数据包结束字节0xEE,其它为用户命令、数据和系统状态参数。
   3.每次通信由A端发起,下发一个数据包;B端收到一个正确的数据包后,必须返回一个数据包应答。
   4.A端下发一个数据包后,在300ms内没有正确收到应答包时(在2400bps时传送6个字节的时间约为30ms),将再次重发;3次重发均不能正确收到应答包则报警。
   5.在系统正常工作时,A端每隔250ms下发一个数据包,B端如果在1s内没有正确收到一个下发的数据包,将进入安全保护程序。
   在这个应用实例中,USART接口的发送程序与前面给出的典型例程中的一样,而对USART的接收程序进行了改动和简化,使其更加符合在本系统中使用。
#define UART_BEGIN_STX        0xBB
#define UART_END_STX        0xEE
#define RX_BUFFER_SIZE0        6
unsigned char rx_counter;
bit Uart_RecvFlag
// USART Receiver interrupt service routine
#pragma savereg-
interrupt [USART_RXC] void uart_rx_isr(void)
  unsigned char status,data;
  #asm
    push r26
    push r27
    push r30
    push r31
    in   r26,sreg
    push r26
  #endasm
  status=UCSRA;
  data=UDR;
    if (!Uart_RecvFlag)
       rx_buffer[rx_counter] = data;
    switch (rx_counter)
            case 0:
        if (data == UART_BEGIN_STX)     rx_counter = 1;
       case 1:
       case 2:
       case 3:
       case 4:
        rx_counter++;
       case 5:
        rx_counter = 0;
        if (data == UART_END_STX)  Uart_RecvFlag = 1;
      rx_counter = 0;
   #asm
        pop  r26
    out  sreg,r26
    pop  r31
    pop  r30
    pop  r27
    pop  r26
  #endasm
#pragma savereg+
    if (Uart_RecvFlag)
    …………            //处理收到的数据包
    Uart_RecvFlag = 0;        //允许USART接受新的数据包
  …………            //处理其它任务
    在这段代码中,接收中断服务程序直接对数据包的起始字符和结束字符进行判断,并完成对整个数据包的接收。当接收到正确的6个字符的数据包后,将“Uart_RecvFlag”标志置位,通知上层程序处理收到的数据。一旦“Uart_RecvFlag”标志置位后,中断服务程序将不再接收新的数据(放弃掉收到的字节),使得数据缓冲区不会溢出。
    上层程序的设计,应保证以200ms左右的间隔对“Uart_RecvFlag”标志位进行一次判断。一旦判断“Uart_RecvFlag”标志置位后,马上进行处理,回送应答数据。处理完后将“Uart_RecvFlag”标志清除,允许USART接收新的数据包。
还可以考虑在数据包中增加“数据包编号”和“数据校验”2个字节,以进一步提高通信的可靠性。
-----此内容被machao于2005-03-07,22:40:22编辑过
 楼主| 发表于 2004-12-27 02:31:53 | 显示全部楼层
如果在数据包中再增加“从机地址”的字节,下发呼叫从机回答。所有从机收到数据包后,其软件检查从机地址是否与自己的地址符合,如是呼叫自己,则回答,否则不于回答,便可实现多机通信。该方法不需要使用AVR的硬件多机通信功能识别,不需要第9位的地址/数据指示,实现也很方便。
发表于 2004-12-27 09:02:06 | 显示全部楼层
楼上说的多机通讯方法是常用的多机通讯方法;给我感觉:各种现场总线协议多机通讯都采用这种方法;
发表于 2004-12-27 15:17:32 | 显示全部楼层
armok 阿莫,能不能把图一并贴出,以供参考,谢谢
 楼主| 发表于 2004-12-27 21:11:09 | 显示全部楼层
此段是《M128》书中的一个小节的摘选,现将图贴上,供参考。
发表于 2005-2-16 18:07:57 | 显示全部楼层
感谢马潮老师提供的程序,已经应用在我的系统中了,还有你的《ATmege8》让我在短短一周就可以自己做程序了
发表于 2005-3-5 15:46:00 | 显示全部楼层
我在ICC中重新定义了一下putchar函数
  while(TX_counter==TX_buffer_size);
  CLI();
  if(TX_counter||((UCSRA&DATA_REGISTER_EMPTY)==0))
    TX_buffer[TX_wr_index]=c;
    if(++TX_wr_index==TX_buffer_size) TX_wr_index=0;
    ++TX_counter;
    UDR=c;
SEI();
#include <stdio.h>
当我调用printf函数时,还会使用ICC库中自己的putchar函数吗?
发表于 2005-4-8 15:08:24 | 显示全部楼层
今天上午来学习马老师的这个程序
发现了一个问题
我的程序为
//ICC-AVR application builder : 2005-4-8 9:28:47
// Target : M128
// Crystal: 16.000Mhz
#include <iom128v.h>
#include <macros.h>
#define _Crystal_  8000
void port_init(void)
PORTA = 0x00;
DDRA  = 0x00;
PORTB = 0x00;
DDRB  = 0x00;
PORTC = 0x00; //m103 output only
DDRC  = 0x00;
PORTD = 0x00;
DDRD  = 0x00;
PORTE = 0x00;
DDRE  = 0x00;
PORTF = 0x00;
DDRF  = 0x00;
PORTG = 0x00;
DDRG  = 0x00;
//UART1 initialize
// desired baud rate:9600
// actual baud rate:9615 (0.2%)
// char size: 8 bit
// parity: Disabled
void uart1_init(void)
UCSR1B = 0x00; //disable while setting baud rate
UCSR1A = 0x00;
UCSR1C = 0x06;
UBRR1L = 0x67; //set baud rate lo
UBRR1H = 0x00; //set baud rate hi
UCSR1B = 0xD8;
char rx_buffer1[RX_BUFFER_SIZE1];
unsigned char rx_wr_index1,rx_rd_index1,rx_counter1;
//This flag is set on USART1 Receiver buffer overflow
unsigned char rx_buffer_overflow1;
#pragma interrupt_handler uart1_rx_isr:31
void uart1_rx_isr(void)
//uart has received a character in UDR
char status,data;
status=UCSR1A;
data=UDR1;
if((status&((1<<FE1)|(1<<DOR1)|(1<<UPE1)))==0)
        rx_buffer1[rx_rd_index1]=data;
        if(++rx_wr_index1==RX_BUFFER_SIZE1) rx_wr_index1=0;
        if(++rx_counter1==RX_BUFFER_SIZE1)
                rx_counter1=0;
                rx_buffer_overflow1=1;
char Uart1_Getchar(void)
        char data;
        while(rx_counter1==0);
        data=rx_buffer1[rx_rd_index1];
        if((++rx_rd_index1==RX_BUFFER_SIZE1))
        rx_rd_index1=0;
        CLI();
        --rx_counter1;
        SEI();
        return data;
char tx_buffer1[TX_BUFFER_SIZE1];
unsigned char tx_wr_index1,tx_rd_index1,tx_counter1;
#pragma interrupt_handler uart1_tx_isr:33
void uart1_tx_isr(void)
//character has been transmitted
if(tx_counter1)
        --tx_counter1;
        UDR1=tx_buffer1[tx_rd_index1];
        if(++tx_rd_index1==TX_BUFFER_SIZE1)
        tx_rd_index1=0;
void Uart1_Putchar(unsigned char data)
        while(tx_counter1==TX_BUFFER_SIZE1);
        CLI();
        if((tx_counter1||((UCSR1A&(1<<UDRE1))==0)))
                tx_buffer1[tx_wr_index1]=data;
                if(++tx_wr_index1==TX_BUFFER_SIZE1)
                tx_wr_index1=0;
                ++tx_counter1;
        UDR1=data;
        SEI();
void Uart1_Sendstring(unsigned char *string)
      while(*string)
      Uart1_Putchar(*string++);
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
XDIV  = 0x00; //xtal divider
XMCRA = 0x40; //external memory
port_init();
uart1_init();
MCUCR = 0x80;
EICRA = 0x00; //extended ext ints
EICRB = 0x00; //extended ext ints
EIMSK = 0x00;
TIMSK = 0x00; //timer interrupt sources
ETIMSK = 0x00; //extended timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void        Delay(unsigned char time)
        unsigned int i;
        for(; time > 0; time--)
                for(i = 0; i < (_Crystal_>>3); i++)                        //        about one millisecond
                        _NOP();
    unsigned char data;
        SPH = 0x0F;
    SPL = 0xFF;
        init_devices();
        Uart1_Putchar('a');
        Uart1_Sendstring("asdf");
        Delay(50);
        data=Uart1_Getchar();
        Uart1_Putchar(data);
几乎是一样的
我加了一个字符串的输出
问题就出在这一条上Uart1_Sendstring("asdf");
程序执行时,字符串输出不全,有时好象这条语句被跳过一样
      while(*string)
这个是子程序
我用轮训方法的时候这样用过的
哪位帮忙看一下
发表于 2005-4-8 21:46:04 | 显示全部楼层
没人回啊
发表于 2005-4-8 22:42:22 | 显示全部楼层
又试了一下
发送字符串的时候
每发送一个字符
加一段沿时,可以成功
不知道为什么
 楼主| 发表于 2005-4-9 00:23:16 | 显示全部楼层
在你的程序中,多处的函数调用可能有问题,主要是形参和实参的对应。如函数定义为char(字符型),而调用时为*char(字符指针型)。
发表于 2005-4-9 14:36:09 | 显示全部楼层
void Uart1_Putchar(unsigned char data) ;
这样调用应该是可以的啊
还有这个程序单步运行的话是可以的
 楼主| 发表于 2005-4-9 15:37:34 | 显示全部楼层
考虑while(*string)?
发表于 2005-4-9 19:13:17 | 显示全部楼层
while(*string)
当*string不为\0
继续啊
有问题吗?
发表于 2005-4-9 19:42:44 | 显示全部楼层
另外有个问题
我在icc里用printf
stdio.h中已经定义了putchar和getchar
我又从新定义了
发生冲突怎么办
谢谢马老师
发表于 2005-4-9 19:44:52 | 显示全部楼层
最新问题
我刚刚试了
puts和printf()
和我用void Uart1_Sendstring(unsigned char *string)
不加延时的情况一样啊
例如
我puts("abcdefghjk");
第一次输出ab
第2次输出ka
底3次输出ja
          h
          f
          d
-----此内容被wowo于2005-04-09,20:06:01编辑过
 楼主| 发表于 2005-4-10 12:11:47 | 显示全部楼层
这是在CVAVR中HELP里关于字符串使用的说明,请参考。
String constants must be enclosed in double quotation marks. E.g. "Hello world".
If you place a string between quotes as a function parameter, this string will automatically be considered as constant and will be placed in FLASH memory.
Example:
/ * this function displays a string located in SRAM */
void display_ram(char *s) {
/ * this function displays a string located in FLASH */
void display_flash(char flash *s) {
void main(void) {
/* this will not work !!! */
/* because the function addresses the string as */
/* it is located in SRAM, but the string "Hello world" */
/* is constant and is placed in FLASH */
display_ram("Hello world");
/* this will work !!! */
/* the function addresses the string as it is located in FLASH */
display_flash("Hello world");
发表于 2005-4-11 09:01:39 | 显示全部楼层
谢谢马老师
可能就是字符串在flash 和在ram的问题
发表于 2008-6-25 04:05:25 | 显示全部楼层
学习了
发表于 2008-7-14 18:39:00 | 显示全部楼层
长经验了
发表于 2008-7-15 10:41:26 | 显示全部楼层
学习了
发表于 2009-3-3 01:11:58 | 显示全部楼层
谢老师;受精了!
发表于 2009-3-3 08:17:42 | 显示全部楼层
学习
发表于 2009-4-6 13:23:22 | 显示全部楼层
好帖,收藏了,谢谢马老师!
发表于 2009-4-8 20:53:34 | 显示全部楼层
马老师,关于通讯远距使用电流环,如您第5楼所图示。光耦选型需通断速率高的例如6N37,TLP117、512、4N25/26等均通断速率不够快。发射用的三极管同样也要通断速率高的开关管,C945、9014、8050等常用的均经测试能够使用。其中C945和9014的波形最好,但距离和总线负荷重时会有击穿的现象,8050在距离远的状况下,波形会有畸变,但勉强可以通讯。
测试环境为PC to N×MCU(N大于350),PC端使用MAX232电平转换为0-5V,PC端最远端距离400米。通讯波特率9600。
发表于 2009-6-16 21:45:18 | 显示全部楼层
mark 要认真研读
发表于 2009-6-16 22:37:44 | 显示全部楼层
超好的基础知识
发表于 2009-6-17 11:17:28 | 显示全部楼层
mark
发表于 2009-7-21 12:06:38 | 显示全部楼层
这个程序要是加入错误处理就更好了.我上一个程序.加入错误处理的.这样在主程序轮询的时候只要检测错误情况就可以进行的数据收发,不需要while的等待.并且是标准c些的,移植性比较好.
编译环境IAR4.20A
uart.h文件
#ifndef _UART_H_
#define        _UART_H_
#define        UART_TX_BUFF_SIZE        50
#define        UART_RX_BUFF_SIZE        20
#define        UART_FLAG_START_TX        BIT0
typedef        enum
        UART_ERR_TX_FULL        = 1,
        UART_ERR_RX_EMPTY        = 2,
        UART_ERR_NO_ERROR        = 3,
}UART_ERROR;
extern        void        InitUart();
extern        UART_ERROR        UartPutByte(pu8 pbyte);
extern        UART_ERROR        UartGetByte(pu8 pbyte);
extern        UART_ERROR        UartPutStream(pu8 pstream, u8 size);
uart.c文件
#include "uart.h"
static        u8        tx_buff[UART_TX_BUFF_SIZE];
static        u8        tx_in;
static        u8        tx_out;
static        u8        tx_cnt;
static        u8        rx_buff[UART_RX_BUFF_SIZE];
static        u8        rx_in;
static        u8        rx_out;
static        u8        rx_cnt;
static        u8        flag;
#pragma        vector=USART_TXC_vect
__interrupt        void        UartTxIntHandle()
        if(tx_cnt>0)
                tx_cnt--;
                UDR        = tx_buff[tx_out++];
                if(tx_out==UART_TX_BUFF_SIZE)
                        tx_out        = 0;
                flag        &= ~(1<<UART_FLAG_START_TX);
#pragma        vector=USART_RXC_vect
__interrupt        void        UartRxIntHandle()
        u8        tmp;
        tmp        = UDR;
        if(rx_cnt<=UART_RX_BUFF_SIZE)
                rx_cnt++;
                rx_buff[rx_in++]        = tmp;
                if(rx_in==UART_RX_BUFF_SIZE)
                        rx_in        = 0;
void        InitUart()
        tx_in        = 0;
        tx_out        = 0;
        tx_cnt        = 0;
        rx_in        = 0;
        rx_out        = 0;
        rx_cnt        = 0;
        flag        = 0x00;
        UCSRB        |= (1<<RXCIE)|(1<<TXCIE)|(1<<RXEN)|(1<<TXEN);
        UBRRH        = 0;
        UBRRL        = 7;
        CPU_REG_DEF;
        ENTER_CRITICAL();
        if(tx_cnt<=UART_TX_BUFF_SIZE)
                if(flag&(1<<UART_FLAG_START_TX))
                        tx_cnt++;
                        tx_buff[tx_in++]        = *pbyte;
                        if(tx_in==UART_TX_BUFF_SIZE)
                                tx_in        = 0;
                        flag        |= 1<<UART_FLAG_START_TX;
                        UDR                = *pbyte;
                EXIT_CRITICAL();
                return UART_ERR_NO_ERROR;
        EXIT_CRITICAL();
        return UART_ERR_TX_FULL;
        CPU_REG_DEF;
        ENTER_CRITICAL();
        if(rx_cnt>0)
                rx_cnt--;
                *pbyte        = rx_buff[rx_out];
                EXIT_CRITICAL();
                if(++rx_out==UART_RX_BUFF_SIZE)
                        rx_out        = 0;
        EXIT_CRITICAL();
        return UART_ERR_RX_EMPTY;
        pu8        ptmp;
        if(size==0)
                ptmp        = pstream;
                while(*ptmp++);
                size        = ptmp-pstream-1;
        if(size>UART_TX_BUFF_SIZE-tx_cnt)
        while(size--)
                UartPutByte(pstream++);
程序里需要几个类型及宏定义在以下的cpu.h中定义.
#ifndef _CPU_H_
#define        _CPU_H_
#define        CPU_FREQ                7372800L
// 无符号类型定义
typedef        unsigned char        u8;
typedef        unsigned int        u16;
typedef        unsigned long        u32;
// 只读无符号类型定义
typedef        unsigned char const   uc8;
typedef        unsigned int const            uc16;
typedef        unsigned long const    uc32;
// 无符号指针类型定义
typedef        unsigned char*        pu8;
typedef        unsigned int*        pu16;
typedef        unsigned long*        pu32;
// 不可变无符号类型定义
typedef        volatile unsigned char        vu8;
typedef        volatile unsigned int        vu16;
typedef        volatile unsigned long        vu32;
// 不可变只读无符号类型定义
typedef        volatile unsigned char const        vuc8;
typedef        volatile unsigned int const                vuc16;
typedef        volatile unsigned long const        vuc32;
// 有符号类型定义
typedef        signed char                s8;
typedef        signed int                s16;
typedef        signed long                s32;
// 只读有符号类型定义
typedef        signed char const        sc8;
typedef        signed int const        sc16;
typedef        signed long const        sc32;
// 有符号指针类型定义
typedef        signed char*        ps8;
typedef        signed int*        ps16;
typedef        signed long*        ps32;
// 不可变有符号类型定义
typedef        volatile signed char        vs8;
typedef        volatile signed int        vs16;
typedef        volatile signed long        vs32;
// 不可变只读有符号类型定义
typedef        volatile signed char const        vsc8;
typedef        volatile signed int const        vsc16;
typedef        volatile signed long const        vsc32;
// 浮点类型定义
typedef        float                fp32;
// 布尔类型定义
//typedef         unsigned char        bool;
// cpu寄存器类型定义
typedef        unsigned char        c_reg;
// 标志位定义
typedef unsigned char        FLAG;
typedef        enum
        FALSE        = 0,
        TRUE        = !FALSE
}bool;
#define        BIT0        0
#define        BIT1        1
#define        BIT2        2
#define        BIT3        3
#define        BIT4        4
#define        BIT5        5
#define        BIT6        6
#define        BIT7        7
#define        FLAG0        0x01
#define        FLAG1        0x02
#define        FLAG2        0x04
#define        FLAG3        0x08
#define        FLAG4        0x10
#define        FLAG5        0x20
#define        FLAG6        0x40
#define        FLAG7        0x80
#define        setb(value, offset)        value|=1<<(offset)
#define        clrb(value, offset)        value&=~(1<<(offset))
#define        cplb(value, offset)        value^=1<<(offset)
#define        getb(value, offset)        (value&(1<<(offset)))
#define        MSB8        0x80
#define        LSB8        0x01
#define        MSB16        0x8000
#define        LSB16        0x0001
#define        MSB32        0x80000000
#define        LSB32        0x00000001
#define        CPU_REG_DEF        c_reg cpu_reg
#define        ENTER_CRITICAL()        cpu_reg=SREG;        \
                        __enable_interrupt()
#define        EXIT_CRITICAL()        SREG=cpu_reg
调用示例:
u8    tmp;
if(UartGetByte(&tmp)==UART_ERR_NO_ERROR)
      缓冲区中有数据进行协议或其他处理......
      缓冲区中没有数据执行错误代码,或者else可以省略,只处理有数据的情况.
发送示例:
发送一般都发送数据流,所以字节发送一般不需要.把发送字节函数开放出来其实没有必要.
u8 tmpbuff[N];
if(UartPutStream(tmpbuff, 2)==UART_ERR_NO_ERROR)
    发送成功,进行成功处理
    发送失败,可以重新发送或是其他处理
2.发送字符串
if(UartPutStream("hello", 0)==UART_ERR_NO_ERROR)
    发送成功,进行成功处理
    发送失败,可以重新发送或是其他处理
将参数2设置为0函数认为发送字符串.
说明:发送和接收的变量都可以使用结构体来完成.如:
typedef struct
    pu8 buff;
    u8  in;
    u8  out;
    u8  cnt;
    u8  flag;
}UART_STRUCT;
static     UART_STRUCT  TxStruct;
static     UART_STRUCT  RxStruct;
void InitUart()
    TxStruct.buff = tx_buff;
    TxStruct.in   = 0;
    TxStruct.out  = 0;
    TxStruct.cnt  = 0;
    TxStruct.flag = 0x00;
    RxStruct.buff = rx_buff;
或者in,out都用指针来做.
之所以没使用结构体或者使用指针来做是因为,为了提高底层函数的执行速度,以及节约占用SRAM的空间.
由于8位mcu的代码空间和sram比较小,所以做成分立的变量不进行结构封装,可以省出一些flash及其sram空间留给更需要的地方.并且底层函数只留出几个接口(UartGetByte(),UartPutStream())在使用的时候不需要考虑内部的架构.可以更好的偏向面向对象编程思想.
2.接收缓冲区满后没有进行溢出处理.想加的朋友自己考虑.其实很简单,加一个标志位即可完成.
发表于 2009-7-21 19:43:22 | 显示全部楼层
好,学习了
发表于 2009-8-3 16:01:48 | 显示全部楼层
收藏,学习了。
发表于 2009-8-14 10:45:17 | 显示全部楼层
有个纯C语言的问题,关于位左移,右移的疑惑,若把变量a左移1位,书上都是a<<1,但程序中的“UCSRB |= (1<<RXCIE)|(1<<TXCIE)|(1<<RXEN)|(1<<TXEN); ”把寄存器的某位放于后面,怎么解释啊,百思不得其解啊,谢谢了,高手勿笑!
发表于 2009-8-14 10:56:28 | 显示全部楼层
http://www avrvi com/start/avr_yiwei.html       AVR与虚拟仪器的网站
终于找到答案了,有同样疑惑的,可到那看看,去学习了!!为什么把名字屏蔽了,郁闷啊
发表于 2009-8-14 10:56:53 | 显示全部楼层
长经验了
发表于 2009-8-14 11:20:28 | 显示全部楼层
谢谢了!
发表于 2009-8-30 14:06:52 | 显示全部楼层
mark  mark  mark
发表于 2009-11-8 09:37:47 | 显示全部楼层
MARK
发表于 2009-11-10 19:07:18 | 显示全部楼层
发表于 2010-1-4 23:08:48 | 显示全部楼层
xuexi
发表于 2010-1-15 11:16:17 | 显示全部楼层
mark
发表于 2010-3-20 21:29:58 | 显示全部楼层
UCSRB |= (1<<RXCIE)|(1<<TXCIE)|(1<<RXEN)|(1<<TXEN); 回复【33楼】springvirus
有个纯C语言的问题,关于位左移,右移的疑惑,若把变量a左移1位,书上都是a&lt;&lt;1,但程序中的“UCSRB |= (1&lt;&lt;RXCIE)|(1&lt;&lt;TXCIE)|(1&lt;&lt;RXEN)|(1&lt;&lt;TXEN); ”把寄存器的某位放于后面,怎么解释啊,百思不得其解啊,谢谢了,高手勿笑!
1<<a a=2.意思是将00000001向左移2位则是000000100,再结合|位符,那么这个位就一定为1。这样你理解吗
出10入10汤圆
发表于 2010-3-20 21:39:49 | 显示全部楼层
学习一下.谢谢!
出235入235汤圆
发表于 2010-3-21 12:00:15 | 显示全部楼层
mark!
发表于 2010-3-21 12:54:00 | 显示全部楼层
先顶再学!
发表于 2010-3-22 16:09:25 | 显示全部楼层
mark 学习
发表于 2010-3-22 16:15:26 | 显示全部楼层
mark
发表于 2010-4-22 17:23:15 | 显示全部楼层
顶。
发表于 2010-6-9 02:23:42 | 显示全部楼层
好贴,学习了。
发表于 2010-6-9 20:07:34 | 显示全部楼层
记号
发表于 2010-6-24 01:02:37 | 显示全部楼层
很好用!
发表于 2010-6-24 01:23:38 | 显示全部楼层
mark
发表于 2010-6-29 09:45:27 | 显示全部楼层
mark
发表于 2010-6-29 19:45:46 | 显示全部楼层
长经验了,虽然最后一个程序没看懂!
发表于 2010-8-13 16:27:06 | 显示全部楼层
好好学习一下!
发表于 2010-12-4 00:34:28 | 显示全部楼层
谢谢马老师! 认真研读
发表于 2011-3-20 16:26:10 | 显示全部楼层
收藏,学习了
发表于 2011-3-20 17:29:10 | 显示全部楼层
mark to not win, me
发表于 2011-3-20 22:15:33 | 显示全部楼层
mark
发表于 2011-4-6 22:03:31 | 显示全部楼层
要学习
发表于 2011-4-6 22:07:40 | 显示全部楼层
mark .
发表于 2011-4-13 20:37:06 | 显示全部楼层
mark
发表于 2011-4-13 21:42:54 | 显示全部楼层
串口用队列不错
发表于 2011-8-25 10:45:14 | 显示全部楼层
记号!
发表于 2011-8-25 23:19:44 | 显示全部楼层
正在学习中.. 好帖!
发表于 2011-11-12 00:18:49 | 显示全部楼层
mark
发表于 2011-11-15 18:31:42 | 显示全部楼层
学习了
头像被屏蔽
发表于 2011-12-16 16:48:05 | 显示全部楼层
回复【1楼】machao
马老师您好:你书得14章串口通讯,我看了,现在疑惑了,我没有学这个上位机编程,现在是学VB还是VC++,哪一个更实用,易于入手,就是学完了就可以直接应用!谢谢
发表于 2012-6-1 11:18:24 | 显示全部楼层
好好学习一下
发表于 2012-6-16 12:10:23 | 显示全部楼层
不错不错啊
发表于 2012-6-30 10:29:20 | 显示全部楼层
电源没有隔离
发表于 2012-6-30 13:14:32 | 显示全部楼层
好好学习一下
 楼主| 发表于 2012-7-1 22:18:49 | 显示全部楼层
wjjcyy 发表于 2012-6-30 10:29
电源没有隔离
图中2个电源,互相不干涉,怎么叫没有隔离?你仔细分析过吗?
发表于 2012-7-2 10:35:40 | 显示全部楼层
......仔细分析了。。。全图要打开的。。。。。。我当时用的是两个光耦。。
 楼主| 发表于 2012-7-2 14:07:12 | 显示全部楼层
wjjcyy 发表于 2012-7-2 10:35
......仔细分析了。。。全图要打开的。。。。。。我当时用的是两个光耦。。 ...
图中是用了两个光耦的,有问题么?到底电源隔离了没有?
这里只有大家知道我,没人知道你是谁,所以没有必要吞吞吐吐吧?
发表于 2012-7-2 22:57:29 | 显示全部楼层
这里只有大家知道我,没人知道你是谁,所以没有 ...
隔离了。。。
发表于 2012-7-18 18:03:42 | 显示全部楼层
马老师,这种USART  低层驱动+中间层软件的方法能否应用于51系列的单片机。
发表于 2012-7-18 18:22:42 | 显示全部楼层
最近想移植到51系统中,但始终不能通信。
程序如下:
void send_data(uchar tx_data)
TB8 = 0;
if(voice_flag)
   TB8 = 1;
   voice_flag=0;
  while(tx_count==TX_BUFFER_SIZE);
  ES=0;
  if(!TI)                                       // 1
    tx_buffer[tx_wr_index]=tx_data;
    if(++tx_wr_index==TX_BUFFER_SIZE)  tx_wr_index=0;
    ++tx_count;
    SB UF = tx_data;
  ES=1;
void send_frame_data()
   send_data(BEGIN_DATA);
       send_data(work_mode);
       send_data(graph_mode);
       send_data(play_num);
       send_data(color_data);
       send_data(END_DATA);
void Time0() interrupt 1  using 1
   TH0=0x00;
  TL0=0x00;
  if(slave_rec_flag)
       work_mode = slave_rx_buffer[1];
       graph_mode = slave_rx_buffer[2];
       play_num = slave_rx_buffer[3];
       color_data = slave_rx_buffer[4];
       slave_rec_flag = 0;
void Serial(void) interrupt 4 using 3
uchar data_buf;
  if(RI)
   RI=0;
  dmx_flag=0;
  data_buf = SBUF;
  if(!slave_rec_flag)
        if(RB8)
            mic_led = 1;
            voice_speed=4;
            voice_flag1=1;
            voice_screen = 0;
        slave_rx_buffer[rx_index]=data_buf;
        rx_index++;
        switch(rx_index)
          case 1:
               if(data_buf != BEGIN_DATA)
                 rx_index=0;
          case 6:
               rx_index =0;
               if(data_buf == END_DATA)
                  slave_rec_flag=1;
  if(TI)
    TI=0;
    if(tx_count)
     TB8=0;
     if(voice_flag)
       voice_flag=0;
       TB8 = 1;
     tx_count--;
     SBUF = tx_buffer[tx_rd_index];
    if(++tx_rd_index==TX_BUFFER_SIZE)
       tx_rd_index = 0;
void main()
     send_frame_data();
void init(void)
uchar iii;
IE=0X93;                        //EA=1;ES=1;ET0=1;ET1=1;EX0=1;开全局中断,定时器T0,T1中断 串行中断,外部中断
TMOD=0X11;                      //定时器T0,T1工作方式都为1  16位 产生32.78MS的定时
TH0=0X00;
TL0=0X00;
TR0=1;
IT0=1;                      //INT0边沿触发
////////////////////////////////定时器1中断使能定时20US///////////////////////
/*ET1=1;
TR1=1;
TH1=0xFF;
TL1=0x37;*/
//----------------------------波特率设置----------------------------//
////////////////////40MHZ使用定时器2溢出中断产生2500KBIT波特率 9位数据/////////
PCON = 0x00;
T2CON = 0x30;
SCON = 0xD0;
TR2 = 1;
RCAP2H = 0xFF;
//RCAP2L = 0xFB;
RCAP2L = 0xFD;
IP = 0x10;
play_num=0;
SetColor(OFF_COLOR);
while(iii<40)
   delay_time(30000);
   iii++;
zoom_xy=30;
play_time=0;
slave_rec_flag=0;
//TI=1;
请问一个马达老师,在51系列串口通信机制里,在标示1位置怎样判断串口处于忙状态,有数据未发送完成。谢谢!
发表于 2012-7-20 15:36:43 | 显示全部楼层
没有人指导我这个学生菜鸟?顶一下。
出75入4汤圆
发表于 2020-7-20 15:40:07 | 显示全部楼层
这个要认真学习下。
GMT+8, 2024-7-28 03:00
